03-28-2023, 12:04 PM | #1 |
Rep 284
Drives: 2023 X5 X45e
Dashcam, or rely on Drive Recorder
In my now-traded 2020 X3 M40i, I had a pair of Garmin dashcams, front and rear installed. With the X5 45e having drive recorder, I'm trying to decide if it's worthwhile to install them in the new X5. The worked fine, I had no major complaints about them - and they definitely offer more features than the drive recorder. Anyone have any thoughts on why to choose one over the other?
03-28-2023, 12:35 PM | #2 | |
Rep 515
03-28-2023, 12:59 PM | #3 | |
Rep 4,429
1. You manually pressing the Drive Recorder button 2. An accident sufficient enough to trigger Drive Recorder to save the file Either way, the max you get is "x" number of seconds before and after the trigger with "x" being your choice of the number of seconds from what Drive Recorder offers via iDrive. As you can see, its far from being a dash cam. |
IftiBashir110.00 |
03-28-2023, 02:34 PM | #4 |
Rep 2,073
Only you can decide - I have drive recorder and don't personally feel the need for a dashcam, however I didn't have a dash cam before I had drive recorder either, so take that into consideration.
If you do a lot of driving, or just want the added peace of mind, then add a dash cam. I don't think drive recorder is infallible so if I felt I needed a super reliable source of video evidence, I would be looking at a standalone dash cam. |
03-28-2023, 02:42 PM | #5 |
Rep 78
If is not too much trouble to add the dash cam, I would add it.
An additional camera will provide a different angle of recording and that may be useful in case of an unwanted event. |
03-28-2023, 02:43 PM | #6 |
Rep 221
Does the drive recorder work when the car is parked and off?
That would be a determining factor for me since I live in NYC and not all areas have private garages I can pay for. |
03-28-2023, 02:48 PM | #7 |
Rep 82
I'm actually making the same decision. Originally, I was leaning drive recorder for the cleaner look. I've decided to stay with dashcam (at least until I change my mind again). I think its beneficial to capture a longer history of an event. Don't just show what happened but possibly why it did. The best thing drive recorder has, that a dashcam doesn't, is that side view so that is perhaps a consideration for it.
AbleDanger145.00 |
03-28-2023, 03:34 PM | #9 | |
Rep 221
So yep, I'll definitely be getting a dashcam rather than rely solely on Drive Recorder. |
03-28-2023, 03:56 PM | #11 |
Rep 82
03-28-2023, 08:19 PM | #12 |
Rep 284
Thanks for the feedback. I was leaning towards the dashcam too, as it does record, easy to get the data off (via phone), can record on demand easily (I know DR has a method as well), and has parking mode if you buy the right cabling.
Other non-critical things is it'll do a time lapse, and also has updating traffic cam warnings and such that don't expire (read: free). Given that I have all the stuff (cabling, dashcam, etc). I may just go ahead and use it. DR and the cams can complement each other. |
03-28-2023, 08:58 PM | #13 |
356
Rep 365
I'd go ahead and install it. I have dash cams in all my cars and my road bikes. The in car recorder may work great, but the dash cam will catch everything. Even things that don't affect you.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
03-28-2023, 09:01 PM | #14 |
Rep 95
you might want to check out the Ring Dashcam. has over the air LTE, so you can check on your car at any time. downside is that it is not 4K.
2021 X5 xDrive 45e M Sport | Phytonic Blue | Tartufo Merino
2023 i4 40e M Sport | Brooklyn Grey | Cognac Sensatec |
03-28-2023, 11:21 PM | #15 | ||
Rep 221
Mainly cause its LTE and also 4K with support for a 2nd camera in the rear. It has been SUUUPER delayed though.. very frustrating. Originally backed it because the Blackvue 2ch dashcam on my BRZ was dying (speaker melted and app functionality stopped working), but now its looking like this will probably just go into the X6M. Question is which will I get first? lol |
03-29-2023, 12:07 AM | #16 |
Rep 284
I do enjoy saving and posting the crappy Seattle drivers and their antics....
03-29-2023, 02:22 AM | #17 |
110
Rep 319
Get a Dash Cam.
Drive Recorder, as mentioned above, is not a dash cam. I have it, and I still decided to go with the BMW dash cam front and rear as I like to have full continuous recording while I drive (I have the parking recording switched off as it just captured too much - every time there is any motion - so every time someone just walked past!). I wouldn't be without a dash cam - have a cheap 'Viofo' in my wife's car and that also works fine, so doesn't have to be super expensive. It's just good to have continuous recording so you have more footage of a silly driver before he rear ends you, for instance - rather then just the impact from the drive recorder! |
03-29-2023, 05:44 AM | #18 | |
Rep 1,201
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
03-29-2023, 07:21 AM | #19 |
Rep 1,236
03-29-2023, 07:46 AM | #20 | |
Rep 4,429
Drive Recorder is always recording when the car is running, it just overwrites its own footage as you drive until the trigger occurs. Then it goes back prior to the trigger to create the start point of the footage (video file) and continues to save the footage after the trigger per your settings. You could experiment to see how much footage its memory can hold by manually triggering it repeatedly if you are curious. I'd rather have a dash cam but so far have been too lazy to start investigating which one to get |
03-29-2023, 09:05 AM | #21 |
Rep 100
In the video linked in post #10, at the 2 minute mark, there is an option to "Manually start and stop the recording."
Is the length of that manual recording limited, or will it actually keep recording until it is stopped? It wasn't clear from the video since the guy didn't try it (but he did take several pictures of the top of his head). |
03-29-2023, 09:16 AM | #22 |
Rep 97
Not sure why anyone want a constant recording? If something interesting happen you can always record it with drive recorder by pushing button or asking with voice command. In case of accident everything is getting recorded automatically. I have dash cameras on both my cars and never review the footage unless something interested is recorded and stored manually, which is exactly what drive recorder does. In addition to it, the drive recorder will record video from all the cameras around the car, giving more details than dash camera. I have ordered my 50e with drive recording with surround cameras and don't see any need of having more cameras / recorders.
Tags |
dashcam, drive recorder |
