11-07-2019, 07:45 AM | #1 |
Rep 11
Fuel Type
Probably asked before but I could't find it in a search. Just curious how many people run regular 87 octane instead of Premium 93? Specifically for me would be the X540. I'm just curious as in researching, the common thought seems to be that BMW recommends 93 for all of their vehicles but some discussions seem to say that 87 is fine and the engines have the technology to adjust for lower octane gas, obviously at a cost to performance. But if I don't need that 10 horsepower loss 99.9% of the time, what the hell if it isn't hurting anything.
I get the point that if you are worried about the price of gas you shouldn't probably purchase something that cost this much but just really curious how many people use 87, or even 89 and if they have any issues? |
11-07-2019, 08:09 AM | #2 |
Member
55
Rep 92
I run 93 Shell 90%ish of the time. If I can't find it I use 91. I personally would never run anything below the recommended 91.
Past BMWs:
2015 F82 M4 6MT/2013 535i xDrive/2005 325ci/ 2001 X5 4.4 Sport/2000 Z4/1998 528i/1995 525i 5MT/1994 318i |
11-07-2019, 08:23 AM | #3 |
Rep 5,324
Always premium. I have a few empirical data examples of some of my PCA members over the years running regular (cheap gas) in various German cars that were required to run premium. Despite having lower performance by the computer adjusting to the lower octane rating, there have been injector problems fuel pump problems, etc....
I run the best gas I can find which is Sunoco 93 in everything. |
11-07-2019, 08:34 AM | #4 |
134
Rep 326
Octane has nothing to do with the cleanliness of the fuel. Use "top tier" (like Shell or Sunoco) fuel that contains detergents and meets a certain standard to keep your engine clean. This wil prevent dirty injectors and carbon build up, which can cause detonation.
Another issue is using low octane fuel. Octane number indicates at what pressure fuel will self ignite. The twin-turbo in your X5 40i provides higher pressure before combustion then a naturally aspirated engine. Obviously you want the ignition system to determine the moment of ignition. Using low octane may cause pre-ignition, which may be noticeable but can cause problems over time for sure. Not the most scientific explanation but hope it helps people tace care of the car |
11-07-2019, 08:38 AM | #5 | |
Rep 18
Pump and injectors and overall fuel supply system can not be damaged by a lower octane fuel, only by "bad", contaminated fuel. Here is the kicker fact for you. The middle grade fuel is actually a mix of 93 and 87, that happens at the gas station. So if gas station has 91 as middle-grade (and it's OK to use according to the vehicle requirements), it's essentially 1/3 of an 87s and 2/3 of 93.
-- vlad
11-07-2019, 08:54 AM | #6 |
Rep 3,507
If you are in a situation where you only have reg 87 it won't hurt. The X5 computer will adjust timing for it. But running it long term can cause damage to the internals and specially if a knock sensor fails (I have seen this put pistons in pieces, my grandfathers caddy). Yes fuel can be tested easily to show you are not running recommended octane and warranties can be voided because of this (also read the warranty disclaimer they have one on fuel).
My question to anyone why wouldn't you run the 91 recommend??? It cannot be cost savings bc you only save "about" $5 per tank if you filled it from 0 gallons and the cost was .25 more. Say you fill out 4 times a month that is $20 a month or $240 a year at a pretty extreme calculation. I didn't buy a SAV to be cost minded or fuel efficient. It cannot be fuel mileage bc the cars knock sensors will retard the timing meaning less efficient combustion of the fuel its self more actual wet fuel going out the exhaust. So why would you not run it, unless you simply didn't have it available????
2022 M8 Comp Convertible
11-07-2019, 08:59 AM | #7 |
Rep 4,504
Drives: 2022 iX xDrive50, DGM
Nothing below 91, and BMW recommends 89 as the minimum. There are several warning notices in the Owners Manual - probably the Ethanol content is the most important recommendation (maximum 10 percent). Using anything other than the recommended fuel in a $90k+ vehicle to save a few pennies may not pass the logic test for some, but likely won't cause anything but additional maintenance issues long term, which may or may not balance out any fuel savings. However, from the manual:
NOTICE Fuel that does not comply with the minimum quality can compromise engine function or cause engine damage. There is a risk of damage to property. Do not fill with fuel that does not comply with the minimum quality. "Quality" is not defined, but could certainly be interpreted as octane rating by the manufacturer. |
11-07-2019, 09:26 AM | #9 | |
Rep 5,324
11-07-2019, 09:30 AM | #10 |
Jim
270
Rep 156
It was mentioned that the 91 octane is mixed at the pump .... It is blended at the refinery or dispersion depot as 91 octane, the same as with the 87 and 93 octane just before it is put the trucks trailer. There is no mixing at the stations. All chemicals are to be added at that point of blending prior to shipping. Samples are drawn at specific times for testing to verify quality.
Now if this is accepted by BMW or not I'm not sure, but I was told by my stealership, if you use the 91 octane once in a while due to lack of 93 octane, this is fine. But if you're in a situation where there is only 87 octane, use an octane booster at that time. But do not use 87 all the time. |
11-07-2019, 10:38 AM | #11 |
Rep 155
Drives: 23 X3 M40i 24 X3 M40i
My previous X3 went in for 45k oil change. The SA asked if everything was going good and I said gas mileage going down to try to get new spark plugs. When I picked up car they said they tested gas and I was over 10 percent ethanol and said I should watch where I buy gas. At that time I only used Shell gas and my area has the 10 percent max ethanol everywhere and summer gas formula. Needless to say they waited till next oil change for new spark plugs.
11-07-2019, 10:50 AM | #12 | |
Rep 4,504
11-07-2019, 11:24 AM | #13 |
Rep 7,488
The Shell recommendation is there because they're paying for the advertising. It's a real world example of "quid pro quo".
For example...they have renewed their "exclusive oil provider" recommendation by BMW up until the end of 2022:
11-07-2019, 11:54 AM | #15 | |
Rep 506
11-07-2019, 11:58 AM | #16 | |
Jim
270
Rep 156
In my area, premium is 93 and I only get 91 when out of my area, sorry. But I wanted to say they blend at the depot, not the station, and as ordered per the state and federal regulations. Also, the stealership told me BMW recommends (91 octane +) and not use regular. If stuck using regular, add an additive to boost the octane rating. |
11-07-2019, 01:13 PM | #17 | |
Rep 116
Drives: 2024 X5 50e LCI
I sell gasoline dispenses and 85% of the gasoline dispensers sold today are blender type equipment at the island. |
11-07-2019, 01:26 PM | #18 | |
Rep 4,504
11-07-2019, 01:26 PM | #19 |
Jim
270
Rep 156
Not sure where your at, but I just retired from the industry after 30+ years and that is not what anyone did that I knew.
We have blenders, but they did the blending prior to loading for delivery. Base stock gasoline is 74 octane and the chemicals added increased the octane to the ordered octane each load. |
11-07-2019, 01:39 PM | #20 | |
Rep 11
