      06-14-2019, 08:47 PM   #23
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Originally Posted by Tenac View Post
Originally Posted by LexxM3 View Post
That's pretty close to my mileage :-(, although I am 40i. When was your X5 delivered?
Production Plant Spartanburg
Production Date 2018-11-27
Ok, thanks. My production was mid-late April, so pretty far away from yours — you don't drive that much, I guess :-).
That is a crazy story. Anyone else with around your production date should have it checked out preemptively.
      06-15-2019, 08:17 AM   #24
Tenac
Tenac's Avatar
4539
Drives: All
It would be interesting if anyone at all runs into this issue too.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      06-15-2019, 09:11 AM   #25
Jgc650i
Drives: 2019 X5 50i
Update, everything nice and clean no leaks. Repairs looks to have gone well. Software updated added some cool camera features my X5 did not have working before. As I back into the garage it will adjust to show how close I am to the wall when I first pull in. I can now set my home it actually shows up on the map now. All my settings stayed except the home screen, made those adjustments to back to normal for me. Not much time driving yet but will put some miles on it, so far happy with the repair.
You mention a software update. . . what version are you now on?
      06-15-2019, 09:34 AM   #26
TurtleBoy
TurtleBoy's Avatar
13223
Drives: 2019 X5 40i,2021 M340i
.48 is the latest, just had mine done on Thursday.
Tenac4538.50
      06-28-2019, 09:32 PM   #27
Tenac
Tenac's Avatar
4539
Drives: All
UPDATE; Thought I would put this update in. Been a few hundred miles since the warranty work. No issues have returned car is running great. Weather in PHX is getting hotter and still no signs of any problems.
2015 M235 Manual
gpitts247.00
TurtleBoy13222.50
      08-16-2019, 05:39 PM   #28
thrubyu
Drives: 2019 X5 5; 2018 M240; 2011 X5d
Same Issue Here @ 2,600 Miles
I am currently dealing with the exact same issue with my G05 (X5 50). I noticed a large puddle of yellow fluid on my garage floor. I purchased the vehicle at Niello BMW of Elk Grove. My production date was November 2018, Spartanburg Plant. I was just notified today by the dealer that both Inter Coolers need to be replaced. They have not said anything about replacing the Radiator. I am concerned what other internal damage this may have caused.
      08-16-2019, 06:18 PM   #29
Tenac
Tenac's Avatar
4539
Drives: All
I'm not worried about anything else or potential. The concern the engineer stated was the material the inter cooler and radiator's are made out of is much more susceptible to corrosion than on the motor/turbo side. They only replaced those as a precaution and the fluid was the failure. I did end up doing a bit more search on this and believe the fluid mixture is NOT the same as typical cooling due to the nature of turbo heat and that is what they are cooling. There is two separate cooling systems on the 50i. Your standard engine cooling and the turbo or aux cooling. The aux fluid is a completely different mixture according the engineer who I spoke too. Knowing this I have no concern over any future issues but also have a case number now to reference say Turbo failure due to overheating.... or something like that.
2015 M235 Manual
      08-17-2019, 01:12 PM   #30
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
This is such a good story with a satisfying ending. Thanks for sharing. Glad to learn that all is well.
Tenac4538.50
      02-11-2020, 09:24 AM   #31
Tenac
Tenac's Avatar
4539
Drives: All
**Update**
So dealer called me back up late last week. They have a recall regarding the work I had done on the cooling system earlier this year. I dropped it back off for them to test the coolant and check for corrosion. They found corrosion so they will be replacing all the parts they did previously and flushing the system with a solution. Sadly it will take a week or two due to the parts being ordered but good note I have a nice 7 series to drive around.
Anyone else with a 50i get the recall notice??
2015 M235 Manual
      02-11-2020, 09:44 AM   #32
sygazelle
Drives: 2014 328i M-Sport, 2019 X5 40i
Great outcome. Thanks for sharing.
Every post where they say "the part has to be shipped from Germany" makes me wonder if BMW really understand (or cares) about modern logistics. My X5 took 7 weeks to get fixed waiting for a "part to come from Germany".
Does BMW know, for example, that FedEx International PriorityŽ ships from Germany to the USA overnight to arrive the next day?
In my case, BMW paid a month rental car and paid one month of my car payment due to the wait. Wouldn't it be cheaper for them to just pay to have the part delivered via Fed Ex International Priority or any of the other international package shipping companies.
      02-11-2020, 12:10 PM   #33
DgjoX6M2016
F86, G05, E91
DgjoX6M2016's Avatar
Drives: F86 X6M
Originally Posted by rmorin1249 View Post
How in the he** is the wrong fluid put in at the assembly plant? Someone needs to investigate the plant in SC. Could be an issue with the wrong fluid but unlikely that only one vehicle was involved. Please keep us updated if you get additional info.
I agree. Wrong coolant seems damn near impossible. Weird.
      02-11-2020, 12:14 PM   #34
Tenac
Tenac's Avatar
4539
Drives: All
It comes down to anti corrosion that is added to the coolant isn't enough protection and fails during high heat. So yes wrong additive mixtures can cause problems.
2015 M235 Manual
