      03-28-2020, 01:39 PM   #1057
eagle_bmw
Drives: 2019 BMW X5 40i
07/2019.55 here and I don't have it either. Mine worked (need to enable in iDrive).
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
TurtleBoy12880.50
      03-28-2020, 01:58 PM   #1058
TurtleBoy
TurtleBoy's Avatar
12881
Drives: 2019 X5 40i,2021 M340i
Thanks guys, I will try it just coding the three I do have.
      03-28-2020, 02:27 PM   #1059
Multimodal
2857
Drives: 2019 X5 50i, 2018 911 T
Bumping this question... can towing functionality be coded via Bimmercode or Esys yet?
Originally Posted by martinf79 View Post
Any word on programming the trailer hitch?
Current garage: 2018 Porsche 911 T Carrara White Metallic/Black, 2019 BMW X5 50i M Sport Mineral White/Full Black, 2019 Ram 2500 Big Horn Diamond Black/Diesel Gray
Archived: 2019 Ford GT350 Ford Performance Blue/Dark Slate, 2012 BMW X5 50i Alpine White/Black, 2014 BMW 320i M Sport Melbourne Red/Black, 2009 BMW DINAN3 Alpine White/Black, 2008 BMW 335xi Alpine White/Black, 1998 BMW 328is Avus Blue/Tan
      03-28-2020, 02:31 PM   #1060
Jgc650i
Drives: 2019 X5 50i
Yep, when I did mine last week I only had 2 of the 4 listed items (I forget which ones specifically). I changed the 2 I did have and it worked fine. I did notice when I first drove the car the first time ADV wasn't working properly. It wasn't showing other cars or side lanes. Once I actually turned on the Assisted Driving Mode (cruise control) for the first time the ADV started working properly and has since stayed that way whether I have AD Mode running or not.
      03-28-2020, 02:56 PM   #1061
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Thinking about ADV, the cafd must be the same for all cars, it's just the settings that vary. Therefore the variance is only in the connection type.
I expect those that can't see all 4 codes cannot do so because their coding setup doesn't support viewing all 4 codes.
I don't know about bimmercode, but the only 100% way I can guarantee that those codes are not trimmed, is to use esysx with latest psdzdata for your target istep, and a version of esysx that has mappings for that psdzdata version.
      03-28-2020, 04:33 PM   #1062
TurtleBoy
TurtleBoy's Avatar
12881
I did the three I have and it seems to be working fine. I will have to see how useful it is but it looks neat anyway.
eagle_bmw182.50
      03-28-2020, 07:52 PM   #1063
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
No, definitely not on Bimmercode.
Maybe Esys can code "Towing mode"?
I've mentioned this a few times in other threads, I would really recommend getting the dealer to do any tow hitch installation on your G05, including coding. These cars have advanced and complex electronic control systems, so you really want to make sure anything retrofitted (even a BMW OEM hitch) is integrated properly, and thus my recommendation to get it installed and coded by the dealer.
Also guarantees your factory warranty. So hopefully you get a feeling for the benefits.
Might be a little more expensive using the dealer, but worth it for these cars.
      03-28-2020, 08:21 PM   #1064
Multimodal
2857
Thanks, I've seen that input elsewhere. Unfortunately BMW does not make the G05 towing kit available aftermarket yet and BMW dealers won't generally install aftermarket parts. So while it would maybe be ideal to do that, it is not currently an option for me (and I assume most people).
      03-28-2020, 08:47 PM   #1065
James_G0540i
Australia
446
Mine is a BMW OEM, at least for here in Australia.
TOWBAR PART No: A888 2000 978
TONGUE PART No: 9032 736 01010.
See attached pic. It was installed by my dealer.
      03-29-2020, 03:18 AM   #1066
ifr
ifr's Avatar
United Kingdom
1197
This might work.
In esys, no launcher/esysx needed, you could add 3AC to FA and do a full car (all ECU) coding, or at the minimum code the following ECU. I say do a full ECU coding as some models may have different ECU to mine and therefore the list below may not be exhaustive:
13F5
211B
29B7
3D0E
3D14
3E52
4146
42C1
42F1
430A
4508
7083
8081
Adding tow/hitch changes a LOT of coding. While it is possible to FDL code these settings individually I'll only post the specific settings if someone really wants to do it that way.
