01-06-2024, 07:54 PM | #1 |
Rep 10
Another 22" Tire Question
Hello,
I have a '21 X5 XDrive40i with the MSport package, brakes, and 22" wheels. I just bought it used with low miles and really like the look but not a fan of the summer tires. Where I live it does get cold so that also isn't great for the summer tires during that time either. However, it rarely ever snows (every few years) and rarely is there ice either. That being said for me due to weather and also use, summer tires are not the best choice. I prefer all-season tires as they tend to work best. I am not a fan of Pirelli tires in general and would something else. I found Continental Extreme Contact DWS 06 Plus tires in a plus size I think may work. The sizes are 275/40/22 and 315/35/22. Looking at the specs they are just a little larger in circumference, but the size is nearly identical between the 2 at 30.7' dia. front and rear. Has anyone run this size and have any pictures? Thoughts on the Continentals? I ran a much earlier set of DWS tires a long time ago on another car and they were pretty good but much less sidewall and treadwear on those older ones was not very good. I know some will say to look at a separate set of 20" wheels for winter but due to the mild winter other than getting in the 30's, and occasionally colder, it just doesn't seem worth it to buy a complete separate set of wheels. I did dig through a bunch of threads and didn't see much mentioned about the Continental's or those sizes. If I missed it, I apologize. |
01-06-2024, 08:20 PM | #2 |
Rep 1,121
I don't know the answer but I'm curious if it would rub at all with the extra sidewall.
It would obviously throw off the speedometer, so that would have to be dealt with, not sure if that's something bimmercode or other programs can do? |
01-07-2024, 09:47 AM | #3 | |
Rep 1,156
Drives: 2022 x5 40!
01-07-2024, 12:59 PM | #5 |
Rep 1,207
DWS is a good tire and I like them. However I’d buy Pirellis in all-season and the proper OEM size. There’s always a chance that non OEM sizes will void the powertrain warranty. Also www.calculator.net is helpful
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
01-07-2024, 03:46 PM | #6 |
Rep 10
Thanks for the responses.
I am still considering 20's but if I do I need to make sure I get the correct wheels that will fit over my MSport brakes. While the car does have the MSport package, and I do like the look of the 22's, I do agree there is much more of an inherit risk of nails, etc. I did get lucky and did not get run flat tires and will keep it that way. Ran those before on other cars and always switched them out when putting on new tires. Just not a fan of the ride. As for the warranty, that is a good point. While it is a grey area BMW could sure make it a miserable ordeal to get warranty work done should anything related come up, especially anything with the XDrive system. I'll keep mulling it over but may just go with 20's and be done with it. I believe it is the 740M wheels I need if I am correct. They will work with the MSport calipers. |
01-07-2024, 05:48 PM | #7 |
Rep 1,121
Uh, what? These are slightly oversized tires, not big heavy ass mud tires. There is no conceivable way that they could deny a powertrain warranty claim over slightly larger tires.
01-07-2024, 06:30 PM | #8 |
Rep 6,911
The biggest thing is whether the rolling diameter between the two axles is close enough, and if they do not impact anything while potentially at full lock while hitting a bump at speed.
Some living in Europe have reported problems with their warranty when fitting even non-BMW approved tires on their vehicle let alone a non-stock size. The law is a bit more flexible in the States, as to deny warranty work, they'd have to prove the 'mod' you performed was the cause of it. |
01-07-2024, 08:18 PM | #9 |
Rep 1,156
Drives: 2022 x5 40!
DWS tires look and ride pretty nice when new but within 2 to 5000 miles they sound like a washing machine thump thump, thump, thump, thump until they warm up. They get flat spots very quickly I don’t recommend them. I had them on a Vw made them replace them twice. Finally I took a refund and bought something else.
01-07-2024, 08:48 PM | #10 | |
Rep 8,830
Drives: eVeRyOnE mAD!
you even have some tire shops that won’t mount non-OEM tire sizes to save the customer from potential future headaches with BMW dealerships |
LDT1599.50 |
01-08-2024, 11:25 PM | #11 |
Rep 208
These are very good tires. They are close enough in diameter to be technically ok and people running such upsized setup have not reported any issues. However, it is likely that if and when there are issues with the transfer case (which is sort of inevitable regardless of the tires), BMW will likely or possibly deny warranty. Its a risky proposition. These transfer cases are fragile and very expensive. I would not hand BMW a free pass in replacement of something they should have done better on. I would stick with OEM sizes.
01-13-2024, 12:23 PM | #13 |
Rep 10
I have gone down that road with warranty issue once a long time ago in the past. Yes, they have to prove the item did cause the issue to deny it but what will happen is this. they will deny it if they feel like it and then make you get a lawyer to fight their lawyer(s) to win the case. In the end you'll shell out to ton of money that you may or may not get all of it back. They know this and why they don't care.
In the end, thinking about it more, I'll either just find a set of the Pirelli All Seasons or get 20" wheels and then all seasons for those. |
