04-03-2020, 09:57 PM | #1 |
Rep 163
PSI on 22 wheels.
Hi guys,
I swap my 740m oem 20 to my 22 wheels staggered front 275/35/22 rear 315/30/22 Pirelli P zero Pz4 . I tried to fill the psi as factory recommended which is front 38 psi rear 45 psi. I found that driving is terrible. The car feel floating and not attached to the road at all it like bouncing all the time and my steering is weird too. I then put it back as i normally fill which is front 34 and rear 40. The driving is totally different car. What are you guys PSI and what you guys recommend?? Please let me know.
BMW X1 F48 2017 sold
BMW X5 G05 50i 2019 sold BMW X5M comp F95 2022 Mini clubman JCW F54 2019 |
04-04-2020, 07:56 AM | #2 |
Member
892
Rep 2,029
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [0.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Just going to be doing the swap back to the 22" this morning. I have 3 cars I'm taking over to my tire guys. There is a thread here as well
https://www.bimmerpost.com/forums/sh...php?p=25444809
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
04-04-2020, 02:43 PM | #3 |
Member
892
Rep 2,029
They installed my 22" setup this morning with the recommended tire pressure. Seems to be fine. Outside temperature was about 9 Celsius. I felt it was a good balance between comfort and spirited driving. I've got the Conti's and would think there is about 10,000 km on them.
04-04-2020, 03:37 PM | #4 | |
Rep 163
Thats look great! I think may be mine are performance tires and I already has 12000 miles on it. I just feel uncomfortable with factory recommend PSI with my 22 summer set but for 20 oem set it does just fine with factory set up. I will have to try again when i change new tires to 22 rims and let see if new tires will feel the same. Thank you for your response!
04-04-2020, 03:54 PM | #5 | ||
Member
892
Rep 2,029
04-05-2020, 08:20 PM | #6 |
Rep 89
I lowered mine from recommended to 37 front 42 rear using an old trusty analog gauge. It's slightly warmer now and the car reads higher but often displays fronts at 42 and reads 45/6 when driving for period of time.
Still experimenting but feels better. I used to run my M3 a couple under also.
Current: 2020 X5 M50i / AG / Full Black Merino / 742M / Exec / DHP / Driver Assist. Pro / Lux Seat / Acoustic / Shadowline / Heated all / Luggage
Returned: 2017 F80 ZCP / Min Grey / Exec / Full Merino / LED |
04-08-2020, 10:44 AM | #7 |
Rep 494
I'm running 38/45 on my 22 PS4's without any issue.
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
04-08-2020, 12:10 PM | #8 |
Rep 5,719
Drives: '24 iX50; '23 i4 M50
What size 22" PS4s are you running?
https://g05.bimmerpost.com/forums/sh....php?t=1705713
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