FDL coding so many settings also opens up additional risk. VO Coding is the safest most complete option in this case.
      04-04-2020, 06:43 AM   #1067
boscoji
boscoji's Avatar
Drives: 2023 X4 M Competition
Quick question- I had the iDrive 7 update to enable the 3d surround view on the connected app. After the software it worked without an issue. When they updated the software it wiped my coding. Recoded it, but now the 3d has stopped working. Anyone have any experience with which coding option may interfere with this? The other connected functions work, just not the 3d view. It says failed to activate cameras. I would like to get that functionality back and do not want to go aback to the dealer and have them reflash it again. Thanks!
      04-04-2020, 08:00 AM   #1068
russelldav
456bhp for breakfast
russelldav's Avatar
425
Drives: 2019 X5 50i
I have enabled ASD using the most recent BimmerCode update but can't see any menu or settings available in my MY2019 50i. Any ideas?
      04-04-2020, 09:06 AM   #1069
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Not sure that is still true. There is a BMW P/N for the hitch, controller, and wiring harness. Which means this should be a dealer installed retrofit (which would include the proper coding). Check here for the part numbers.....
https://www.realoem.com/bmw/enUS/sho...diagId=71_1114
Don't let the generic diagram fool you, the part numbers are for the US hitch, which is a different design than the EU hitch. The catch is that a dealer installed OEM hitch setup will have a reduced towing capacity over a factory installed hitch (not sure I understand why though - could be the lawyers talking)....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      04-04-2020, 09:43 AM   #1070
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
So I just took delivery of an X7 40i and I am looking to do a little coding. I have been lurking over here since the G05 and G07 are essentially identical from a coding perspective and the G05 coding scene is a bit larger....
Originally Posted by Mikli View Post
The M live cockpit is pretty cool but it doesn’t display the drive mode or change to blue eco or sport displays anymore. It is a nice change for M.
Originally Posted by goofytek View Post
I tried it and liked it too, but i lose the sport tach in the HUD. And not showing the modes is kinda a drag. Maybe missing another toggle to enable more info?
Originally Posted by mobilejo View Post
M cars don't have sport mode, sport+ or eco mode so stands to reason the M display won't have these settings visible on the tach.
Regarding the M display, has anyone dug a bit deeper to see why the Drive Mode is no longer displayed? M cars DO come with different drive modes, including ECO modes (much to the dismay of driver enthusiast "purists"). My F80 M3 has them and while I have not seen the cockpit of one of the new G-series M cars in person yet to verify, I would be shocked if the new G-series M cars don't have them as BMW wants to cater to a wide base of customers for their M-cars. But back to the M display coding discussion....
I coded this using BimmerCode. After coding, when I changed the different Drive Modes, it was clear that there was "something" happening in the cluster, as the screen changed very slightly when changing drive modes. For example, the triangle that indicates the car's position on the map in the center of the cluster changed to blue when in ECO mode. There were other very subtle differences on the display when changing different Drive Modes as well.
This leads me to believe the cluster module (DKOMBI) is "looking" for additional data in order to display the different Driver Modes. Therefore, it is possible that there are other parameters (either in the cluster module or another module) that need to be changed in order for the Drive Mode to display properly in the M display. Of course, if additional parameters are found to turn on Drive Mode in the M display, it could be different than the non-M display. For example, instead of the words for each Drive Mode, the background color of the M display could change based on the different Drive Mode selected. Right now I would be happy with some type of very noticeable display change for the different modes (the navigation triangle I mentioned above is a bit to subtle for me).
So any thoughts from the more experienced G-series coders?
      04-05-2020, 09:23 PM   #1071
James_G0540i
Australia
446
Bimmercode just updated to 2.18.0-6475 on Android, and I've noticed the the head-unit ECU module now supports Expert mode.
I recently coded Sports Plus through the Body Domain Controller (BDC) for my G05, since the 30d/Diesel doesn't come with Sports+ from the factory. After coding the BDC, I found Sports+ could be selected from the buttons on the gear-shift panel, but NOT from the head-unit (center head-display). It still showed Sports+ in the Instrument Cluster though.
