      07-10-2020, 07:21 AM   #287
Bigtop
Drives: 2020 G05 M50i
Originally Posted by LexxM3 View Post
"Latest" is not particularly specific. Which exact version of psdzdata did you try and which exact ISTEP is now in your car? Also ESysX or Launcher Pro and which version of either. Also which version of ESys. With that info, we may (or may not) have further ideas.
Hi LexxM3
E-Sys 3.33.0 64bit
E-SysX 64bit 2.0.5.1 IspiHostAdmin 2.0.4.5 IspiHost 2.4.7.7
PSdZData_Lite_v4.21.32 which came with
ISTA4 4.19.2x
I am presuming that when I deleted the old psdzdata files replaced to the new ones it replaced the old istep files?
      07-10-2020, 07:52 AM   #288
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
Hi guys I have an M50d and I had this menu in the car. Suddenly after 2 days I picked up the car it disappeared.
I checked in esys and menu was deactivated, I activate the menu again but no luck nothing appears.
Went to Bmw just to test them, but they said it's not available for my car. LOL didn't expect other answer.
Any idea what could be?
I have only made the software update a few months later so it's not related.
Thanks
      07-11-2020, 01:48 PM   #289
Xmel`
Drives: BMW X5 G05
Thanks
Hi. I have the same model.
Write parameters that you tried to activate in e-sys and ecu.
I will check it.
      07-11-2020, 01:59 PM   #290
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
Thanks
I will check it.
Can you send me yours mgu file to compare with mine?
Do you have this menu on yours?
DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND
This was off when I read the mgu.
Don't know how it's possible to have it and then for your own it disappears.
Thanks in advance
      07-11-2020, 06:11 PM   #291
Xmel`
Drives: BMW X5 G05
Thanks
I will check it.
Thanks in advance
No. I don't have it activated.
I thought it could be on some fresh versions of software. I am on 03/2020 now. Which one do you have?
I will try to activate it and let you know if it shows. In what menu of idrive it should appear?
      07-11-2020, 08:13 PM   #292
JoseSportM
JoseSportM
JoseSportM's Avatar
414
Drives: BMW G42
Thanks
I will check it.
Thanks in advance
Car-general settings
Like in the picture
I had the 2019.70 version when I got the car.
I could chose the different mods.
Then was gone and I thought with the update 2020 could be back. But I was wrong.
Anyone with this menu in the car M50d or M50i can check the mgu and post here?
Thanks
      07-13-2020, 02:49 PM   #293
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
Originally Posted by anuj452 View Post
Thanks ifr
I compared the codes and found below codes were different
ACSM5 -- [1B2D]
a_pdc: aktiv [01] -- Default : Initwert [00]
a_pdc_fp: aktiv [01] -- Default : Initwert [00]
HU_MGU -- [3E52]
ACTIVE_PDC: aktiv [01] -- Default : nicht aktiv [00]
After I made the changes, I do see the option in iDrive for "Active PDC with braking intervention" and I was able to activate through iDrive
Will have to test if this works as expected
Note : I did get some error messages on iDrive while coding, Parking Assistant malfunction, Driving assistance reduced
I was able to verify that the Automatic Parallel parking worked perfectly fine after the coding updates
Thanks ifr
ACSM5 -- [1B2D]
HU_MGU -- [3E52]
After I made the changes, I do see the option in iDrive for "Active PDC with braking intervention" and I was able to activate through idrive
When I coded this it went through fine but then my auto parking stopped working. Has anyone else had this issue? After I change the codes back my auto parking work fine once again.
2019 X5 X40iM
      07-14-2020, 06:39 AM   #294
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Will have to try it, never use my auto parking - are you talking about the auto parallel/perpendicular parking or the auto backup after you drive forward for a bit?
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      07-14-2020, 07:36 AM   #295
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Auto backup works fine. It's the auto park that stops recognizing available spaces.
