01-26-2021, 01:44 AM | #45 |
Registered user
78
Rep 422
Drives: G05 3.0d MSport / F23
01-26-2021, 04:06 AM | #46 |
Rep 293
It's the OEM M742 Jet black 9,5x22"front and 10,5x22" rear on Pirelli Scorpions Winter 275/35-22" front and rear.
01-26-2021, 04:11 AM | #47 |
Rep 293
Here are more pics of the set up 😊
01-26-2021, 04:31 AM | #48 |
Rep 111
looks quiet OK from the pics...I wish I had known this before that 275 for rear is also ok with OEM 22" staggered set up. I had to buy 315 Pirelli Scorpions for the rear with a lot of euros
01-26-2021, 12:29 PM | #49 |
Registered user
78
Rep 422
01-27-2021, 09:38 AM | #51 | |
PittsburghG
Rep 5
01-27-2021, 09:48 AM | #52 |
PittsburghG
Rep 5
I figured that would be the case, which is why I was going to get dedicated winter tires this time. With my prior X5's I would just replace the factory run flat tires with the Continental Extreme Contacts, and they worked ok for me. However, with the RRS the 22" rims came with the Continental Crosscontacts that were terrible. The RRS only had a few thousand miles on it, and while driving to work I slid right into a curb when going very slowly around a curve. The plaza where my office is located hadn't been plowed so the road had about 2" of snow on it, and those big A/S tires just couldn't handle it. Damaged my rim, and of course worried me about driving in the snow at all. Nothing like having a RR, and driving a VW to go skiing because the Rover was terrible in the snow due to the big tires.
01-27-2021, 01:36 PM | #53 |
Self-Deprecating Narcissist
7258
Rep 6,561
I had the full size Supercharged with 22" and it came with the same tires. They were horrible in the dry and I immediately swapped them out. I wouldn't trust those in the winter and they're definitely a three season tire not an all-season.
10-21-2021, 04:39 PM | #54 |
7258
Rep 6,561
Just a head's up to anyone still in the market... the 22" rears are out of stock in most places. The only way to find them is through certain dealers or at Porsche. I mentioned on here back in the middle of summer that there would be limited supply and I hope those who need took advantage. I suspect the wheel/tire winter combos in smaller sizes will be sold out soon so if you haven't purchased or cannot find the 22" in stock then start exploring options before you do not have any.
10-21-2021, 06:31 PM | #55 |
Rep 6,728
Unlike all-season tires that tend to be made throughout the year, most manufacturers switch between producing winter and summer tires, and they aren't produced all of the time. So, once winter is actually here and most people have already bought their winter tires, they start making summer ones for the next season...so, if they don't figure the right mix of sizes and quantities, it's not uncommon to run out of certain sizes. Because rubber gets harder as it ages, it's not good practice to have excess stuff sitting around, as if not sold in one season, they'd not be as effective the next, plus, warehousing tires until the next season just ties up money and profits, so not a great idea. IOW, get them early if you want a good selection and the freshest stock, and, look at the date codes...you don't want last year's stock.
11-10-2021, 03:46 AM | #56 |
Rep 1
so what's the deal with 22" tires? are we allowed to drive on them on winter or not?
I got few months ago X5 with 22" summer tires, and tried to get the tires for the winter. The local BMW dealer told me that I am not allowed to drive on 22" winter tire because those are not approved by BMW and I should buy the tires and rims that are smaller?!?!?!? what the is this? I never heard anything like this. I am afraid if I buy pirelli's scorpion that they will not admit the warranty if needed for any reason. |
mopaman34.00 |
11-10-2021, 02:48 PM | #57 |
Rep 6,728
Nobody, don't care whether it's a car manufacturer, or tire manufacturer, suggests it's okay to use high performance summer tires when it gets COLD out, let alone have much of any traction. A summer, high-performance tire's rubber is designed to stay stable at high speeds in hot temperatures, so it tends to be a bit harder than a winter or all-season tire. Rubber gets harder as it both ages, and when the temperature drops. So, that makes a high-performance, summer tire with usually few sipes (those are what allows it to grip on the ice and snow) almost like driving on slicks...it is both dangerous, and, IMHO, foolish, to try to use them in the winter when there may be any ice or snow, and just being that cold, with the rubber now much stiffer, can cause them to literally crack. Because they can't conform to the road surface because they're so hard, your stopping and cornering will be compromised. Now, if you're really lucky, avoid any snow or ice or emergency stop, or hard acceleration, you MIGHT get by, but all it would take is once and if you're lucky, you just ruin your tires, but might have much more serious consequences. In some places, driving with summer tires in the winter would get your vehicle impounded and a heavy fine. Not that common in the US, though, but if you're involved in any accident, the lawyers will have a field day!
