06-04-2024, 03:23 PM | #1 |
Rep 107
K-Mac Camber Upper Wishbone Adjustable Bushings
Has anyone tried replacing their bushings with these instead of replacing their upper arms from those of the G05 50i? Probably similar price in the end, but possibly a bit more adjustment and keep the beefier arms?
https://k-mac-camber-kits.com/produc...adj-194516-4k/
20 ///X5MC - Tanzanite Blue II Metallic
96 SC E36 ///M3 Racecar - Alexander Calder BMW Art Car Homage Wrap 14 Porsche GT3 - PTS Arena Red Metallic Last edited by azm3; 06-04-2024 at 05:25 PM.. |
06-05-2024, 12:32 AM | #3 |
23
Rep 33
What about the original m control arms that reduce camber?They look like a good solution.Seems noone tried them either
https://www.bimmerworld.com/Suspensi...109504616.html |
azm392.50 |
06-12-2024, 01:40 PM | #4 |
Rep 107
Those ain't cheap!
96 SC E36 ///M3 Racecar - Alexander Calder BMW Art Car Homage Wrap 14 Porsche GT3 - PTS Arena Red Metallic |
06-14-2024, 04:31 AM | #6 |
Forced Induction Connoisseur
1105
Rep 860
Drives: 23 X5MC / 23 720s
Garage List 2024 G87 M2 [0.00]
2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
I'd be interested in sphericals for all the big bushings...
Oy vey, look at all these shekels
07-25-2024, 10:39 AM | #7 |
Rep 107
I just ordered a set to test with, $420 shipped. Will report back once installed...
08-01-2024, 08:51 PM | #8 |
Rep 107
Adjustable bushings arrived today and they included an extraction tool for the old bushings that says "no arm removal" :-). Will try to get installed and align tomorrow, but will likely be early next week...
GJCaesar22.50 |
08-02-2024, 02:13 PM | #10 |
Rep 8,931
Keep us posted. I fail to see how it’s possible to install that without removing the arm. With MSS you have to drop the whole strut to even access those two bolts since there isn’t any room to get a tool in there.
Alan |
08-05-2024, 08:47 AM | #11 |
DD214
322
Rep 388
08-07-2024, 09:55 AM | #12 |
Rep 107
Shop has been busy, but should have done by EOD. I am as anxious as you, lol...
08-07-2024, 06:33 PM | #13 |
Rep 107
Off to a rough start, the bushing extraction tool that came with the kit does not fit over the M upper arms. Had to shave about 8mm to get it over. Will report back shortly...
08-09-2024, 12:41 PM | #14 |
Rep 107
Spoke to K-MAC in Australia (they have really great support), and they accidentally packaged the wrong extraction tool in my kit. Once the extraction tool was modified to fit the M upper wishbone, extraction went pretty quick:
We did shave the rubber off the end of the old bushings to make it a bit easier to extract: New bushings pressed in easily and the upper arm was reinstalled, you can see the new adjustment rings on the insides of the arm between the bushing and the bolts. We also replaced the torx connecting bolts on the uppers with hex bolts to make adjustment a bit easier: Aligned with expected results: Overall, install was not terrible and would have taken about 4hrs if we did not need to modify the tool. This is definitely a much cheaper alternative to replacing the upper arms and gives a lot of room for adjustment. High quality bushings and great support from K-MAC, I'd say this kit is a win...
96 SC E36 ///M3 Racecar - Alexander Calder BMW Art Car Homage Wrap 14 Porsche GT3 - PTS Arena Red Metallic Last edited by azm3; 08-09-2024 at 07:50 PM.. |
08-09-2024, 01:54 PM | #15 |
DD214
322
Rep 388
Nice, I think I'll order this kit instead of swapping for the X5 control arms. Hopefully I don't have the same issue.
Was the wrong press tool in the correctly labeled box? Curious what I may expect. |
08-09-2024, 02:56 PM | #16 |
Rep 107
They had a different part number I guess for the kit with the bigger extraction tool. I would call or email them to confirm after you place your order:
K-Mac Sales Kevin McIntyre sales@k-mac.com +61.450.450.322 +1.888.847.9099
08-09-2024, 07:24 PM | #18 |
3360
Rep 1,937
Damn - just replaced my arms with the x5 ones. Wears way better but the aggressive look is gone, a little less sporty on the drive but maybe that’s just me.
08-14-2024, 08:59 AM | #19 | |
DD214
322
Rep 388
08-14-2024, 04:31 PM | #20 |
Rep 151
I wanted to chime in here on how amazing the customer service from K-Mac is. You call and the legend answers the phone and is always willing to answer questions and address any concerns. Highly recommend this route, and this company.
azm392.50 |
08-14-2024, 10:49 PM | #22 | |
Rep 107
Once tightened down, the nord washer on the end secures the bushing in position. Most of the adjustments were made where we thought it should be before putting the wheels back on and tossing on the rack, made the alignment quick and easy. We also replaced the torx through bolts on the top of control arms with hex bolts to make it easier to loosen and tighten with an air ratchet. It aligned exactly where I wanted it to, the truck drives on rails!
