06-17-2022, 05:31 PM | #353 |
299
Rep 352
Decided to go 25 in the rear and moved the 18 to the front. Rear is perfect for my taste, the front could have easily taken a 20 mm spacer but I am not going to buy another set for 2mm. The 12mm ones I had in the front will go for sale.
r33_RGSport12976.50 aug0211167.50 |
06-27-2022, 11:28 PM | #354 |
Rep 205
Has anyone noticed any increased rock chips due to these spacers? The front spacers on my f80 m3 caused all sorts of chips to my rear fenders but I suspect that was due to the flares and width.
r33_RGSport12976.50 |
06-28-2022, 10:29 AM | #355 | |
12977
Rep 18,719
I have ran aggressive setup on all my cars and I don't have problem with rock chips to rear fender. I guess LA road is bad, yet clean of gravels.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
07-16-2022, 11:14 PM | #356 |
Rep 23
what is the best set up for a non air suspension 40i non sports package on 20' stock rims
If I use these spacers, I'd need a new set of bolts? Thanks |
07-16-2022, 11:28 PM | #357 |
Rep 6,824
You want your bolts to be inserted into the hubs far enough to provide the designed support, so if you put in a spacer, you want a bolt that much longer.
Wheels clearing while stopped and full lock has no direct relationship to what might happen if you were at speed, in a turn, and hit a significant bump. With the wheel sticking out further, it is to be expected that you might end up with more stone chips from the wheels throwing things, mostly when turning. |
07-17-2022, 09:15 AM | #358 | |
12977
Rep 18,719
Let me know if you want to swing by to my shop next week.
07-18-2022, 02:36 PM | #359 | |
Rep 23
08-10-2022, 11:18 PM | #360 |
Rep 276
r33_RGSport What do you recommend for a 23 X5 M50i with 742M wheels? It has DHP. I'm looking for mainly flush, not aggressive, however. Thanks!
08-11-2022, 10:59 AM | #361 | |
12977
Rep 18,719
15/20 if you are lowered.
08-11-2022, 11:53 PM | #362 |
Rep 276
08-12-2022, 10:51 AM | #363 | |
12977
Rep 18,719
I need to know what are the wheel and tire sizes.
08-23-2022, 03:33 PM | #364 | |
Rep 104
I have the same alloys - but just wondered will there be any issues down the line. Do you have any pics with it being on load level? I assume you have air suspension
BMW X5 30d M Sport
08-24-2022, 09:04 PM | #365 | ||
299
Rep 352
I am on air suspension. Here is one at loading height. |
08-30-2022, 07:09 AM | #366 |
Rep 74
This may be a stupid question, but is the spacer visible when mounted with the 742s? The reason I ask is that I see that there are both black and silver available, and I'd like to know if it even matters.
Also, I was dead set on a 12/15mm setup, but now I'm leaning towards a 15/20mm, because I like the look better. Will this look funny, if I do not lower the car? It seems that many people lower it when using this size option. Thanks in advance! |
Eyezlee36.00 |
08-30-2022, 08:36 AM | #367 | |
12977
Rep 18,719
Unless if you have Carbon Ceramic Brake, which are not available on BMW SUV's. Another thing, Black anodizing tends to fade if not treated correctly. I've seen some that had chemical reactions against wheel cleaners.
freezerdoctor69.50 |
08-30-2022, 09:04 AM | #368 | |
Rep 74
08-30-2022, 11:32 AM | #369 |
Rep 165
Anyone have any issues with the wider stance in terms of tire wear or alignment specs being off after installing the spacers? Saw in the pro/con thread that some people were saying that tires wore uneven, etc. I was considering just the 12/15mm ones doesnt seem like much to put the alignment off or cause excessive tire wear.
08-30-2022, 07:57 PM | #370 | |
12977
Rep 18,719
Uneven wear can be off alignment from beginning or tire pressure. I never have problem with my cars with spacers or aftermarket wheels that are same spec as stock wheels with spacers.
S68 X5MC270.00 |
08-30-2022, 08:21 PM | #371 |
Rep 165
09-01-2022, 12:25 PM | #372 |
Rep 2,028
Just got 15mm for the front and 20mm from r33_RGSport
Got them installed today. I think looks really good. Very happy!! Thanks Ben Here are before and after of of front and rear wheels. The angle of picture is not exactly same. |
r33_RGSport12976.50 AECDY299.00 |
10-03-2022, 08:30 PM | #374 | |
DD214
270
Rep 283
I'll throw some pictures up when I install to help the thread as well. |
