05-14-2022, 09:10 AM | #287 | |
Rep 46
Drives: '22 X5 45e; '09 328 N51 SULEV
05-14-2022, 10:49 AM | #288 | |
Rep 8,694
Drives: eVeRyOnE mAD!
probably best you unsubscribe since you clearly didn't understand that and aren't receptive to the fine folks here trying to help you understand there are limitations to almost everything in life. it's pretty clear how you deal with it when things don't go your way |
05-14-2022, 01:22 PM | #289 |
Rep 6,805
The 45e has two distinctly different ways to turn over the ICE:
- regular starter motor and note, it is a beefed up system versus the pure ICE machines so wear should not be a problem - jump start function where if you're moving already and the ICE needs to be turned on, it engages some clutches in the transmission and the momentum starts the ICE up. I do not notice any judder or shake when mine starts up the ICE. So, in my case, I do not miss an ASS button option. The 45e is a complicated vehicle, as are most any new BMW these days. THat's one reason why the user's manual is over 400-pages. If you haven't read it at least twice, you're missing out on features, and understanding the ones you thought you might already know, like there are three different modes on the cruise control, for example. If you drive it like every other vehicle you've owned, you're not getting full benefit out of it. It is different. A pure electric will be that much different yet again. |
07-14-2022, 04:46 PM | #290 |
Rep 1,003
In my config, I had it set to start on Adaptive. In the 3 drives since then, never entering Eco Mode, ASS would still be on with
Auto Start Stop function Not Active I just went in and also enabled this which I expect ASS to work once turned off. Auto Start Stop function memory Active Am I amiss on the original setting being set to not Active but it obviously was still being active.... |
