The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Best Scanning Diagnostic Tool
      09-16-2016, 06:05 AM   #23
aaron_
Drives: E93 335i LCI
Can you do logs with the Carly app? I need to sort out a half cel error codes 2c56 and 2c58 - they come on at wot 3rd and 4th consistently. If I can't I have a DCAN and inpa. Can logs be done through that. I don't have a jb4 in case that's suggested
Thanks guys
      12-11-2019, 09:09 AM   #24
335xiBRO
Drives: 08 335xi
Originally Posted by vtl View Post
This is the golden link that works. Lot of cables are a different white PCB which might not connect to your car.
http://www.ebay.com.au/itm/271621954...%3AMEBIDX%3AIT
INPA is the software from BMW you can use to diagnose your vehicle. Much more capable than the BAV cable. Reads everything and you can go into the detail of an error code. A lot of times the error code is pretty vauge but will have more data ascociated with it that pinpoints the fault. Cable is much cheaper and the software can be downloaded off the forums. Its a bit tricky to setup but now there are idiot proof guides in in the coding section of this forum.
Alternatively if you want a more user friendly setup, you can use the same cable but use an android app called BMW Carly. Never used it cos I use INPA but seems to be an alternative that is easy to use and recommended by a lot of members here.
Hi just recently purchased a 335 and looking for a scan tool. Is INPA still your recommendation these days or has something better popped up ?
      12-11-2019, 03:24 PM   #25
vtl
vtl's Avatar
Australia
1496
Drives: 2008 BMW 135i MT
INPA is still the go to software imo. ISTA is the newer version of the software which is a lot more user friendly (although much harder to install). But it is quite slow to connect to a car and scan it. INPA is much more convenient and faster
      07-17-2021, 10:46 AM   #26
evanmike.auto
evanmike.auto's Avatar
Drives: 2018 BMW X4
Yes INPA is really good, one vote for this tool. I've been using it for years and I must say that it's really easy to use, you don't have to be an expert to use it.
I'm wanna try something different so I'm looking for other choices. Just found this article: https://www.obdadvisor.com/bmw-scan-tool/ It covers current BMW scan tools and I think I'd try with the Foxwell NT510 Elite, based on its good review overall... Gonna order one today. Good luck to me
      04-28-2024, 11:48 AM   #27
Kingweddle21
Kingweddle21's Avatar
Drives: E92 335i
I purchased a 2011 335i last year and am looking at scan tool options. Do you still recommend the INPA software? Ive been looking at foxwells NT710 scanner but i am uninformed in this subject
