03-14-2022, 10:54 AM | #309 |
Rep 18
Looking great in both iterations and am curious if your old 741m setup is equipped with spacers or stock? If so, do you mind sharing the specs as I've got an MY22 AG GO5 45E on order and am going down the rabbit hole with fitment options? Thank you!
03-14-2022, 11:15 AM | #310 | |
Rep 8,698
Drives: eVeRyOnE mAD!
front specs: 21x9.5ET37 rear specs: 21x10.5ET43 |
dD_E90AW1.50 |
03-22-2022, 05:08 PM | #312 |
299
Rep 352
Installed 12/18 Spacers today. Thanks Ben r33_RGSport for all the help and fast shipping.
Pictures are at Sport height. Car has air suspension. I will take better pictures when I get it all cleaned. |
r33_RGSport12971.00 silverstar335501.50 |
03-22-2022, 05:13 PM | #313 | |
12971
Rep 18,716
Looks good.
03-27-2022, 07:27 PM | #314 |
Rep 1,340
How does it look at Loading height, trying to decide between 18mm or 20mm in the rear with 22" wheels, currently have 21".
03-27-2022, 08:20 PM | #315 | |
299
Rep 352
I have Pirellis which I think don't bulge like the Contis. |
03-28-2022, 01:35 PM | #316 | |
Rep 9,032
Thanks. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-08-2022, 09:06 PM | #319 |
Rep 1,340
04-09-2022, 06:42 AM | #320 |
Rep 747
04-09-2022, 01:39 PM | #321 | |
Rep 1,340
04-19-2022, 07:24 PM | #322 |
Rep 16
Thinking about adding wheel spacers to my new 2022 X5 M50i.
I don't think it has air suspension. It has 742M 22" wheels - which one do you suggest? 12F-15R or 15F-20R? |
r33_RGSport12971.00 |
04-19-2022, 08:32 PM | #323 |
12971
Rep 18,716
My recommendation is 12/15 for stock height and 15/20 if you are lowered.
04-19-2022, 09:02 PM | #324 |
Rep 1,340
I would highly recommend 18mm in the rear, currently have 15mm on a stock air suspension and it is not flush.
04-19-2022, 11:39 PM | #325 | |
12971
Rep 18,716
I too have G05 with 2 axle air suspension, and comfort height, 12/15 is the perfect setup. 18mm will poke out unless if your suspension is on sport or loading height.
04-20-2022, 12:31 AM | #326 |
Rep 1,200
I have air suspension and 21's with 15f/20r. I would personally go more aggressive in the rear as a heads up. My E70 is much more aggressive with 25mm adapters in the rear and I love it but my G05 with 20's is a bit too tame for my tastes. If you like things aggressive then 20mm might not do the trick as an fyi. Attached pic might not be the best angle as it looks pretty decent but I assure you that 3-5mm extra would probably be my most preferred width. Regardless it's not worth getting another set so this will stay.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
04-20-2022, 08:21 PM | #327 | ||
299
Rep 352
If you are running Pirellis 15/20 is what I suggest but it is all about the stance you like. If you want more pics I will be happy to send from different angles. I am on air suspension so the pictures are a combination of sport and loading height. I got my spacers from Ben. Give him a call he has done many X5's. |
silverstar335501.50 r33_RGSport12971.00 |
04-20-2022, 09:03 PM | #328 |
Rep 1,340
I have an air suspension with 15mm spacers in the rear and this is in comfort mode. As you can see from the picture it is not flush at all.
I recommend at least 18mm in the rear. If I were to do it again, I would do 12mm (F) - 18mm (R). |
04-21-2022, 04:47 PM | #329 |
Rep 16
Thanks for references everyone. Really helpful.
How do I even find out if I have air suspension? VIN: 5UXJU4C05N9L79123 Based on above reference photos I think 15-20 seems probably the perfect setup for semi aggressive stance. I have continential tires, not pirelli. Does air suspension makes it stick out even more or not? |
04-21-2022, 04:56 PM | #330 | ||
12971
Rep 18,716
All that I've been measuring are on Continental. Quote:
