      04-29-2024, 12:04 PM   #1
dnachmerp
Drives: bmw 335i, x5
Debadging a 3 yr old car
Hi there, I have a black 2021 x5 and wanted to debadge the s-drive/40i but i'm worried that since the car is 3 years old that i will see a difference in the paint where the badge used to be? Kinda like a ghost image of the old badge? Has anyone done this 3 or 4 years later and have not traces of the old badge?
thanks
      04-29-2024, 11:11 PM   #2
bmwsone02
bmwsone02's Avatar
61
Drives: 2019 X5
thanks
I have. 2020. Heat up the badges with a heat gun (LOW HEAT) and about 6” away and constantly moving. Use fishing line to run behind the badge. Then use a wheel eraser at low speed and do not press hard with the eraser. Let the wheel friction do the job at low speed.
Use a light amount of goof off. Then I used cleaner and clay bar in circular motion. After, wax (no need for an orbital buffer) with a clean, soft micro fiber.
I thought I took a pic of after. But didn’t. Can take one tomrrow and update. But not a trace of adhesive or any sort of indication that a badge was on.
I also measured before I removed in case I need to put it back if I sold the vehicle.
Good luck. Just take your time.
      04-29-2024, 11:29 PM   #3
dnachmerp
Cool thanks. So was there any traces of the old badge?
      04-30-2024, 12:03 AM   #4
bmwsone02
bmwsone02's Avatar
61
Drives: 2019 X5
Updated post. But no marks.
      04-30-2024, 04:10 PM   #5
Keithwand
110
Drives: 22 X5 replaced 16 X5 6/22
I Debadged my 2016 x5 Alpine white around 2018. No ghosting or any issues. Hated it on the front doors.
I had the dealer debadge my when new 2022 as well on arctic gray.
No issues.
Took off everything on the back.
