03-11-2024, 07:30 AM | #1 |
Rep 187
Daylight savings automatic time issue
Did anyone else not have their BMW spring forward automatically? I have it on automatic time change and proper time zone.
03-11-2024, 08:32 AM | #2 |
Rep 51
I just learned you have to switch off the auto button and back on then it updates. Touch the clock on the upper right and it takes you to those settings
03-11-2024, 08:34 AM | #3 |
Rep 8,737
Drives: eVeRyOnE mAD!
both our X5 and 5 series changed automatically
had X5 for just over 3 years and 530e over 1 year and have never had to toggle anything, both iDrive 7 running 11/2023.50 |
thereef5101167.50 |
03-11-2024, 11:48 AM | #4 |
Rep 24
2024 X5 M60i with iDrive 8.5. Yesterday, without any action on my part, the time adjusted correctly. Today. however, it reverted back to standard time. I used the toggle off then on method to get it to update. Waiting to see if it again reverts to standard time.
03-11-2024, 12:02 PM | #5 |
Rep 187
Tried that and it worked…my Audis always change without me having to do anything. Thanks!
03-11-2024, 12:20 PM | #6 |
Rep 166
Drives: 2024 BMW X5 M60i
Mine was an hour behind and then when I tried to change it to Central time zone, it kept changing it back to Istanbul! I finally just changed it manually.
jpw17256.50 EscaladetoBMW10.50 |
03-11-2024, 12:29 PM | #7 |
18
Rep 33
In my case the Auto button was off and as soon as I enabled that, the time was updated
03-11-2024, 12:33 PM | #8 | |
Rep 8,737
how’s your cellular signal at home when parked? if low/spotty, it’s quite possible your vehicle may have trouble communicating with the server to update its time automatically |
03-11-2024, 12:48 PM | #9 |
Rep 804
03-11-2024, 01:27 PM | #10 | |
Rep 8,737
while DST rules are fixed (starts on 2nd Sunday in March and ends on 1st Sunday in November), I don’t think I’ve come across any clock in my lifetime that changes back and forth automatically without being connected somehow. IOW, clocks that change times automatically require some type of connection (atomic, cellular, etc) |
03-11-2024, 01:41 PM | #12 | |
Rep 804
nZtiZia4677.00 |
03-12-2024, 02:43 AM | #13 | |
Rep 1,252
Drives: 2020 Z4 M40i
03-12-2024, 06:27 AM | #14 |
Rep 192
Drives: 2024 X5 50e
I stumbled on this accidently, just toggled it on and off while saying, "Hey, let's go." Worked for me.
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
jpw17256.50 |
03-12-2024, 06:36 AM | #15 |
Rep 8,737
y’all should report this iDrive 8.5 bug having to toggle just to reset the time properly to DST even if set to AUTO. I’ve never had to toggle anything in the 3 years I’ve owned my 45e that runs on iDrive 7
barbE120.50 |
03-12-2024, 09:16 AM | #16 |
Rep 112
Drives: 2013 E92 M3
Mine would not let me select the “automatic time setting” checkbox so I had to manually adjust the clock forward by 1 hour.
Any one else unable to select the automatic time setting in Idrive? |
03-12-2024, 12:48 PM | #17 |
Rep 78
I had posted about this in another area yesterday, my M60i was having the same issue - it had the correct DST yesterday morning but when leaving work it reverted back to Standard Time.
I had to toggle the automatic time update off and back on and it corrected it. It did keep Chicago as the city - that didn't change. The M60i is on iDrive 8.5 and the M440i is on iDrive 8 - and it had no time change issues at all - updated automatically with success. |
03-12-2024, 02:22 PM | #18 | |
Rep 1,363
Rob |
03-12-2024, 04:33 PM | #20 |
13425
Rep 19,972
Never have since I got it and have crossed many. I always have to uncheck and check the box to have the time update.
thereef5101167.50 |
03-12-2024, 06:58 PM | #21 |
181
Rep 329
I don't think there's a way to report bugs... hence the reason why this software is full of them.
