08-21-2023, 11:19 PM | #1 |
Rep 226
Drives: 2022 BMW X5 M50i
Installed M track module in my X5M50i
M track module installation was done after lots of hiccups couple of days ago and finally the remote coding was done in my X5M50i last night ,
Didnt got enough time to play with it but i'll update my experience later with it. |
08-22-2023, 07:49 AM | #3 | |
Rep 226
Also no ACC or DA info on cluster or on HUD when sports mode is activated may be X5M owners can shed some light on this topic if that happens in X5M too. |
08-22-2023, 06:34 PM | #4 |
Rep 93
Seems your M-Track Module isn't coded properly , RPM is fully red on side
08-22-2023, 06:56 PM | #5 | |
Rep 226
But anyhow thanks for pointing out |
08-23-2023, 11:16 AM | #7 |
Rep 226
08-24-2023, 10:49 PM | #8 |
Rep 74
Drives: Bmw g05, bmw g06
I wanted to do this on mine but apparently if you have the cruise control buttons you can’t? Are you missing those options? Where’d ya get it from
08-25-2023, 06:25 AM | #9 | |
Rep 226
It was a little frustrating experience. I will update my findings and if any issue it causes to the car. |
D1038.50 |
09-01-2023, 02:41 PM | #10 |
Rep 2
Coding information that changes the RPM color of the instrument cluster.
Applies to two themes: M Instrument Cluster and M Track View. [DKOMBI4] Instrument Cluster → 3001 KI_Parameter → DZM_VARIANTE 01 : Diesel b57 engine 02 : Gasolin except b58 engine 03 : Gasolin b58 engine 04 : Gasolin s58 M (Over 7,000rpm is yellow) 05 : Gasolin s63t4 M (Over 6,700rpm is yellow) Last edited by CharlesJung; 03-31-2024 at 11:34 AM.. |
postbox1918154.50 |
09-01-2023, 02:46 PM | #11 | |
Rep 226
05 : Gasolin s63t4 M (Over 6,700rpm is yellow)? Because my X5 is coded as X5M |
09-10-2023, 12:10 PM | #12 | |
Rep 226
09-13-2023, 12:28 PM | #13 |
Rep 226
Fixed the cluster coding.
Changed 2 settings: CTR_DISP_M_SYS_TIMEOUT: nicht_aktiv HMI_VORWARNFELD_KOMBI_ENABLE: nicht_aktiv Both were set to aktiv and changed to nicht_aktiv |
01-14-2024, 03:10 AM | #14 |
Rep 95
Drives: 2020 G05 40i M-Sport 2023 330i
Would you mind posting the information of vendor please, found them on aliexpress, don’t see remote coding included
F10 M5 AlpineWhite/SakhirOrange[DCT]
01-27-2024, 11:47 AM | #16 | |
Rep 3,681
2022 G05 B58/PHEV
+ a few very old BMWs |
01-27-2024, 11:59 AM | #17 |
Rep 226
01-27-2024, 12:07 PM | #18 | |
Rep 3,681
Maybe maybe a look at both at cold start should tell the story.
2022 G05 B58/PHEV
postbox1918154.50 |
02-08-2024, 12:57 PM | #19 |
Rep 50
Hello,
I received the module to test. Fair price, quick delivery. Have a question before start the installation, the manual is not very exhaustive... where is located the plug in image #2? In the glove fuse box? Thanks. https://1drv.ms/b/s!AvGhh2aNRueOhwRI...e5233e5fvozD1p Found this: Last edited by 007bandido; 02-09-2024 at 01:04 PM.. |
02-09-2024, 06:35 PM | #20 | |
Rep 226
02-10-2024, 04:31 AM | #21 |
Rep 50
Hello,
Thanks for your help. I found the connector. Initially, I didn't understand. I have a 2020 G05 Diesel 30D fully equipped. When I opened the connector, I don't have the same slots with the same colors. For example, I don't have a cable in 32, but I have a brown cable in 25. For cable 7, I don't have the same color, mine is orange-blue. On the other hand, my 1 is red-yellow. I guess, according to the instruction manual, I have to change cable 32 for 25, cable 7 for cable 1. Correct? Cables 35 and 36 seem to be the same. For 36, yellow-white. For 35, yellow-black. https://1drv.ms/i/s!ApdyxZ3hXY5tibQZ...1Kx5Q?e=g8ZhtW https://1drv.ms/i/s!ApdyxZ3hXY5tibQY...FIl4A?e=tBdEuc Last edited by 007bandido; 02-10-2024 at 04:36 AM.. |
04-06-2024, 01:42 PM | #22 | |
Rep 12
Hey, I have exactly the same set up as you. Colors are different and no cable In ‘32’ is missing. Have you tried to connect it switching it as you mentioned above ? |
