08-28-2022, 12:40 AM | #45 |
Rep 3,685
The issue is more than just the charge time. Imagine even if today, we have tech to charge a 100kWh in 5 min, equilateral to fill up a tank of gas. the power deliver needs to be 1200kW for the entire SOC. I think we are averaging to 85kW now. To charge my 85D from empty to full will take 1hr+
But my point is, if I use one tank of gas in a year. If these one tank is spread out to top of when my 32 miles EV isn’t enough, it really means 31 mile of EV is very good my most of my driving, I just need a few more miles per trip. if I have 250 miles of range, I will not need the ice. The other extreme is that one tank is one long trip, ~400 miles. I would say for that road trip, I will deal with the EV charging, mostly one over night chsnge with L2 at destination will do. Really I am not against EV or PHEV, I have one. 45e is a good learning curve. 2 months in, I realize who is this really for. And more importantly who it isn’t for. Last edited by eelnoraa; 08-28-2022 at 12:59 AM.. |
08-28-2022, 01:11 AM | #46 |
Rep 6,838
High capacity CCS (or Tesla supercharging) is a major load impact on the power distribution network. My dealer wouldn't install one because he would have had to upgrade his entire power system to support one, and it wasn't a reasonable cost:benefit deal.
CCS units can range from 25-350K today, with most tending to be in the 50K range. It's an expensive DC power supply that will need some significant cooling capability increasing the power needs overall. A really good DC power supply might be in the 95% range, so to get 350K out, that would require 368K in, not counting what it might take to cool the thing. That's a lot of current to be moved. Large battery capacity is pretty heavy today. The medium sized battery in the 45e combined with the ICE isn't bad when you compare it to say a Tesla Model X, which is within a few hundred pounds of the BMW. So, for a larger range EV, instead of carrying around a large battery alone, you're carrying a smaller battery that you'll likely fully utilize on a daily basis, and an engine that is quick and easy to feed when the time comes...so not a huge penalty except for maybe the additional complexity. But, we've been making ICE based transportation for ages, and it's pretty reliable. For me, the 45e is a good solution until the infrastructure gets built out to make a BEV or FCV a viable choice. Mostly EV operations and the freedom of going pretty much anywhere anytime with the 'backup' ICE. |
08-28-2022, 04:39 AM | #47 | |
Rep 89
08-28-2022, 06:48 AM | #48 | |
Rep 65
08-28-2022, 09:02 AM | #49 |
Rep 483
We traded our 45e in last month, but while we had it was not uncommon for us to get 40-45 miles without the AC/Heat on during the spring, summer and fall months. With the AC on it was about 33 and 30 with the heat on. This was 30 percent city roads with lots of lights and 70 percent at 50 mph with some lights. Granted this was me trying to drive it so I would get every bit out of it. So driving habits has a lot to do with it.
We had about 26k miles on it before we sold it. Hope it helps.
Currently: 2024 iX xDrive50 & 2022 X7 M50i
In the rear view mirror: 94 325is/07 528i/08 X5 3.0/08 328i Conv/11 X5 35i Prem/12 X5 35d/12 335i Conv/15 328d/15 328GT/15 X3 28d #1/15 X3 28d #2/16 X3 35i/16 X5M/16 M4 Conv/17 330e/21 X5 45e - Arctic Grey/21 X5 45e - Alpine White /21 330e Xdrive/I4 e35 |
08-28-2022, 10:15 AM | #50 | |
Rep 213
Could explain what you mean by "more beneficial tire rotation"? It did not factor that in.
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
08-28-2022, 10:35 AM | #51 |
Rep 8,736
Drives: eVeRyOnE mAD!
preferred tire rotation for square tire FWD/AWD moves the rear tires to the front and the front tires to the rear whereas staggered tires only allow for side to side rotation on the same axle
08-28-2022, 10:38 AM | #52 |
Rep 213
Is that because the 21s+ use different size tires front vs back while 20s use the same size? I didn't realize that.
08-28-2022, 10:50 AM | #53 | |
Rep 1,340
08-28-2022, 10:56 AM | #54 | ||
Rep 483
silverstar335501.50 |
08-28-2022, 01:39 PM | #56 |
Rep 3,685
Rotation get more complicated with summer tires. Most are either directional or inside/outside specific. All my other bmw with summer are like that. So for side to side rotation, I need to take the tire off the wheel and swap side to side.
08-28-2022, 02:57 PM | #57 |
Rep 65
Exactly...or NOT and hope that your alignment is dialed in. This is by no means a boast as some would scream, "this guy doesn't maintain his dream car very well!" We will see how the first 5K miles go, but that will be this Spring after the winter shoes come off...and it will be a square set up that can only go front to back as they are directional and asymmetrical.
08-28-2022, 03:19 PM | #58 |
Rep 3,685
Tire rotation should not impact or affected by alignment, but in mount/remount tires is such a hassle. In my ownership, I have only done tire swap rotation once because BMW’s factory camber is too negative on the rear. The tire wear is extreme inside bias. Once I learned, I zero out rear camber and I just don’t do rotation for my stagger setup bmw anymore.
But then the main reason for me to run zero rear camber is because I hate factory under steer geometry setup.m. Add stagger, our cars under steering severely. While not to the same level as FWD car, but once you experience what neutral steering feel, you will never go back |
08-28-2022, 04:21 PM | #59 |
Rep 3,685
So I run my battery already empty yesterday. The charging stat show car took in 19kWh from 3% to 100%. This is well above the 17kWh that we are supposed to get. This may explain why getting 31 mile EPA is east.
But my question is, do we really get usage of 19 instead of 17? Oh is is more of summer behavior? |
08-28-2022, 04:24 PM | #60 | |
Rep 8,736
08-28-2022, 04:28 PM | #62 | |
Rep 8,736
https://www.caranddriver.com/feature...arging-losses/ |
08-28-2022, 08:04 PM | #63 |
Rep 6,838
A couple of things:
- converting ACV to DCV is never without its losses in the power supply. The EVSE is supplying ACV, and the batteries need DCV (that power supply is IN the vehicle). Expect about a 5% loss just from that conversion when using level 2, more when using a level1 EVSE. - both the power supply and the batteries will heat up during charging, so the vehicle will be 'wasting' some energy to keep things cool, more so in the summer and after a long use versus say recharging during off-peak time after the vehicle has had a chance to cool off by itself without using the on-board cooling. |
08-28-2022, 08:22 PM | #64 |
Metal Mover
115
Rep 240
Drives: Demo Car
Will be doing 56/90 testing soon (ala TeslaBjørn)
Stay tuned! |
08-28-2022, 08:25 PM | #65 | |
Rep 72
08-28-2022, 08:28 PM | #66 | |
Metal Mover
115
Rep 240
Drives: Demo Car
I can say the steering in the MSport doesn’t seem to have that center dead spot that annoyed me to no end on the xLine. |