Everyone also suggests that for best winter performance that you select a smaller wheel and narrower tires which cut through snow better instead of floating, and the taller sidewalls help prevent wheel and tire damage should you hit something that was hidden by that snow. Going -1, -2, or maybe -3 in rim size, if it will fit, is a good choice. |
GrussGott18113.00 |
11-10-2021, 04:30 PM | #58 | ||
18113
Rep 11,746
Drives: 2018 M4 Comp Indv
So when you say "allowed" it's less of a warranty issue (but that too) and more of a safety kill-yourself-and/or-others-and-legal-trouble issue. Given you look to be in Croatia, I can't be sure about their laws, but many EU countries (e.g., Switzerland, Germany, Austria) have legislation saying you must have severe weather tires as marked with this symbol: In Germany for example the rule of thumb is von O bis O meaning from October-Easter you must run severe weather tires in cold/snow/mountain weather regions ... and the penalties for not running winters can be severe too: * Police see your car without severe weather tires, 40-80 euro ticket * You spin out & cause traffic or inconvenience, 80+ euro ticket & points * A one-car accident = the above & you lose insurance & can't rent! * An accident with other cars: all of the above & they confiscate your vehicle Not sure how much of this applies in Croatia, but probably some ... and I can tell you for a fact that in Germany, Austria, & Switzerland they police & border patrol WILL check your tires and they target large wheel / performance cars. EDIT: a quick search turned up the rules for Croatia Winter equipment |
Flying Ace4982.50 |
11-10-2021, 05:39 PM | #59 |
Rep 710
I was in this same situation and was debating just trying to drive when the temps are above 40 and so on.. I ended up buying a winter set. It's just not worth risking you're life or anybody else's because of a couple dollars ( couple thousand )
GrussGott18113.00 |
11-10-2021, 09:25 PM | #60 | |
Rep 88
11-11-2021, 12:48 AM | #62 |
Rep 6,728
From the year or so I lived in Germany, it's my observation that they are very serious about driving. The average American driver wouldn't pass their written or practical tests, as you need far more knowledge to pass than the 60%, 20-question, multiple choice in the state where I got mine. You need almost a perfect score, and it was hundreds of questions. No excuse that you weren't aware of the rules. The driving test is lots more complete, requiring demonstration of skills beyond what some Americans never achieve. THen, their vehicle inspection is much more complete than most any I've seen in the USA. For example, when I was there, they put the vehicle on a machine that measured the braking force on each wheel for total power and balance L-R and F-R, and they ran the vehicle across a calibrated bump to check the shock absorbers for function. It's probably more sophisticated today. This was decades ago.
My boss, driving a German vehicle, with German plates, got stopped one weekend for touching the center line twice while going around a curve and received two citations...they expect you to be in control of your vehicle at all times. Another had had a few too many and was sleeping in his vehicle, but he had the key in the ignition. By law in Germany (at least at the time...don't know what is done now with keyless ignition!) if the key is in the ignition, even with the vehicle off, you're technically driving. He lost his license for a year. IOW, they take driving very seriously as well as vehicle status. |
11-11-2021, 05:31 PM | #63 | |
18113
Rep 11,746
In that scenario M+S tires aren't gonna do well (arguably even a bit dangerous!) and one is probably better off with "all weather" tires like Nokian WRs or all-season if you really wanna be a stickler ... personally in that scenario I'd skip it for sure in the US. And it should noted in Europe, even in Germany, and even von O bis O, you can drive in, say, Munich all winter long w/o M+S ... you just can't go into the mountains or anywhere with ice, snow, or below 40 temps. I wouldn't try it in Zurich though. |
11-11-2021, 06:53 PM | #64 | ||
Rep 842
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
GrussGott18113.00 |
11-11-2021, 07:09 PM | #65 |
Rep 6,728
Most winter tires are essentially useless as winter tires once the tread gets below a certain point. On Blizzaks, at least they used to literally have a different tread compound in layers, so that once they were worn a certain amount, they worked better as an all-season than a dedicated winter tire. What generally doesn't work well are dedicated high-performance summer tires when it gets cold out, which I think, was the original question. THose can be downright dangerous in the cold, whether there's snow or ice, just makes it even worse.
Yes, in the dry, the block sizes and sipes may not be able to provide the same ultimate cornering and grip or feel as a dedicated summer tire, and they may wear faster, but given those considerations, under many circumstances, they will work when it gets warmer out. I wouldn't want to take a high speed trip through Death Valley in the summer with winter tires, though! |
GrussGott18113.00 |
11-11-2021, 10:00 PM | #66 | |
Rep 710
I'm a little confused? I have winter tires for the winter. Why wouldn't they do well? |