2019 X5 X40iM
      07-14-2020, 04:29 PM   #296
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Update
I retried the codes and then let the car reset and everything now works fine. Changing the three files should work but make sure you reset the car after the process before trying
2019 X5 X40iM
      07-17-2020, 06:50 PM   #297
Bigtop
My car updated to IDrive Version 11/2019.70
Default Adaptive, Delete Warnings, and some other settings were lost. Interestingly, the Alpine dash was not deleted.
I have:
E-Sys 3.33.0 64bit
ISTA4 4.19.2x
I can read and code
<cafd id="00007083" name="BDC_BODY3" series="S18A">
<!--3075 LceMaster-->
But not <cafd id="000044ED" name="BDC_BODY3" or <cafd id="00003E52" name="HU_MGU" It could not read the coding data
What version of the psdzdatalite file should I use to match the 11/2019.70 update?
Thanks
      07-18-2020, 12:21 AM   #298
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
I have:
E-Sys 3.33.0 64bit
ISTA4 4.19.2x
I can read and code
Thanks
Just get the latest. 4.24.13.
That'll see you through to istep 07/2020, but you'll probably need an esysx update at some point. You get one update free so I'd wait until to u really need it.
      07-18-2020, 08:03 PM   #299
Bigtop
Thank you Sir.
      07-27-2020, 12:21 AM   #300
konicax
Drives: BMW X5 G05
Originally Posted by homerrr View Post
I find it super valuable, frequent highways with lower speedlimit when going near towns, I'm glad to have it coded
It's a quite lengthy and complicated list. I have an excel sheet with it. If you pm me your email address I'll send it to you. You'll need esys.
Trying to code for my new G05, and really appreciate if you can share the instruction of eSLA function via konicax@gmail.com.
Thanks!
      08-14-2020, 04:52 PM   #301
Pumxee
Pumxee's Avatar
104
Drives: BMW X6
Can you code with these programs if you have a Mac?
      08-14-2020, 04:58 PM   #302
mandomedic122
Drives: BMW 2019 X5M G05, Mini 2016 S
Esys and EsysX are only compatible on Windows Operating Systems. If you have boot camp installed with windows OS working properly you can use it.
Armando
      08-14-2020, 05:09 PM   #303
ifr
ifr's Avatar
United Kingdom
1198
I use VMware fusion and/or bootcamp with esysx and/or launcher pro. Works great
      08-17-2020, 03:00 PM   #304
Curamrda
Curamrda's Avatar
Drives: F13
Any ideas how to code - to remember Inteligent safety settings? Its really annoying to hold it everytime after start to disable it
      08-31-2020, 08:50 AM   #305
mbarac
Romania
Drives: GO5 xDRIVE
Originally Posted by jokinawa View Post
Hi All,
I have developed some cheat codes for my G07 which should work for G05 for the most part.
If someone is willing to test and get back to me that would be great.
Here is a link to the post.
[CODING] G07 E-Sys Cheat Codes https://g07.bimmerpost.com/forums/sh....php?t=1636904
And a link to the cheat codes:
https://github.com/packetpilot/bmw-f...s/jokinawa.xml
I am still working on them and will have some updates soon. Cheers!
jokinawa
Hi,
For Alpina dash coding
... with psdz data full 4.24.30 istep version 20.07.535 worked !
... with psdz data full 4.25.12 istep version 20.07.545 NOT work !
Do you have some walkarond for this problem ?
Marius
      09-01-2020, 01:29 PM   #306
mbarac
Romania
Drives: GO5 xDRIVE
Originally Posted by mbarac View Post
jokinawa
Hi,
Marius
SOLVED !!
BIMMERCODE APP coded Alpina Dash on my iStep level.
Thank you !!
      09-12-2020, 09:51 PM   #307
juhcobywankenobi
Drives: 2019 BMW 330i
2019 BMW 330i  [0.00]
Hey Xmel` did you ever get this working? I just coded it for my G20 and I have 03/2020 software. It required one more configuration item in the HU_MGU:
DISPLAY_CONFIGURABILITY_ENGINE_SOUND -> activ
The last item for me was disabled, once I enabled it, then it started working.
      09-14-2020, 03:55 PM   #308
Xmel`
Drives: BMW X5 G05
No. I think it works only for benzine cars. I have diesel.
