      03-06-2020, 10:55 AM   #1
jimbg
Drives: LR Discovery 5
Display kilometers per hour on UK car
If you have a UK spec car what can you configure for traveling in the EU?
Also does the car understand speed limit signs that are in kilometres rather than miles per hour?
Cheers
Jim
      03-06-2020, 12:30 PM   #2
Carneylad
Drives: G05 M50d, Tesla Model 3
Cheers
Jim
You can have both MPH and KPH displayed on the dash at the same time. I believe if you change the settings to use KPH as the default when in the EU it should be fine and read the signs correctly. There is also a setting for adjusting your headlights to driving on the other side. Not sure if this is available on all models. I have lasers and that setting is available.
      03-06-2020, 01:03 PM   #3
jimbg
Cheers for that, just need the car to be delivered now.
