04-28-2024, 01:05 PM | #1 |
19
Rep 41
50e Owners with 22" Wheels - What Tires you got?
What tires are you running on your x5 50e with 22" wheels?
I just picked up some 22" wheels for the wife's 50e and went to discount tire to order the below tires and i was getting some push back regarding the load rating being to low vs what the car came stock with 20" wheels with tires that had 110 load rating. Front: Pirelli P Zero All Season - 275/35/R22 104W XL BSW BE Rear: Pirelli P Zero All Season - 315/30/R22 107W XL BSW BE Based on the load index chart for the tires above you get 8,266 lbs which is greater then the cars GVWR of 7,055 lbs so those tires should be just fine... right? I know you can get a 50e with 22" wheels from the factory in or around the europe area so im curios what tires and load rating they come with from the factory? Any help would be greatly appreciated. |