Yesterday I coded Sports+ into the head-unit ECU using Expert mode; based on the recent update to Bimemrcode, and now everything lines up-including showing Sports+ on the center head display.
So to cut a long story short, to code Sports+ - I had to code both the BDC and HDU ECUs, so yes it would be safe to assume you need to code multiple ECUs for driving modes.
You shouldn't have to code anything in the Instrument Cluster ECUs though.
      04-05-2020, 09:27 PM   #1072
TSMC55
Australia
125
Drives: BMW X5 2019 GO5
So what changes did you make to the head unit ecu?
      04-06-2020, 05:17 AM   #1073
James_G0540i
Australia
446
Under HU_MGU (Head unit) ECU I changed two modules:
"3008 FES" module:
- FES_SPORT_EXPERT change to aktiv
- SPORT_CONF_ATTENUATION_SPORTPLUS change to active
- SPORT_CONF_STEERING_SPORTPLUS change to active
"300A SARAH" module:
- Spurwechselassistent change to gen_1
So overall procedure is:
Body Domain Controller (BDC) ECU:-
3221 PfFesMaster module:
- FesPiaDefaultSportWorldMode: change to 0x02 (SportExpert, aka Sports Plus)
- FesSportWorldMode1: change to 0x02 (SportExpert, aka Sports Plus)
HU_MGU ECU:-
3008 FES module:
300A SARAH module:
TSMC55125.00
      04-06-2020, 06:35 AM   #1074
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
That is good to hear. I tried to code Sport Plus (and Comfort Plus) this weekend only to find out that the HU_MGU ECU did not support Expert Mode yet. Good to hear it is coming (I am on iOS which always appears to lag Android updates).
But just to be clear, you can now see the different Drive Modes with the M Dash display coded? That is what I was really after with my post above since I know others have already coded Sport Plus with E-Sys. Can you show a few pics?
      04-06-2020, 10:49 AM   #1075
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
On a related note, I just purchased the Ethernet to Lightning adapter to use with my OBD2 ENET cable so that I could access some of the additional ECUs in my X7. The connection is blazing fast when compared to using my WiFi OBD2 connector. The same is true about the connection speed when using BimmerLink too.
So for the Apple iOS folks, if you already have an ENET cable, I would recommend getting the Ethernet to Lightning adapter as a wired connection will always be more stable and reliable than a wireless one (even though the current wireless OBD2 adapter options still do work well). I purchased the Ethernet to Lightning adapter recommended on the BimmerCode site.
      04-06-2020, 11:06 AM   #1076
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Lightning to Ethernet Adapter:
  • much faster than Bluetooth OBDII adapters = true
  • more or same reliability = not necessarily true; depending on random state of iOS at any given time, the Lightning Ethernet adapter can be intermittent
      04-06-2020, 11:13 AM   #1077
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
- much faster than Bluetooth OBDII adapters = true
- more or same reliability = not necessarily true; depending on random state of iOS at any given time, the Lightning Ethernet adapter can be intermittent
Fair enough. But so far my one coding experience with the Ethernet adapter was a very positive (and fast) one as my current WiFi adapter is an older Vgate one that is no longer made (but still compatible with the current BimmerCode and BimmerLink apps). If I have any concern with the Ethernet adapter, it is the long term reliability as technically, it is not a "MiFi" adapter and a few reviews have indicated poor build quality. Time will tell I guess.....
      04-06-2020, 11:59 AM   #1078
eagle_bmw
The ENET/lighting adapter combo is definitely a lot faster. I can walk through all menus in BC and code my preferences in 5 minutes or so. Compare that with MX+ taking ~5 minutes just to read and code BDC.
However, I had 3 instances where the cable combo failed to connect. Is this what you had experienced LexxM3 ? I had to disconnect and re-initiate diagnostics mode again. But once it works it is consistent.
I never experienced disconnection or issues yet with Mx+. It is just slow but fits the small storage box by the driver side.
2019 X5 40i M-Sport
