View Poll Results: What type of installation would you want? | |||
I'm good with powering through USB | 7 | 31.82% | |
Hardwire 12v into fuse | 12 | 54.55% | |
Mirror tap type power | 6 | 27.27% | |
Multiple Choice Poll. Voters: 22. You may not vote on this poll |
03-22-2021, 06:47 PM | #23 |
Rep 217
03-23-2021, 10:04 AM | #24 |
Rep 217
Alright, excited to share an update. I kept thinking about the board and getting the 12v circuit correct from the mirrortap. I ended up staying up late last night working with a PCB designer and I now have a single board to handle everything.
Those are sent for production, and I should have them in a week or two. So in terms of hooking up to the vehicle, you'll just have the 12v power wires, so mirrortap or hardwire, and then on the other side, you'll have the LED mount for the dash and the sensor. I need to bench test the power, but it should handle the variable voltage in the car just fine, once i get the PCB in, then I can verify and hopefully no changes will be required. So now I really need to get the LED dash mount sorted, as that's the last major component left to get to a finished product. I tried doing a clay mold of the dash so i could have something sitting on my desk here to work with, but that didn't work so well... Time will be a little tight this week, so might not get to it until the weekend. That's all! Excited to share some more pics in a week or two! |
nZtiZia4708.50 |
03-23-2021, 11:46 AM | #26 |
Rep 217
Sort of, the new board is a arduino clone, built to my spec. So I can run the same code easily, but the board was built for this project, if that makes sense. Has the 12v conversion built into the board to be able to hardwire into the car.
03-23-2021, 11:50 AM | #27 | |
Driver 🇦🇲
32
Rep 43
I think I get it. It's a PCB that works like an arduino and has a 12v-5v converter built in? Is the PCB something you designed or is it a modified version of something readily available? |
03-23-2021, 11:51 AM | #28 |
Rep 217
03-23-2021, 11:54 AM | #29 |
Driver 🇦🇲
32
Rep 43
Amazing dedication right there! I love watching projects like these come to fruition. As someone who worked as a CAD designer and CNC machinist for 6 years, I especially appreciate the level of detail you're putting into this.
03-23-2021, 03:32 PM | #31 |
Rep 76
Earlier, I believe, I mentioned having written a letter to the CEO. Today, I received a call from Logan at the BMWUSA HQ as a follow-up to my letter.
The usual pass-the-buck, "have you talked to the dealer", etc. She said she would escalate internally and let me know something by early next week - but not to get my hopes up of a quick solution. (no kidding, it's been going on since 2019) She did ask if I had my windshield tinted which I do not. That may have helped a little bit, at least caused her a moment or two of pause. I am sure she was counting on my having a tinted windshield. More to follow, hopefully, but certainly nothing as exciting as the project you have undertaken, chrisnack. It gets more interesting by the update. Again, incredible. |
03-23-2021, 03:47 PM | #32 |
Rep 217
I doubt BMW will fix it unfortunately and it would just be a software fix anyways (which is totally fine).
Oh well, I will have my stuff ready in a couple weeks hopefully. I worked on setting up a store online today so it’s easy to order and I can track stock and make sure you aren’t paying for one without me having stock... I don’t want people to think the money just goes into a black hole. I personally hate that, so you won’t be able to order one unless I physically have it completed and ready to go. And I love when places support Apple Pay and google pay so I will support those as well! Thanks to Shopify. Last edited by chrisnack; 03-24-2021 at 08:55 AM.. |
03-23-2021, 04:32 PM | #33 |
Rep 2,610
Nothing wrong with a software fix. A rather simple fix that would make everyone happy is a manual brightness override control and that should have been there in the first place. I was lucky enough to learn early in my engineering career that while automation is great, every automatic function must have a manual override because the reality is that engineers are never as smart as they think they are when it comes to real world inputs/situation and users (but defaulting to auto before user has their say is often fine and desirable) — many designers and engineers have never learned that lesson.
SpeedyBeamer11.50 mitch57804.50 |
03-24-2021, 08:55 AM | #35 | |
Rep 217
03-24-2021, 06:08 PM | #36 |
Rep 217
Got the initial prototype piggyback boards in today that i designed a little over a week ago. So got that hooked up, here's a pic of the screw terminal test board and then the new board i designed for comparison, it's super tiny! The darker blue board underneath is the one i designed, it has the wiring for the circuit embedded in it. The 2nd pic with the larger board, most of the circuit is in the actual wiring itself.
The newest board will be a bit bigger, because it has the 12v circuit in there as well. I also switched the wires to a silicon based wire, and it's much more pliable and will fish through trim considerably easier. I think i might drop the gauge even more though yet. |
nZtiZia4708.50 |
03-24-2021, 09:11 PM | #37 |
Rep 8,766
Drives: eVeRyOnE mAD!
2 weeks driving with 35% ceramic tint (98-99% heat rejection) on front driver/passenger windows, I don't seem to be plagued by the dimming dash issues BUT I will gladly support you when this product is released
03-24-2021, 09:48 PM | #38 | |
Rep 217
Maybe 35% isn’t as bad though, I’m 15%. I’m betting where you are located geo wise and how intense the sun is plays a part as well. I’m in WI and it’s winter/early spring right now. |
03-25-2021, 07:01 AM | #39 | |
Rep 76
Wait 5-10 seconds and see if the display brightens any more from your "normal" backlighting. If it does, you have it. Nothing wrong with that, many are used to it and accept it, others don't care. I live in the Dallas area, where it gets VERY bright and very hot. Going under trees, skyscraper shadows, pop-up storm clouds, etc. really affects the display. If I'm wearing sunglasses, which everyone here has to do, it just makes the problem ten-fold. One minute you are looking out the windshield in the brightness and then look down at your displays and literally cannot see anything for a few seconds until your eyes adjust - rinse and repeat. It sucks. I have 35% tinting as well - none on my windshield. I truly hope you don't have the problem, that would be great. |
03-25-2021, 11:48 AM | #40 |
Rep 217
I assume there a few of you who are open to doing some beta testing for me?
Once this next round of boards comes in, even if i don't have the dash mount fully sorted, I'd like to get a couple people using/testing these for me. I've got a mount that clips in, it's just not as pretty as I'd like it to be yet. |
03-25-2021, 02:29 PM | #42 | |
Rep 8,766
chrisnack i'm a little leery about tapping into power to beta test... |
03-25-2021, 02:42 PM | #44 |
Rep 8,766
