03-13-2021, 03:55 PM | #221 | ||
1200
Rep 1,587
03-13-2021, 04:15 PM | #223 |
Rep 1,179
Starting to understand why this got broken. Seems they don’t have a standard menu across models for this. This is how it has always been set, so putting it in SPORT mode displays the tach, but it doesn’t do it. You can only change it to Always. Off and “In SPORT mode” are now essentially the same.
This is how it’s set on the G20/21: |
03-13-2021, 04:33 PM | #224 |
1200
Rep 1,587
Most likely a coding change than a firmware issue.
Have a look over the coding settings. Should be fixable one way or another. The menu I have is for MY21 rather than G05 specific. It does switch to tacho when in sport mode. This is the full coding if you want to try the newer menu CB_HUD_FAS: nicht_aktiv [00] CB_HUD_LIST_AUS: aktiv [01] CB_HUD_LIST_AUTOMATISCH: aktiv [01] CB_HUD_LIST_FAS_PERMANENT: aktiv [01] CB_HUD_LIST_SPORT_AUS: nicht_aktiv [00] CB_HUD_LIST_SPORT_FES: nicht_aktiv [00] Last edited by ifr; 03-13-2021 at 04:41 PM.. |
03-13-2021, 04:44 PM | #225 | |
Rep 1,179
03-14-2021, 04:46 AM | #226 | |
Rep 1,179
Thanks for this! This was a really annoying issue as it was always in your line of sight every time you drove the car Thanks for the help and info this weekend. All issues fixed! |
ifr1200.00 |
03-14-2021, 06:34 AM | #227 |
Rep 272
Couldn't find anyone in Australia able to code TLA after going through the whole thread so I guess its not available in Australia yet?
03-14-2021, 08:31 AM | #228 | |
Rep 207
Hi,
Can check with you, the coding is default or you ownself code to enable it? Quote:
03-14-2021, 09:02 AM | #230 |
Rep 207
Hi,
Thank you. Can i understand more on the coding? What does this 2 codes do? CB_HUD_FAS: nicht_aktiv [00] CB_HUD_LIST_AUS: aktiv [01] This 2 code enable menu for "Additional Display"? CB_HUD_LIST_AUTOMATISCH: aktiv [01] CB_HUD_LIST_FAS_PERMANENT: aktiv [01] This 2 codes will disable menu for "Sport Displays"? CB_HUD_LIST_SPORT_AUS: nicht_aktiv [00] CB_HUD_LIST_SPORT_FES: nicht_aktiv [00] |
03-14-2021, 09:42 AM | #232 |
Rep 207
03-14-2021, 12:49 PM | #234 |
Rep 51
03-15-2021, 03:36 AM | #235 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Did you have to recode aSLA after your iStep upgrade to 03/2021?
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
03-15-2021, 04:45 AM | #236 | ||
Rep 51
03-15-2021, 07:40 AM | #237 | ||
1200
Rep 1,587
03-16-2021, 04:25 AM | #238 | |||
Rep 451
i-step 07/2020.25 - new features including Traffic Light Assistant
03-16-2021, 04:29 AM | #239 | |
1200
Rep 1,587
TLA has to use KAFAS as it needs to dynamically read the light status (RAG) and also differentiate between the type of light in use. |
03-16-2021, 04:40 AM | #240 | ||
Rep 451
If this is the case I think this component may be omitted from the Australian database and why TLA does not work here as our traffic lights are similar in appearance to those in the U.K./EU or alternatively it may be geofenced like Traffic Jam that we have yet to circumvent
03-16-2021, 08:59 AM | #241 | |
1200
Rep 1,587
Same for eTJA. It's not a code/landmask that prevents it from working. Last edited by ifr; 03-16-2021 at 09:08 AM.. |
03-16-2021, 03:44 PM | #242 | |
Rep 451
I was able to read these commands using Tokenmaster's NCD CAFD Tool but it no longer works. I suppose i could test this theory by changing the country code to 801 (DE) or 824(UK) in the FA and VO code the KAFAS module
