02-10-2020, 12:18 PM | #1 |
Rep 411
Run flat tire is flat and needs replaced, but all four?!!!?
yes my first flat tire! rear right was flat. I drove about 20 miles back home on it. Took to dealer and they said it needs to be replaced. That's not it. because X5 is all wheel drive, you have to replace all four tires. The tread on my car is about 4-5 mm in front and 3-4 mm in rears. BMW recommend replacing tires at 3 mm tread is what I was told. This is my first experience with all wheel drive and run flat tires. My X5 is only a year old but 29000 miles (we've traveled places I somehow settled for replacing just the two rear tires for total cost 752$ with installation. I hope I did not get screwed (my tire is screwed for sure)
02-10-2020, 12:59 PM | #2 | |
Rep 133
wanderlustX5156.00 |
02-10-2020, 01:03 PM | #3 |
1053
Rep 1,952
depending on how much tread you have on the other tires you may have to replace in pairs, but not all 4 unless they need to be replaced because of other reasons.
They say you don't want to have a brand new tire riding on the same axel as a tire with a lot of miles on it. If they're close in miles (say a few thousand miles) you're OK, but if they're not, it's best to replace the pair. Not sure why it would matter front to back. I'm sure those tires wear at different rates anyway. |
02-10-2020, 01:07 PM | #4 |
Rep 411
the front tires have tread 4-5-4 and the rear tires have tread 4-3-3. The dealer told me BMW recommends replacing tires at tread level 3. at first, they wanted me to replace all four. The tire shop person at dealership told me I could getaway with just replacing rear two tires because replacing only one tire can result in axle differential
02-10-2020, 01:10 PM | #5 |
1053
Rep 1,952
3/32nds (which I assume is level 3) is pretty much at the tread bar. This is when you'd want to seriously consider replacing your tires. Their performance in the rain will be compromised. You're 4-5-4 tires probably have a few thousand miles left, so it's matter of convenience at that point. Replace all 4 now and save yourself a trip back to the dealer in a few months, or spread them out.
02-10-2020, 01:15 PM | #6 | |
Rep 411
02-10-2020, 01:27 PM | #7 |
1053
Rep 1,952
Guess it depends on the type of Conti you have. On my Mercedes I had CrossContact LX Sport and got about 40k miles out of them. Those were all-season tires. If you have summer or performance tires, you're not going to get 30k miles out of them.
02-10-2020, 01:30 PM | #8 | |
Rep 411
02-10-2020, 01:32 PM | #9 |
Rep 133
My summer tires only get around 10k miles
02-10-2020, 01:33 PM | #10 |
1053
Rep 1,952
I don't know if those Conti's come with a tread warranty like the DWS 06s do, but you may want to look into that. 30K miles is pretty low for those tires. I believe they have a UWQT rating of 480, so that's pretty decent tread life.
02-10-2020, 01:34 PM | #11 |
Rep 178
Maybe you guys have better luck, but all of my stock BMW tires (Conti included) have been pretty dead by 30k miles, just about the time I return my leases. I had to replace a set of Goodyears around 20k miles (they were awful near the end too).
So yeah, while you CAN replace 1 out of 4 tires, I have no doubt that they would recommend to replace in pairs (at least) when the rest have 29k miles... Pretty much guarantee the X5 is not going to drive right with 1 new tire and 3 old ones. Might even notice it driving funny with 2 new and 2 old... |
02-10-2020, 02:29 PM | #12 |
2019 X5 40i
115
Rep 226
My past experience with F10 528 xi, the run flats did not last well and dealer recommended changing them at around 33K miles. Dealers generally err on the side of caution to make money
Eventually i got 4 new run flats from costco at 40K miles Talking to some of my other friends, they all had to replace their run flats by 45K miles
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
02-10-2020, 02:59 PM | #14 |
Rep 418
Drives: ‘20 X5/M50i (ordered); &
At 29,000 miles per year you obviously do a lot of driving and possibly a lot at high speed. You know you won't get two years of service out of anything you select. If I was in your situation I would start shopping tires when trend on one is at 4 and change all at same time even if a few are still at 4. Your going to have to replace in a few months anyway.
02-10-2020, 03:02 PM | #15 | |
Rep 411
Anyone with suggestion between: Pirelli vs Michelin or just get Conti again? |
02-10-2020, 03:08 PM | #16 | ||
Rep 418
02-10-2020, 03:25 PM | #17 | |
Rep 2,609
Considering the cost, it may be more effective to replace the one tire and to shave it down to the wear of the other 3. While it sounds weird and wasteful, it's a complex predictive cost calculation to decide whether to replace all 4 or shave the one, but it is done. Tire Rack will do it for free, I believe, for example.
02-10-2020, 03:29 PM | #18 |
Rep 178
Not on a modern X5, but when I replaced the tires on my wife's 2007 X5 (which we owned, not leased) I put Michelin's on and was very happy with them.
On her X3, which required replacement of the OEM Goodyears at 20k, I put on Pirellis, but honestly, I got what was cheapest and met the lease requirements because I knew we'd be turning the car in. I've never had a bad set of Michelin's though... |
02-10-2020, 04:10 PM | #19 |
Rep 411
the dealer's tire expert recommended Bridgestone Alenza A/S RFT instead of Pirelli Scorpio Zero A/S or Conti A/S for the weather we get in Oregon. Wet, snow in mountain passes from Nov-April. They were also 400$ cheaper than Pirelli and Conti.
02-10-2020, 04:42 PM | #20 |
Getting older, but I still love awesome fast cars!
144
Rep 360
I agree with other posters, not surprised by tires worn out at 29k miles. Replace all 4 because of wear not just because you had a flat. The flat caused a deeper inspection. Of you only replace the rears, which is the minimum to keep matched set, then you will likely do the fronts in one more month. I would look at the replacement as a chance to upgrade.
RVAGuy167.00 |
02-11-2020, 06:32 AM | #21 |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
As others have alluded, it's all about rolling radius. I've always gone with 4/32nd as a rule of thumb. So if the most tread you have on one tire is 5/32, and figuring a new a/s tire is 11-10/32, you would be out of that 4/32nd recommendation. See the article below as other manufacturers have even stricter recommendations. Regardless, 29k is a lot of miles on any BMW.
https://blog.tirerack.com/blog/make-...on-an-awd-car-
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
Tags |
#runflattires #x5, #tires |
