01-25-2022, 08:26 PM | #1 |
Rep 3,933
Disconnect Battery from Vehicle
If say for example, I wanted to remove the steering wheel airbag.
I know I need to disconnect the large vehicle negative battery under the rear cargo area, but what about the smaller auxiliary battery under the hood on the passenger side at the back of the engine compartment? |
01-26-2022, 12:47 PM | #3 |
Rep 106
Do you lose all the programming in the computer when disconnecting the battery?
Wondering as I need to replace an amp this weekend and debating disconnecting the battery or not.
2022 White X5 Xdrive40i M-Sport
01-26-2022, 12:48 PM | #4 |
Rep 3,933
Good to know. Thank you. Though I had a trim piece on the steering wheel replaced (creaking noise) by the dealer and it looks like he may have turned off battery power by the small auxiliary battery under the hood. Or something in that same compartment. I know he didn't disconnect the main battery in the rear. Hmm?
01-26-2022, 01:46 PM | #5 |
Rep 842
It's basically the same as rebooting iDrive. You might have to operate the tailgate a couple times to get it to sync up after reconnecting.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
WellsX553.50 |
01-26-2022, 02:44 PM | #6 | |
Rep 8,815
Alan
WellsX553.50 |
01-26-2022, 02:51 PM | #7 |
Rep 7,489
Check your owners manual...the sunroof may need a reset after a battery nap (loss of power). And on some BMW models the one-touch windows, clock, and date may need a reset after a battery nap. But it also may depend on how long the cable is disconnected.
Also, if you do have an aux battery...if you disconnect the main battery...the vehicle is NOT totally de-energized according to the TIS. So do be careful when disconnecting airbag and SRS/MRS electrical connections if you haven't disconnected both batteries....there is a risk of shorting if you leave the aux battery attached. So just be careful & aware of the risk.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-26-2022 at 03:41 PM.. |
WellsX553.50 |
06-27-2023, 08:29 AM | #8 |
17
Rep 45
I am trying to swap my paddle shifters for carbon ones. The job itself is fairly easy to perform according to videos I’ve seen online.
Basically you disconnect the negative terminal from the trunk battery and that should allow you to remove the center block of the steering wheel and get them changed. The issue for me is that the new G06 LCI comes with the BMW MHEV technology and by disconnecting the negative cable in the trunk alone didn’t seem to have powered off the steering wheel as the horn was still working so I didn't proceed worrying I could set the airbag off. Wondering if anyone can guide me through how to disengage the airbag to carry out the job? Thanks in advance |
06-27-2023, 08:45 AM | #9 | |
Rep 4,338
WARNING: Never close the engine hood/bonnet if the rear cargo area battery is still disconnected as this will/may (according to BMW) damage the Li-on battery because closing the engine hood/bonnet will automatically reconnect the Li-on battery back into the electrical circuit. Last edited by Marty in NY; 06-27-2023 at 09:04 AM.. Reason: Added warning |
Clk Group39.00 |
06-27-2023, 08:46 AM | #10 | |
17
Rep 45
06-27-2023, 09:02 AM | #11 |
Rep 4,338
WARNING: I forgot to mention this in my last post but.....never close the engine hood/bonnet if the rear cargo area battery is still disconnected as this will/may (according to BMW) damage the Li-on battery because closing the engine hood/bonnet will automatically reconnect the Li-on battery back into the electrical circuit.
06-27-2023, 10:00 AM | #12 | |
17
Rep 45
Thanks a lot again. |
Marty in NY2723.00 |
06-27-2023, 10:06 AM | #13 | |
Rep 4,338
BTW, I know were Redhill is, I used to live in Maidstone. |
06-27-2023, 10:11 AM | #14 |
17
Rep 45
