03-28-2022, 04:08 PM | #23 |
Rep 3,245
Russell: Porpoising responsible for "99%" of Mercedes' problems
https://www.motorsport.com/f1/news/r...blems/9392139/ Good article with insight what Russ thinks about the current status of Merc car. |
NYG10840.50 |
03-28-2022, 04:12 PM | #24 |
#buildnotbought
10961
Rep 4,910
So 1% is that huge gap between Russel and Hamilton?
I mean they have the same cars right? I mean porpoising is probably their main problem (and a mechanical problem), but I think they have more (pretty big) problems besides that.
03-28-2022, 04:24 PM | #25 | |
Rep 7,466
Besides proposing their next issue is downforce, and that is reduced due to porpoising, and the last part is drag due to the larger wings they have to run. So if they fix porpoising theyll fix everything, theyll be able to run the car lower and that increases down force and fixes all their grip issues, and they will be able to reduce drag by running smaller wings as the floor now generates their required downforce and the floor does this more efficently than the wings so more down force with lower drag.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
irunalot1518.00 |
03-28-2022, 04:36 PM | #26 |
#buildnotbought
10961
Rep 4,910
Yeah I understand that a different setup greatly affects performance, but howcome they couldn't align those setups more the way they did in Bahrein?
It's pretty rare that from 1 team 1 car qualifies 6th and the other car 16th. I think HAM also was totally off his (mental) pace, so I think there's also an issue to be solved there. (I imagine a better performing car will do a lot here but he's not his usual self) And lastly of course the big repeating tactical errors (don't know if it's a coincidence it's both times with HAM). This race they missed a pit window, but last race they went on hards. I don't recall exactly, but had they even tested those hard tyres in FP?!?
03-28-2022, 04:48 PM | #27 |
60819
Rep 19,771
03-28-2022, 05:04 PM | #28 |
63935
Rep 24,826
Spot on !
You can bet on it ..Because the RB18-B gets new upgrades specific for Australia . The smaller rear wing worked perfectly last weekend to get the higher topspeed. A. Newey is very busy to make the Redbull faster in the slow corners .. Overheating of the brakes is also an issue for the Red Bull ..
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
03-28-2022, 05:07 PM | #29 |
63935
Rep 24,826
That's why he disappeared completely
03-28-2022, 05:07 PM | #30 |
Supreme Allied Commander
1969
Rep 61,781
Drives: A BBS WHORE
Actually been three years since last time F1 held a race. 2020 all the teams arrived and cancelled just before FP1.
Fliplegend1471.00 NYG10840.50 |
03-28-2022, 05:08 PM | #31 | |
60819
Rep 19,771
03-28-2022, 05:10 PM | #32 |
60819
Rep 19,771
...unlike me, g'nite all.
03-28-2022, 05:19 PM | #33 | |
63935
Rep 24,826
Then you/we know what is going on .... It's pretty simple : Mercedes screwed it completely up with the E-10 fuel and the bigger turbo's! One or two new floors wont help them ...And the Star-Wars mirrors s@ck too !
03-28-2022, 05:22 PM | #34 |
63935
Rep 24,826
Don't be worried my friend ...A. Newey is on our side !
03-28-2022, 05:23 PM | #35 | |
Rep 7,466
This is why max qualified high up with the rb16 while albon could never get the setup right. I'm not comparing Lewis to albon, just making an analogy. In the case of Lewis he was probably searching for more performance and eventually it bit him, this will probably not happen again because he likely will just have to accept a compromised setup to avoid changing things so much that he ran out of time to refine. In terms of the pit window I guess it was confusing because Ric was parked right in front of the pit entrance and Hamilton probably didn't want to risk getting a penalty like last time when he boxed when a car covered the pit entrance. In terms of the hard tires, they performed no so good because the tire blankets are set to a lower temp this year so it takes time for the hard tires to get up to temp and that's why they looked like crap out of the pits.
03-28-2022, 05:26 PM | #36 | |
Rep 7,466
1) Mclaren has over heating issues, and a major lack of downforce, and braking issues. Top speed isn't even their number one concern right now. 2) AMR: has major porpoising issues to the point where they have to run an even higher ride height vs. merc so they also don't have a top speed issue, they have a down force issue. 3) williams is williams.
03-28-2022, 05:52 PM | #37 | ||
#buildnotbought
10961
Rep 4,910
If you're not in time to give that info, you fail. how come they know that at the finishline but not know this 5 or 10sec earlier. Nothing changed in the status quo afaik. The pit entry lights didn't just change; all green when HAM was approaching. Obviously it was a confusing situation, but it's in those situations merc. always fails. Both the pitcrew/team as HAM have difficulty to adapt to the confusing situations. They can win, but only on their conditions. And VER/RB are very very good at making those split second decisions right at the moment that it counts. This year: hard tyres in bahrain, missing pit entry in saudi arabia. Last year: not coming in for slicks in Hungary (consequence: 2nd instead of 1st, so missing 7 points and a race win) Restart at Bahkoe: Ham leaves brake magic button accedentally on: Looses 2nd place completely. At the portuguese gp they pulled in BOT 1 lap too early. And so on. And the other side of the story is RB. How often have they either closed the gap or passed HAM with an undercut. Or VER going in at exactly the right time when it starts to rain. RB hardly makes any tactical mistakes and profits from a lot of tactical decisions. And last race VER managed each pitstop to manage an undercut and reduce LEC lead with 3 or 4 sec. That reduced the gap every time. Ferrari currently doesn't make any obvious mistakes but RB still has the edge on the tactical strategy imho.
03-28-2022, 05:57 PM | #38 | |
Rep 7,466
Because there were 3 test days and 3 free practices in Bahrain... Strategy still needs to improve.
NYG10840.50 |
03-28-2022, 07:05 PM | #39 |
63935
Rep 24,826
RUS has more strength in his right foot ...
03-28-2022, 07:19 PM | #40 | |
63935
Rep 24,826
For HAM It's even worse ! Because HAM is scared in the 2022 Mercedes , That's why RUS is faster ... 1 sec. in F1 terms is not a river of time , that's a sea of time !
03-28-2022, 07:26 PM | #41 |
Rep 3,715
03-28-2022, 08:02 PM | #42 | |
Rep 7,466
So I guess Perez out qualified max because max was scared, it's definitely note tire related just like it's not setup related.
03-28-2022, 08:11 PM | #43 | |
Rep 3,715
Perez out qualified Max because he drove a really ideal lap and Max's setup had a lot more understeer. He even uses his brakes for turn in on 9 while Checo just lifts. |
M5Rick60818.50 ///M Power-Belgium63934.50 |
03-28-2022, 08:18 PM | #44 |
17575
Rep 10,692
Drives: M4 CS. Former G82, x2 F82, F80
Oh so they finally decided to put their big boy pants on and have a race huh?
Good. |
