05-20-2020, 03:19 AM | #243 | |
1198
Rep 1,587
If you use idrive to flip between the modes I think it shows a graphic of each mode change, e.g. throttle response, dampening etc. I wouldnt do ambient colours next. Maybe try Video in Motion? |
yans29.00 |
05-20-2020, 05:06 AM | #244 | |
Rep 99
Thanks again. I guess we still don't have anything firmed up on the default suspension level setting? I always drive in height level 2 (level 3 being normal height). |
05-20-2020, 05:10 AM | #245 | |
Rep 99
Same with Sport Plus? |
05-20-2020, 07:56 AM | #246 | |
1198
Rep 1,587
FesPiaDefaultComfortWorldMode ComfortPlus FesComfortWorldMode1 ComfortPlus HU_MGU (3E52) FES_COMFORT_PLUS aktiv |
yans29.00 |
05-20-2020, 08:00 AM | #247 |
Rep 99
05-30-2020, 07:26 PM | #248 |
267
Rep 345
Drives: 2019 X5 40i M
Crafted Clarity Help Needed
Does anyone know if there any codes related to the crystal shifter. I installed after-market but only the P lights, not the X.
Does anyone know of a code setting that might turn it on? Thanks
2019 X5 X40iM
05-31-2020, 10:40 AM | #249 |
1053
Rep 1,952
There was another thread about retrofitting the crystal gear selector. When you look at the parts diagram there's a different part number for the control panel if you have the crystal controls. I suspect that the difference would be the hardware required to light up the X on the selector.
05-31-2020, 11:03 AM | #250 | |
267
Rep 345
2019 X5 X40iM
05-31-2020, 11:05 AM | #251 | ||
1053
Rep 1,952
05-31-2020, 11:15 AM | #252 | |||
267
Rep 345
Coded mine today and it works great!!
2019 X5 X40iM
06-02-2020, 07:50 PM | #253 |
267
Rep 345
Help with Logo
Can someone please clarify what I need to activate I order to get the M Logo to appear at the top of my display. I tried activating the Logo entry in DKombi but nothing happens. Thanks in advance.
2019 X5 X40iM
06-03-2020, 08:01 AM | #254 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Does anybody know the coding parameters to remove ALL of the iDrive GUI restrictions for when the car is in motion? For example, when the car is in motion, you can't use the keyboard to enter in a new navigation destination (or any keyboard functions in iDrive). Or, if you you want to manipulate the videos in the Drive Recorder section (play, pause, delete, etc) you can only do so when the vehicle is stopped. There are several other examples of these iDrive GUI restrictions while driving as well.
I would at least like to have the choice to operate all iDrive functions, whether the vehicle is in motion or not....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
06-10-2020, 11:16 AM | #255 | |
150
Rep 365
06-18-2020, 09:09 PM | #256 |
2019 X5 40i
115
Rep 226
+1 -- Is there a way to add Logo on the instrument cluster without the M layout ???
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
06-18-2020, 09:13 PM | #257 |
2019 X5 40i
115
Rep 226
Do we have the codes for automatic braking when backing up or while parking in front/rear if the car comes close to an object.
I think there was an old thread on this, i couldn't find that. Below codes were mentioned in that ACSM_5 1B2D a_pdc_fp aktiv I tried this, however after I coded, i got the Chassis Stabilization error on the idrive, did not revert it back yet
06-18-2020, 09:23 PM | #258 | |
Rep 2,609
06-18-2020, 09:34 PM | #259 | |
2019 X5 40i
115
Rep 226
Thanks for the thread details ...
Looks like it is still not working for US region cars with the above parameters. I thought additional coding was required to enable a menu item iDrive that would allow us to select to auto-brake or not Auto braking is a standard feature in many cars now, not sure what BMW is thinking to not add this feature for US spec car. Quote:
06-19-2020, 01:49 AM | #260 | |
1198
Rep 1,587
[1B2D] a_pdc: aktiv [01] a_pdc_fp: aktiv [01] apdc_activation: initwert [00] apdc_generation: gen_1 [01] auto_il: nicht aktiv [00] auto_pdc: aktiv [01] these codes are profile related so almost certainly not needed (my choices in idrive) : pia_default_apdc: nicht aktiv [00] pia_default_apdc_fp: nicht_aktiv [00] pia_default_auto_il: aktiv [01] pia_default_auto_pdc: aktiv [01] [3E52] ACTIVE_PDC: aktiv [01] ACTIVE_PDC_FLANKENBREMSUNG: aktiv [01] - dont use this, as needs additional hardware (brakes on side too) AUTO_PDC: aktiv [01] PDC_FLANKENSCHUTZ: aktiv [01] PDC_GENERATION: gen2 [01] PDC_SENSOR_HINTEN: 4_sensoren [01] PDC_SENSOR_VORN: 4_sensoren [01] [430A] AutoPdcAbstandSchwelleMS: StandardValue [64] AutoPdcAbstandSchwelleRR: StandardValue [96] AutoPdcAbstandSchwelleVFVR: StandardValue [3C] AutoPdcFlanken_enable: StandardValue [00] AutoPdc_enable: StandardValue [01] BrakeDistIF_enable: APDC-ON [01] ExProbThreshold_aPDC: StandardValue [66] MRA_aPDCMonitoring: StandardValue [00] [42C1] C_SperraPDC: Nr001 18-07 G005_not_PHEV G015 [01] C_Verwendung_PDC_Daten: Nr000_false [00] C_aPDC_Applikation: Nr001_not_RearAEB [01] C_aPDC_vorhanden: Nr001_vorhanden [01] |
06-19-2020, 07:07 AM | #261 | |
///M SubDriver
1837
Rep 2,784
06-19-2020, 04:45 PM | #262 |
Rep 26
G05 Coding
Hi there, anyone succeeded in adding colours to ambient light , also can anyone guide me in adding language to mgu and cluster, ive added chinese to mgu ( list ) , shows but cannot be selected. Thanks
06-20-2020, 08:38 AM | #263 | |
2019 X5 40i
115
Rep 226
Thanks .. will try the codes below and see if it works for US region...
06-21-2020, 02:47 AM | #264 |
Rep 71
Hi ifr,
I checked all the values on my car with regards to PDC and only found this entry different then to the ones provided. a_pdc_fp: nicht_aktiv [00] Does this enables auto braking for front? Thanks Jeet |
