      10-16-2021, 07:35 PM   #1
Minton444
Drives: 2006 525xi e60
Programming issues
I'm a disabled vet that was given this car. The CCC unit went bad so I replaced it because I couldn't afford to have it done by anyone else. Since I was doing the work myself I figured I would do a firmware update on all of my 2006 525XI e60 modules except for the CAS and now I'm having issues. I used K+DCAN cable & WINFPK 5.3.1. with the sp-daten ver 67.1. Everything showed that it completed "OK". Now I have all of these error codes and all kinds of issues. I need help to get back on the road. If I get this fixed I'm never touching this car ever again!!!!
SIM/SGM
93AD 60
SZL
9501 60
94C0 20
94AC 60
STVL/TEFA
963F 20
962C 60
STVR/TEBF
96FD 20
96BF 20
96AC 60
SFZ
9ABF 20
9AAC 60
DME/DDE
CD99 84
CDA8 84
CD94 94
2DC3 04
CDB0 04
CDA9 14
CD9F 14
CDAB 14
CDAA 14
CDAE 14
EGS
CF1B 24
CF1A 24
CF19 24
CF1E 24
CF21 34
VGSG
54C6 71
55C3 38
55D0 28
DSC
D378 A4
D36A A4
D356 A4
D355 A4
5DDF A0
5EBA E0
CAS
A0B1 28
KOMBI
A3B3 20
A3B9 20
A3AC 20
A556 20
SBSL
984C 70
9857 70
986D 70
9878 70
9891 20
9895 60
983F 20
982C 60
SBSR
98ED 70
98F8 70
9915 60
98BF 20
98AC 60
There has been many lessons learned here. One being, I did a firmware update on all of these at one time and didn't cycle the car every time I updated the firmware. I also had a battery charger attached and NOT a voltage regulator. Lastly and most importantly, I should have had an indie shop do the work but I'm broke and now I don't have a car! Will someone please help me get out of this mess.
      10-17-2021, 11:25 AM   #2
DomMuc
DomMuc's Avatar
506
Drives: G87 M2
did you switch off ignition when updating the CAS?? with ignition on you could have caused a mayor problem....
      10-17-2021, 11:28 AM   #3
Minton444
Thanks for the response. I was able to get everything fixed except szl module which keeps throwing a 94ac error. I didn't mess with the CAS!
