      07-10-2024, 03:09 PM   #265
hodgson-p@hotmail.co.uk
Phil
46
Drives: Bmw g05
Originally Posted by ultragamma View Post
That’s a vent hole. But I don’t think your condensation comes from there. Maybe do the air tight test to be sure? Use a hairdryer blowing cold air into the vent holes and see where the leak is.
I have a set of these and the water was getting in around where you plug the wires in at the point where that meet the casing
      07-11-2024, 02:06 PM   #266
Alan l.
Alan l.'s Avatar
5682
Drives: 2020 F95 X5M Competition
Another option to water seal it is to spray the entire back side of the lights with a product called flex seal. since its sprayed on you can get even coverage throughout. If that doesn't work then nothing will.
      07-12-2024, 11:44 AM   #267
ultragamma
Drives: BMW x5
Any chance of adding a rubber o ring on it? You should be able to get it in any hardware store. Try get silicone instead of rubber, but rubber works as well.
      07-16-2024, 02:39 AM   #268
sengoekhan
Drives: BMW X5 G05 3.0d
Hello
I find a solution that allows oem lci tail lights to older g05. Its a adapter to use and must coding by enet. Has anyone use this adapter? Sorry for my bad english.
https://carsystems.com.ua/2024/03/26...easy-facelift/
      07-17-2024, 02:22 AM   #269
ipayincash
ipayincash's Avatar
Drives: F95 comp
Originally Posted by Alan l. View Post
Looks like BayOptics still selling lights i already told them didn't work on US spec X5s. I believe i was the first one that ordered from them and ended up sending them back for a full refund. Not only did my driver side outer light not fit at all with a massive gap they also did not light up correctly.
That’s insane that they’re still selling these…. What kind of business model is that
Turbo Spoolies Addict!!!
      07-17-2024, 02:30 AM   #270
ipayincash
ipayincash's Avatar
Drives: F95 comp
Originally Posted by PhuX99 View Post
So I just got these installed and so far the fitment is horrible but I can modify them to make them fit that isn’t an issue. I’m more concerned about the startup and shutdown animation. Are they supposed to flicker when turned on? When they shutdown, it doesn’t flicker as much in person. Anyone else have similar issue? I’ve tried to contact Bayoptiks about the damage on one of them but no reply at all. Kinda concerned.
https://drive.google.com/file/d/1EGX...w?usp=drivesdk
https://drive.google.com/file/d/1-hC...w?usp=drivesdk
The flickering is def a nuisance but it doesn’t look like anything else is flickering wrong besides start up is that correct ? One of the main issue people have had here is the water getting in. If it rains a lot where you live or it’s humid then you’ll end up with condensation. From what I’ve seen as of late the lights with “LED” written on them are good and I was able to find some from a recommended seller on Aliexpress but obviously there’s no guarantees. I even asked the seller if there was anyway they could check but they weren’t trying to wet the rear taillights in a video for me lol I tried right ? lol they told me (and I quote)
“Just install new lights, try to avoid washing the car, We have sold a lot of this tail light, and no customer has ever fed back the problem of water inflow.” Unfortunately that wasn’t enough to motivate me to gamble and make the purchase. Out of curiosity what do your taillights say on them ?
PhuX9928.00
      07-17-2024, 10:05 AM   #271
PhuX99
Drives: 2021 Alpine white X5
The taillights I got from BayOptiks say LED on the side. So far no water or condensation has gotten in it yet and it’s been raining for a few days now. As far as the fitment issue, I found the reason and solution why there was a gap. The aftermarket outer lights has a step where the 10mm nut tightens the lights down and I just drilled a slightly larger hole and touch up paint to make them slide in flush with the body. The OEM tail lights still mounts fine if anything you have more room to align the tail lights. The inner I had to use a few washers to get the fitment almost right. It’s not perfect but nothing anyone would notice unless they were looking at them from the top. So far I can live with it; the startup animation is the only thing that bugs me. My RH inner came in damaged but they sent out a replacement.
      07-17-2024, 02:37 PM   #272
ipayincash
ipayincash's Avatar
Drives: F95 comp
Those look great! Great job installing them they look like OEM fitment 👍 I’m pretty positive you got a good set 🤞since it has the “LED” on the side.
The light animation being off is def annoying, something that would bug the hell out of me too, but nobody else would notice it really lol I wonder why that seems to be an ongoing issue with these, and there seems to be different animation patterns lol they can’t seem to get them in sync like OEM…..
