05-15-2022, 03:15 PM | #1 |
Rep 776
Fs: 2008 bmw m3 e92 - clubsport / track build
2008 BMW M3 - Black / Black - 166,000 KM - 6 MT (New oem clutch + flywheel) - Rod Bearings with ARP Bolts. Full car inspection and service was done in April 2022. - 44,950$ CAN - Located in Montreal, Canada Perfect car for the enthusiast looking for a weekend/ dedicated track car that you can drive on the streets. Meticulous built by an M3 enthusiast. Top quality parts only and no cutting corners. Over 40,000$ in parts alone. Most of the components on the M3 have been overhauled / upgraded or replaced with OEM parts from 2019 - 2021. I drove the car for about 10,000 km including most of the upgraded parts. The car is ready to drive and enjoy. No repairs needed. The body is in fair condition with normal wear. Ceramic coating was also done on the vehicle last year. Including all of the part receipts + service documentation. Looking to sell as is + includes all of the OEM parts (front seats, full interior, stock brakes and more…) I would rather not part-out. Prior to purchasing the vehicle in 2018, the car had a small accident in the front (reported on Carfax). Front right corner including hood was damaged and fixed with OEM parts. The car is A1 and has 0 issues. Selling only because I started a new project and this is my 3rd E92 M3. Will cost you over 80,000$ to build a similar car. Low ballers will be ignored, priced to sell. ----- Full Album: View post on imgur.com MAINTENANCE: - Rod Bearings with ARP Bolts (July 2018) - New Actuator (July 2018) - Full Coolant Flush (Engine, Diff, Transmission, coolant) (August 2019) - Motul 660 (Brake Fluid) (August 2019) - New Windshield (June 2020) - Oil Change (July 2020) - New Spark Plugs (July 2020) - New 2 x Front Wheels Hub (August 2020) - Steering Rack Rebuild (December 2020) - Oil Change + Motul 660 brake fluid (April 2021) - Pad alignment (-3.5f , -2.4 rear 1/16 in) (April 2021) - Power Steering full system overhaul (June 2021) - Oil Change + Inspection + Alignment (April 2021) - New OEM Clutch + Flywheels (April 2022) UPGRADES: Power - Turner Motorsport Test Pipes - Stage 2 - Alex Alpine ECU Tune - AFE Carbon Intake Wheels & Tires - 18” VOLK TE37SL (18X9.5 , 18X10.5) - Nankang AR1 (275 / 295) - 19” OEM M3 Wheels - Michelin Pilot 4S (265 /285) Suspension - JRZ RS1 Coilover Kit - Eibach Springs (900F / 900R) - Ground Control Race camber plate - Group N Engine mount (BMW Motorsport) - Subframe Aluminum Bushing (Bimmerworld) - Differential Mount Delrin (Turner Motorsport) - Transmission Mount Poly 80a (Revshift) - Powerflex Poly bushing rear shock mount - Powerflex rear control arm & trailing arm bushings - Subframe Powder Coated Black - Hotchkis Sway Bars (front + back) - Full front SPL suspension Arms - SPL Rear toe Arm - SPL Rear Upper Guide - SPL Camber Arm - SPL Sway End Link Rear - SPL Toe lock kit Brakes - Stoptech BBK ST60 / ST40 + SS brake lines - Pagid RS29 Pads (Front & Back) 80% life - Apex Stud Kit - Motul 660 Interior / Safety - (2) Recaro SPG XL - Raven Performance Roll Bar - Schroth 6 point harness (GT3 version) - Recaro Side Mount 7207450A - VAC Seat Belt Receptacle - VAC Extinguisher kit - MS Sidemount - Hard Motorsport Door inserts - Hard Motorsport rear trunk cover - Cooling - CSF Triple Pass radiator - CSF Oil Cooler - CSF Power Steering Cooler - D088 Coolant hoses Kit - Bimmerworld Cowl MISC - Power Steering Overhaul / OEM Upgrade - Bimmerworld Racing Shifter - Bimmerworld Clutch Stop - Bimmerworld Clutch & Brake bushings - Bimmerworld Pedals - Turner front SkidPlate - New Steering Wheel Alcantara Custom - GT4 Carbon Front Splitter + Rear Spoiler
E92 M3 Clubsport
JRZ | TE37SL | AR1| Stoptech BBK (ST60/40) | Recaro SPG XL + Schroth 6 point | Raven Roll Cage | | Alex Alpine Tune | Turner Test Pipes | AFE Carbon Intake | Bimmerworld Solid Bushings and more... Last edited by Rafstar; 05-17-2022 at 11:22 AM.. |
05-16-2022, 08:22 AM | #3 |
Rep 2,091
Wow great build, I know you don't want to part out but you'd make a lot of money back from putting it back to stock.
GLWS
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
