02-19-2019, 09:39 AM | #45 | |
Rep 6,121
04-27-2019, 10:27 PM | #46 |
Rep 251
Is there any way to keep the suspension more firm/sport mode-like, without actually being in sport mode? If you have the 2-axle suspension, can I make it my low-rider?? :P
04-28-2019, 02:07 AM | #47 |
Rep 12
Hi, this is the "no air suspension" thread, therefore with "normal adaptive m-suspension" you can go sport mode and the tire pressure way. Here little helps a lot. Perhaps same effect with the air suspension .....?
With air many as you wanna go "sportier" and "lower"- with adaptive M normally the question is if it is comfortable enough. For my part M adaptive witch 20 inches is superb stiff with minimal body roll, sporty and comfortable enough. |
05-03-2019, 12:28 PM | #48 | |
Rep 72
40, M Sport Design, 2 axle air, Ind Act Steer (IAS)
So I am looking at a 40 with M sport design. This give you the adaptive M suspension. I wanted to add IAS, which in turn adds 2 axle air. When I do this, it does not warn me that the Adaptive M Suspension will be removed. If you build a 50 and you go to add comfort or dynamic options it will tell you that the Adaptive M Suspension will be removed. So, in the infinite wisdom of this board.... Can you equip a 40 with M sport design (which includes the Adaptive M Suspension) with 2 axle air, and IAS which is NOT remove the Adaptive M Suspension? |
05-03-2019, 12:36 PM | #49 | |
Rep 417
G30 540i Msport
G05 X5 xDrive40i Msport Retired '03 330i, '10 335d |
05-03-2019, 01:34 PM | #50 | ||
Rep 6,121
05-03-2019, 02:52 PM | #51 |
Rep 72
Thank you both! That makes sense as to why people say that they feel so different. I was thinking that the air spring wouldn't change the rode much as the damper was the acting the same for both set ups, but that is not the case so I will need to drive the air spring, which I doubt feels like a boat (but to each their own opinion). Thanks again!!
05-03-2019, 05:14 PM | #52 | |
Rep 4,246
