12-13-2020, 02:02 AM | #199 | ||
1169
Rep 1,780
12-13-2020, 03:19 AM | #200 | |||
Rep 2,420
And I tried this morning, in climate rules steering wheel heating is gone. Seat heating still works. |
12-14-2020, 09:54 AM | #202 |
Rep 30
12-15-2020, 03:13 PM | #205 |
Driver
163
Rep 447
Oooh! I just had my car tell me that 07/2020.80 is available for me to download. I wonder what’s changed between .54 and .80? Still annoying that they don’t release the 11/2020 OTA.
12-15-2020, 05:54 PM | #206 |
Rep 2,610
Maybe don't be too annoyed. With the exception of opportunity to code and test unreleased driver assist features, the reports of 11/2020.xx so far seem to be more focused on feature removals and than anything usefully (and working) new.
12-16-2020, 02:15 AM | #207 | |
1200
Rep 1,587
Only real change seems to be a fix for a camera switch issue: https://static.nhtsa.gov/odi/rcl/202...0V598-0733.pdf The G05 isn't mentioned as impacted, but there is a programming update for ICAM. WRT BMW pushing current release software OTA - be careful what you wish for and take a look at the 'bricked car from OTA update' threads. There would be more threads like those without in-field testing at dealers, and RSU pilot. |
12-16-2020, 07:58 AM | #208 | ||
Rep 2,420
The active ambient light in the door handles now show a small white line when the trunk is open. My kids were taking stuf out when I was still in the car and it was not switched off First tought it was a defect. But it disappeared once the trunk was closed. And when opening a door with de car on it blinks red. But it already did that before. Not really a substantial upgrade. |
12-18-2020, 09:49 PM | #209 |
1169
Rep 1,780
anyone else having problems with carplay and 07/2020? ever since I got this update, the phone won't stay paired with carplay. I'll get into the vehicle and it'll say 'connect new device'. I've had to reboot idrive (that'll sometimes work), or remove my phone and re-pair my phone.
It's an iphone x running 14.3; Even when I re-pair it, sometimes the phone/music will disconnect as soon as the engine start/stop button is pushed at the end of a trip. I'm sure this is just because me not correctly having paired it properly. Anyone else have a sequence of steps to ensure this works every time? |
12-19-2020, 02:53 PM | #211 |
13548
Rep 20,188
Mine took about the same. Actually for the last one I never did know if the download from the phone finished or if it just went off the download that the vehicle did.
12-19-2020, 03:11 PM | #212 |
Rep 6,881
Android or iOS phone?
FOr an android phone, you only need to be connected via WiFi, but for iOS, they want both BT and WiFi. My iOS phone transferred the file in maybe 10-minutes or less. |
12-19-2020, 05:12 PM | #213 |
Driver
163
Rep 447
Ok, weird. I am connected via both, but it is stuck at 87%. One of those random BMW things I guess. The phone says it is uploading and the car says... well, nothing except “preparing”. I’m sure it will finish one day.
12-19-2020, 09:34 PM | #214 | |
1169
Rep 1,780
07/2020 takes a lot longer to initially recognize your phone (if you haven't driven overnight or in a couple of days) than previous iDrive versions. I just got in today and went for a short trip. at first it gave me the usual prompt to 'connect a new device' but within 30 seconds it recognized my phone and started to play the last song I played on my playlist. a subsequent trip recognized the phone immediately and worked as before (hopefully it stays that way). The only thing I did different was in the overnight period between drives, I closed all the apps, restarted my phone, and disabled auto-joining the bmw wifi ssid. |
12-20-2020, 12:30 PM | #216 | |
PANIC!
485
Rep 823
However, and this may be purely coincidental, but I usually stream Apple Music via CarPlay nonstop. I turned it off one day to listen to ESPN on XM and the percentages started going up a lot. In fact, it finished within 20 minutes of driving that day (9% to complete) whereas before I couldn’t even see it move. As soon as I got home, I put it in park and did the update, which took 20 minutes while the car was off and me sitting inside. So, maybe the upload is reduced while CarPlay is actively streaming? |
12-24-2020, 02:47 PM | #217 |
1169
Rep 1,780
FYI
The "Pause/ Un-pause" gesture now fully works with CarPlay. Previously, it would just work for Pause, but then you had to manually unpause it. Not anymore, they fixed it. |
12-25-2020, 01:21 PM | #218 |
Rep 229
So mine has transferred to the car but it's been weeks and I'm still waiting for it to be ready for install. I keep checking every few days but still nothing. The car is used frequently and therefore can see it relating to the battery being below 80%. Other face similar issue and any idea how to trigger this?
12-25-2020, 02:20 PM | #219 | |
1169
Rep 1,780
01-01-2021, 09:09 AM | #220 | |
Driver
163
Rep 447
thereef5101169.00 AshD101.50 |