Either way they look amazing 🤩 I might pull the trigger really soon on a set I think I can live with the weird start up as long as no condensation problems
      07-28-2024, 01:08 PM   #273
Installsplus
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
Installsplus's Avatar
471
Drives: 2011 E92 M3 DCT/ESS 625 kit
After my frustration with Water, getting into the passenger outer tail I went back to stock. If anybody needs parts, please let me know. Inner tail lights are perfect. Left side is perfect. I was sent a brand new right side outer tail , but didn’t work properly. It’s unfortunate because they looked really good. Prefer someone local if possible.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625
2016 F15 X5 Msport 35i
      08-01-2024, 01:04 PM   #274
Impossibru28
Impossibru28's Avatar
Drives: BMW X5 M50i
So it seems there is still no clear source for perfect plug and play rear taillights correct ? Just read through all 12 pages to make sure I wasn’t missing something and after much reading I see AKD & Bayoptics are a no go, and the only other sellers are
https://www.k2-industries.com/produc...ghts-2019-2024
Did anybody make a purchase from K2 ?
https://bimmerplug.com/products/lci-...f95-x5m-g05-x5
Kobe4ever did your lights from bimmerplug workout for you ?
I would like to know this as well
      09-01-2024, 07:55 AM   #275
Grady-Hawaii
Drives: 2019 BMW X5 (G05)
I'm sorry if I'm a little slow here, but can someone please provide the detailed step-by-step instructions for removal of the passenger side rear 12V cigarette lighter panel? I am trying to replace the passenger side outer tail light (cracked) with an identical OEM replacement and would like to avoid the removal of the entire high-voltage fuses box located in the passenger side rear service panel and I understand working through the 12V cigarette lighter panel seems to be the most preferred method. Also, I've read some people talking about whether or not the light will need to be re-coded or not.... is this applicable for an OEM to OEM light swap on a 2019 X5? Any help/guidance is much appreciated!
(Note: This is my first post ever and I joined out of desperation trying to get this accomplished as I cannot pass the annual state-mandated "safety inspection" in Hawaii without this light replaced... which means I can no longer drive my car until this gets swapped, beause the inspection was due by the end of August.. ugh.)
Thanks again in advance.
      09-01-2024, 04:13 PM   #276
yimmy
Drives: M50i
I installed mine today and thought I would never complete it but once you know what you're doing it's straight forward.
1. On the cigarette panel, use a tool to pop the cap off in hole furthest to the right. Behind the cap is a nut (I believe 10mm), remove it.
2. Use a plastic tool to remove the frame of the cigarette panel. I worked right to left. As you get it pulled out you will have to remove the plug to the cigarette lighter.
3. Once removed you will see a nut above the fuse panel, holding the panel in place. No need to remove it. Just to the left of that nut is the nut that secures the taillight. It is behind the black insulation. Pull the insulation down to expose the nut. Remove the nut (10mm) and you can now remove the taillight. You will need an extension.
      09-02-2024, 01:01 PM   #277
lucreative
Drives: 22 BMW X5 xDrive45e
Sorry for the long delay in posting updates for these tail lights. But I may have a possible solution for you. I recently got a lot of condensation in my right outer tail light, more than before, and I though I was screwed and having the same issues as you. However, I was researching and realized that these LED lights NEED to vent. Water will get in no matter what and condensation will happen because LED is not hot enough to evaporate water that will always intrude. Read some post on Telsa tail lights.
What I figured out, was that my vent holes, the cloth covered ones were clogged and obstructed. They were not completely open with loose plastic inside (quality control issue). So I pealed the cloth sticker and cleared the hole. Slowly, over a week or so, the water completely evaporated.
Still doesn't fix the fact that AKD store is a scam and crap. But at least you can try this to salvage.
      09-21-2024, 01:14 PM   #278
blackoutF15
488
Drives: BMW X5 x35i
Has anyone done the aftermarket LCI conversation figured out how to alter the wiring to make the turn signal part lit? My signal lights and brake lights are shared with the bottom portion of the lights. The middle light which supposed to be for turn signals never light up.
      09-30-2024, 02:11 PM   #279
Kobe4Ever
Drives: 2019 X5 50i
Hey guys, I am gonna try and get these Beamer plug LCI tail lights in soon, but I'm pretty worried given all the posts in this forum, has anyone installed the Beamer plug? Do the tail lights need to be completely sealed or are they actually supposed to vent like another member suggested?
      10-01-2024, 11:15 AM   #280
starlights
Drives: G05 50i
I happened to see the the real (BMW) turn signal lights in action on LCI and was very underwhelmed by how they looked and how fast they flashed - while they look cool turned off I am not impressed with the functioning. I would save my money and put it elsewhere
