      12-16-2020, 01:01 PM   #1
bforbrian
bforbrian's Avatar
723
Drives: 2020 BMW X5 x40i
What tire pressures are you running on your winter setup?
I'm currently running 43 PSI on all four corners of my square set up of the following:
-20x9 +30
-265/45-20
(My OEM wheels are 22" 742Ms)
According to the computer, pressures of 42 PSI are recommended.
Would like to see what pressures everyone is running on their 21" and 22" setups, whether they are square or staggered!
      12-16-2020, 01:03 PM   #2
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
-20x9 +30
-265/45-20
I run whatever the car recommends once you set the sizes correctly. 43psi sounds ok for the rear, but too high for the front on that basis. Double check your tire setting in iDrive.
      12-16-2020, 01:13 PM   #3
bforbrian
bforbrian's Avatar
723
Even for a square setup? In the US I believe 20" OEM wheels are staggered, hence the computer instructs owners to maintain different pressures front and rear. However, there isn't an option to select identical sizes on all four corners, which is why I set the same pressure all around.
      12-16-2020, 01:22 PM   #4
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Yap, my setup is 20" square, but after-market, not BMW, rims. Here is the car setup (cold). My fronts are a bit high, been meaning to adjust.
Hm, but now that you mention it, the computer does indicate that "it will determine front wheels automatically" and I now wonder what it thinks I have on the front? Hm. Will investigate further.
GREENPUS133.00
      12-17-2020, 08:45 AM   #5
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
I've asked my dealer to excavate a formal answer from BMW regarding what the car is assuming is on the front with my settings. No answer yet (and I give it a max 20% chance of ever getting one), but in the meantime, playing with every available combination of 20" winter wheel setups in iDrive, it always recommends 33psi front and 41psi rear cold. The settings don't make any difference, at least not cold. FWIW to OP's question.
GREENPUS133.00
      12-17-2020, 09:03 AM   #6
bforbrian
bforbrian's Avatar
723
Yeah I presume it's because the computer always recognizes the 20" set up as a staggered setup. Thanks though - helpful to know.
      12-18-2020, 01:14 AM   #7
Fifthtoe
Drives: X5 M50i
According to the 2021 price guide, the 20s are a square setup (738 optional are square and 740m m50i standard are square).
      12-18-2020, 08:55 PM   #8
BHCJJS
21
Drives: '21 G05 x40i M Sport, '04 E46
What's of further interest is that the rears also change from 41psi to 43psi. I am assuming it changes based on weather, but haven't found the threshold yet for the increase to 43psi. Fronts never change though from 33psi.
'21 G05 M Sport / '03 F-250 Powerstroke / '16 GSX-R750
Past: '18 F26 X4; '09 E60 535xi
      12-18-2020, 09:38 PM   #9
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
The recommended pressure doesn't change with weather, but it does change with tire temperature (which is related to outside ambient temperature and, obviously, driving loads). As tire temps go up, actual pressure goes up and the associated recommended pressure goes up as well. This makes sense. My fronts go up in recommended temperature as they warm up as well as the rears.
      12-19-2020, 10:32 AM   #10
bforbrian
bforbrian's Avatar
723
I can confirm this. I have seen the recommended pressure for the rear change between 41 to 43 psi.
      12-19-2020, 02:31 PM   #11
Pro55
Drives: BMW X5 G05 30d
The reason you only put the rear axle in the idrive is because it then knows what you have on the front. If you put the 20 summers it gives you the staggered set up. Change it to winters and it automatically assumes a square set up.The rear axle is always the widest for the staggered set up so it knows. The only time it would be different is if you go non OEM and have some completely different set up.
      12-20-2020, 03:39 AM   #12
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Are you assuming this (that winter 20" setting configures as a square setup internally) or is there formal BMW documentation somewhere per this description? Would love to have something formal rather than guesses and conjectures.
      12-30-2020, 01:12 PM   #13
Pro55
Ive attached a snap from wheel size.com This is for Europe G05 30D . Each model gets different entry but fundamentally they are the same. As you can see the 20 wheels are staggered for summer but square for winter.
LexxM31698.50
      05-28-2021, 11:53 AM   #14
GREENPUS
Drives: 2019 BMW M5C
I know this is an old post. When I look under my Tire Pressure Monitor I don't see anything that says "recommended". It just shows me actual pressure and an option to change tires to different size. How do I get the "recommended" other than looking at the sticker on the door.
2021 X6 xDrive40i
2019 M5 Competition
2021 X6 xDrive40i M Sport
2018 Toyota RAV4 AWD
2008 Corolla S Souped Up - The Black Widow
      05-28-2021, 04:25 PM   #15
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
2021 X6 xDrive40i
Is there a chance you've configured "Other" for your tires? In that case, it doesn't know what to recommend and just assumes the pressures you've set at TPMS initialization are the right ones and monitors to those settings.
Another possibility is that your car doesn't have TPMS but rather the inertial relative tire pressure monitoring. I had originally assumed (a while back) that all G05 has TPMS in all markets, but it did come out that some markets had inertial (old-style, a la E46 for example) monitoring. I'll try to dig up the posts on this from at least a year ago. But considering you're in US, this latter theory doesn't seem likely.
GREENPUS133.00
      05-28-2021, 07:33 PM   #16
GREENPUS
Its a US built 2021 X6 with factory 22 inch wheels. Factory installed. The tire monitor is set to 22 inch. I didnt look to see what is under the "other" option. I assumed it was TPMS
2019 M5 Competition
      06-13-2021, 01:27 PM   #17
GREENPUS
LexxM3 I got the recommended tire pressure to show. The tire setting was correct. It was set to the 22 inch tires. I selected "other" and then flipped it back to 22 inch.
2019 M5 Competition
LexxM31698.50
