03-13-2024, 02:08 PM | #23 | ||
Rep 8,739
Drives: eVeRyOnE mAD!
I simply illustrated that if you grab on the red shaded area, your hand can be touching both the lock and unlock sensors simultaneously such that you can confuse the vehicle and get conflicting results **on my 45e, touching only the ribs locks the vehicle. it doesn’t unlock it |
03-13-2024, 02:59 PM | #24 | |
Rep 105
Ok, that part is a little confusing. How I took what the comfort access did was like you said, touching the ribs only locks the vehicle. The motion/proximity sensor in the handle is what unlocks it. It was the same way on another non BMW vehicle I had.
2021 X5 xDrive40i M-Sport | Phytonic Blue / Cognac
03-13-2024, 03:14 PM | #25 | |
Rep 8,739
AFAIK, the sensors in the door handles aren’t motion/proximity sensors but rather capacitance (touch) sensors. I also know the NFC sensor is located in the driver door handle of pre-LCI vehicles but dunno about LCI since those utilize UWB tech |
03-13-2024, 04:27 PM | #26 | |
Rep 154
Drives: X5 40d G05
03-13-2024, 04:28 PM | #27 | |
Rep 154
Drives: X5 40d G05
03-13-2024, 04:48 PM | #28 | |
13447
Rep 20,002
I think you are confusing a few different things. With Comfort Access folks are referring to the physical touching of the door handle. With that the vehicle unlocks when you touch the door handle to left of the ribs and it locks when you touch the ribs. With Touchless unlocking/locking enabled the vehicle will unlock as you approach it with your fob, or enabled phone for the LCI, and lock as you walk away with your fob/phone. For the key card and pre-LCI digital key you need to touch the card/phone to the handle in order for it to lock/unlock.
03-13-2024, 04:49 PM | #29 |
Rep 8,739
that’s exactly what I do, too, and I’m very specific and purposeful with my hand placement. when unlocking, fingers are towards the middle of the handle and well away from the locking ribs. when locking, I use only one finger on the ribs (usually the index)
03-13-2024, 06:20 PM | #30 |
Rep 105
No, thats not the confusing part for me. You said (**on my 45e, touching only the ribs locks the vehicle. it doesn’t lock it.) So it locks it....but doesn't lock it? Touching the ribs definitely locks it for me. It's been a long day and maybe I am just reading it wrong. as for the tech that controls the unlock, I was merely guessing. I don't know what it is either, but I don't recall having to touch the handle for it to unlock. I may have and am just forgetting, but I seem to see it unlock even before my hand is all the way inside the handle.
nZtiZia4680.00 |
03-13-2024, 06:53 PM | #31 | |
Rep 8,739
03-13-2024, 08:33 PM | #32 |
Rep 858
Drives: BMW Z4 M40i, BMW X5x40i
I do the same, but I found it is possible when in a rush to grab the handle and pull it before the sensor triggers the unlock. If the handle is pulled out even a little bit when the relay trips it won't unlock. I've learned to grab the handle and listen for the lock before pulling. Slow is fast.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
medialook104.00 |
03-13-2024, 09:09 PM | #33 |
Rep 167
Drives: 2024 BMW X5 M60i
What I find annoying is getting to my destination, exiting and closing the driver’s door and realizing the rear driver’s side won’t open as I try to retrieve my bag. I then have to open the driver’s door and unlock it, as I don’t carry my key fob and only use watch and iphone, which would take longer than opening the door and hitting “unlock.” Am I missing something here?
03-13-2024, 09:31 PM | #34 | |
Rep 8,739
we're all creatures of habit, but sometimes those habits don't gel well with technology. some may find BMW's programming quirky, but if we learn how to compromise our habits and adjust to the programming, it's much less frustrating or annoying. QUESTION: is there no longer an NFC sensor in the driver door handle in the 2024 models to put your iPhone or Apple Watch up against to lock/unlock the vehicle? i'm unclear if that sensor was removed because the 2024 models use UWB tech instead |
03-13-2024, 09:41 PM | #35 | |
Rep 167
03-13-2024, 10:14 PM | #36 | ||
Rep 129
Cityman185.50 |
03-13-2024, 10:19 PM | #37 | |
13447
Rep 20,002
03-13-2024, 10:22 PM | #38 | |
Rep 8,739
a) grab the driver’s door handle to unlock all the doors? b) hold your iPhone or Apple Watch against the driver door handle to unlock all the doors? |
Cityman185.50 |
03-13-2024, 10:24 PM | #39 |
Rep 129
The manual version of comfort access. Some people choose to not enable the "approach unlock/walk away lock" function. But even with that option disabled, you can touch the inside of the door handle to unlock or touch the ridges to lock. Just the proximity of the fob or dk+ is enough. For our lci, this feature is only on the driver and passenger handles. Pre-lci has it on all door handles.
Cityman185.50 |
03-13-2024, 10:28 PM | #41 | |
13447
Rep 20,002
03-13-2024, 10:30 PM | #42 |
Rep 129
03-13-2024, 10:34 PM | #43 |
13447
Rep 20,002
LOL I know how it works, was asking for you to explain it since what you typed did not make any sense/was not clear. Wanted to make sure people understood.
mushy_musashi133.00 |
03-13-2024, 10:40 PM | #44 | |
Rep 129
Cityman185.50 |
