Extended BMW 335d PIDs for Torque
09-05-2018, 10:18 AM | #221 |
Rep 28
now that the bimmergeeks app is out, i noticed that there is trans temperature data available through the obd port with their app. Has there been any further development of this PID to made the same trans temp information available through torque?
09-07-2018, 01:32 PM | #222 |
87
Rep 370
Trying one more time, can someone please share nice GAUGEs LAYOUT!?
09-14-2018, 08:30 PM | #223 |
798
Rep 1,630
09-14-2018, 08:35 PM | #224 |
798
Rep 1,630
12-08-2018, 01:15 PM | #225 |
24
Rep 48
Drives: 2008 E92 335I Coupe
like this?
02-26-2019, 09:02 AM | #227 |
87
Rep 370
No, i mean you can EXPORT gauge layout and then just share it with community here and now im interested in yours because you somehow got fuel rail pressure!)
03-03-2019, 08:08 PM | #228 |
Rep 803
https://anonfile.com/HfmdK1vbb5/BMW335dextendedxx_1_csv
I have that and a few calcs based on rpm/maf, vw tdi had maf mg per stroke. Oh and mg fuel per stroke like the tdi had. |
03-12-2019, 10:14 PM | #229 |
24
Rep 48
04-16-2019, 10:28 PM | #231 |
Rep 30
Hey, I've been looking through all the info here, can't find what I'm looking for;
Is there a PID or way to look at diesel injector fuel trim/compensation values? I'm looking for an Android solution to a specific table I can get in INPA. 'Selective Mass Adjustment'. I use it to check the health of my diesel injectors and look for warning signs of a failing injector - I've been stranded twice! Check out Cylinder 5 in this vid: https://youtu.be/FicbKEFSSgI And my write up of it here: https://xoutpost.com/bmw-sav-forums/...ml#post1159871 I'm hoping there is an easier/quicker way to monitor this than having to pull out my laptop and cable all the time. Any help appreciated, Simeon |
05-01-2019, 09:34 AM | #232 |
Rep 10
If laziness is mother then daddy is frustration and I'm bout to take it out on the torque app.. I cannot get it to connect for the life of me.. Did anyone get a "select the right baud rate" message and can't connect? At this point I'm done with torque pro unless you guys have an answer.
Maybe I have already found my problem after digging into the forums.. I have the bimmer geeks k+dcan usb cable and well I haven't gone down yet but I'm pretty sure I just need to switch it from k to d can on the obd2 connector itself. Last edited by blk35d; 05-01-2019 at 06:32 PM.. Reason: More info |
05-02-2019, 04:09 PM | #233 | |
Rep 10
05-22-2019, 01:23 PM | #234 |
Rep 2
Here is the ability to get a good BOOST
Thank you DWR, I am a rider from Taiwan. According to your tips, I finally read the correct boost value on my E60 535I:party0030::party0030::party0030::party0030:
https://youtu.be/A12ld-kfm6Q5I. |
05-31-2019, 02:48 AM | #235 |
Rep 4
Are these PID's for the later N57 engine? I've tried on my '06 M57 and they don't seem to work.
Also, boost on torque pro seems to max out at 22psi for me, but it properly flat lines so I don't think this is the actual maximum, just the end of range for the reading, is this correct? |
07-27-2019, 08:19 AM | #236 |
Rep 160
Can anyone confirm if the Pre SCR EGT is scaled correctly for a 35d? I'm seeing some higher than expected temps.
Logs -> https://datazap.me/u/madbim/35d-7-27...ta=8-15&solo=8
2008 E90 335xi - DPs, 5" IC, MHD Stg2+, xHP Stg3, xDelete | 2013 X5 35d - DUDMD Stg1, EGR Delete
