      01-17-2021, 02:35 PM   #1
Shawzy44
Shawzy44's Avatar
158
Drives: 2019 BMW X5 40iX
Retrofit ACC on G05?
I reached out to "Group Buy Car Parts" as I hear they have a retrofit kit for G30.
I noticed on their video it says G05. Has anyone dealt with these guys?
https://www.facebook.com/groupbuycar...97386346950471
I am going to reach out and see if they have specific info and a parts list for the G05.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
2019 BMW 440iX M Performance Cabriolet
      01-18-2021, 10:24 AM   #2
Shawzy44
Shawzy44's Avatar
158
I am researching retrofitting "SA 5DF Active Cruise Control+Stop&Go Function"
So far my parts list is:
Radar (FRS): 66316898190
Radar Mount 1: 66316883865
Radar Mount 2: 66316883738
Radar cover: 51118737334
Lower Grill: 51117421805
Wiring Harness: 61128734045
Multi-function Steering wheel buttons: 61319483001
Diagrams:
https://www.realoem.com/bmw/enUS/sho...diagId=66_0507
https://www.realoem.com/bmw/enUS/sho...diagId=51_A197
Does anyone have any input or learnings from similar research?
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
      12-07-2022, 06:07 AM   #3
michal15qaz
Drives: E90 320i E91 325xi F10 530d
Hi.
How's the work progress? It works ?
Please, more info
      12-16-2022, 09:18 AM   #4
135iUSN
19 X5 1998 M Roadster
135iUSN's Avatar
64
Drives: 135i Alpine White / Terra
1998 BMW M Roadster  [0.00]
2009 135i  [0.00]
I’ve placed an order, waiting for shipment, yesterday update they were testing components prior to shipping.
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
      12-17-2022, 12:46 PM   #5
hodgson-p@hotmail.co.uk
Phil
41
Drives: Bmw g05
Dose this work as OE or dose it use a emulator with group buy parts ?
      12-17-2022, 04:43 PM   #6
Aloux
Drives: BMW X5 x45e
Keep us updated. If you don’t mind, take some pictures/videos during the install. I am interested by both the mechanical install and the coding. My car is under warranty so I may wait a little bit I am tempted to do the upgrade too.
      12-18-2022, 07:33 PM   #7
Shawzy44
Shawzy44's Avatar
158
Originally Posted by michal15qaz View Post
Hi.
Please, more info
I was able to have the kit installed a while ago. Works well. I believe it’s an emulator but ACC works just like OEM. Need to reprogram the radar and emulator after every I-step update though.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
      12-18-2022, 07:36 PM   #8
Shawzy44
Shawzy44's Avatar
158
There is more on the retrofit in this thread.
https://g05.bimmerpost.com/forums/sh....php?t=1655837
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
      05-20-2023, 10:26 AM   #9
Aloux
Drives: BMW X5 x45e
Hi 135iUSN were you able to go through the install? Any comments? Thanks.
      06-08-2023, 10:04 PM   #10
thepianist1
35
Drives: BMW X3 G01
Diagrams:
Shawzy44 This may sound far fetched but I think there must be a way to run the ACC software running on an emulator before installing the radar and other hardware to the car. What errors do you see when you run the emulator connected to the car without the radar?
If I can get 70% accuracy of ACC with just the camera and not the radar proven by the emulator, I will just skip spending the money and time installing the radar and just have a half working ACC
      06-08-2023, 10:20 PM   #11
TurtleBoy
TurtleBoy's Avatar
12885
Drives: 2019 X5 40i,2021 M340i
Hopefully you are just joking around and would never try running a system like that. On the hopefully very slim chance you are serious, thankfully the ACC system doesn't use the camera it uses the radar for its operation to sense the distance to the vehicle ahead.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2023.67
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      06-08-2023, 11:24 PM   #12
thepianist1
35
Drives: BMW X3 G01
I just want to test the software will work on the car before investing in all the hardware, I don't expect to run this on the road with just the camera obviously. It’s not like it’s a plug and play solution, once you connect the short range radar coding has to be done. That final step is what I want to verify first before hitting a dead end
      06-10-2023, 01:32 PM   #13
Shawzy44
Shawzy44's Avatar
158
I am not much help as I had this installed and didn't do work myself.
I do recall that when the radar isn't installed the car shows a driving assistant error related to the radar. The was cruise control is disabled when that occurred.
The radar is 100% required for ACC.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
      06-10-2023, 08:38 PM   #14
thepianist1
35
Drives: BMW X3 G01
How much did it cost you for all the parts and install? Do you have final list of all the part numbers used and which store did you go to do the install?
      06-12-2023, 04:40 AM   #15
superkrups20056
20
In his other thread he linked above he said it cost $2K for parts and $400 for labor. Comparable to my StealthHitch install, actually. Same prices.
      12-08-2023, 02:05 PM   #16
creeking
Drives: BMW X5
I just buy all the parts for my X5 with $1k, they will give me code and fsc cert for another $300 remote support. i will post photo when it finished.
I need to install all the parts myself. i dont know how to connect the wiring to driver cabin.
who knows that? tks
      12-08-2023, 04:43 PM   #17
TurtleBoy
TurtleBoy's Avatar
12885
who knows that? tks
Check this thread out for some detail. It is quite a project and looks like the person is stuck on the wiring.
https://www.bimmerfest.com/threads/a...#post-13891038
      12-24-2023, 11:15 AM   #18
Shawzy44
Shawzy44's Avatar
158
Here is a photo of the wiring and the wiring diagram I used.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
