      01-15-2021, 05:32 PM   #1
lexieke
Belgium
70
Drives: X5
Home Assistant supports BMW
So Home Assistant (https://www.home-assistant.io/) now also supports Connected Drive, specific docs can be found here: https://www.home-assistant.io/integr...nnected_drive/
I've set it up to create some automations (do X when the car gets connected to power, do Y when car enters a zone,...)
Anyone already played with this? Any good suggestions on usage?
Appreciate 3
LexxM31698.50
volodp196.50
      01-15-2021, 05:51 PM   #2
badcowboy
badcowboy's Avatar
Drives: BMW X5 45e
I am using home assistant to show the status of charging, range and fuel level of my x45e (basically to let me know if I can make it to the store without filling up or charging up first). It is also giving me alerts through Apple's Home app when the door is locked and unlocked.
aMIC31.00
      01-16-2021, 09:13 AM   #3
lexieke
Belgium
70
Drives: X5
Currently trying to create an automation based on the location of the car but it's not checking frequently enough to see where it is
      01-21-2021, 07:20 AM   #4
Flippy_00
Belgium
44
Drives: 2020 G05 45e
My current implementation.
HA is running on a wall-mounted tablet in the kitchen.
Most important is the button to preheat the car, as my wife is too lazy to charge her BMW displaykey...
As you can see, i have no frontend UI skills
Appreciate 4
volodp196.50
lexieke70.00
aMIC31.00
      01-25-2021, 02:43 PM   #5
lexieke
Belgium
70
Drives: X5
Thanks for sharing, looks awesome!
I'm now trying to do automations based on location but the time interval appears too big - did you try anything with that?
      02-03-2023, 01:33 PM   #6
aMIC
Drives: BMW 325 XIT , X5 45e
How do you configure Home Assistant for 'BMW Connected Drive"?
I tried to add it as new integration to HomeAssistant 2023.2.1 and I used as the user name and password as used for myBMW app, but it returns a fail to connect error message
As region I selected 'north_america'.
Do I need to enable this 3rd party remote access somewhere?
      02-03-2023, 03:05 PM   #7
AbleDanger
AbleDanger's Avatar
Drives: 2023 X5 X45e
2023 BMW X5 45e  [10.00]
I think I ran into that same issue when they switched it from configuring in the config files to the UI component. FWIW, I think it eventually worked. Right now my integration is showing 'unknown' so it's possible there's an issue on BMW's side.
      02-05-2023, 09:27 PM   #8
aMIC
It was a silly password typo issue.
Confirmed to work with Home Assistant 2023.2.2
      02-05-2023, 11:11 PM   #9
AbleDanger
AbleDanger's Avatar
Ah! At least it's an easy fix. I know there was something odd when they first changed the config method, but I can't remember what it was. It's working now though, so hopefully I never have to go back and futz with it again.
aMIC31.00
      02-10-2023, 06:29 AM   #10
Tylast
14
Drives: X5 45e (2023)
I've set up an automation with HA to auto close my garage if I forgot & to turn on my sidewalk lights when I get home at night. I just wish the the BMW Connected Drive integration supported X45e pre-conditioning.
aMIC31.00
