11-27-2022, 01:12 PM | #111 | |
13266
Rep 19,785
Go have fun with your lights. Just the fact that won't show the coding after repeatedly being asked for it by numerous folks shows you have no desire to contribute anything of value to the forum. Like others have been doing, time for me to just ignore your nonsense.
11-27-2022, 01:59 PM | #112 | ||
Rep 740
11-27-2022, 03:04 PM | #113 | |
Rep 177
There is no rational reason not to post verification of your successful coding... Other than the logical conclusion you are not being truthful. If you are being honest, you would have nothing to lose. |
11-27-2022, 03:16 PM | #114 | ||
Rep 740
No camera it's going to capture what the eye sees. I see what BMW advertised. And that is all! I didn't do Anti Dazzle in my F30 because the physical hardware was missing (HID) and I would need ECE housings. There is no physical hardware missing as these are matrix LED with the proper swivel and basically the same as ECE. My archaic iPhone does not have the proper night CMOS to capture the lights in action. If you do not want to believe it, that is your choice. Once again there are over 10 lines of parameters that need changing. The only changes one cannot do in BimmerCode is the camera sensitivity. Which when changed will keep the high beam on longer in roads with street lights. The code is here in the forums. I will code the KAFAS with the laptop and see if I see any differences. |
11-27-2022, 03:53 PM | #115 |
13266
Rep 19,785
Just ignore him. He is likely using one of the faux anti-dazzle coding procedures that have been posted in various threads. This one is supposed to be very close to working but of course does not have the KAFAS capability and has not ben shown to not have some light leakage. Folks using it though seem to be happy with it and have not reported getting flashed from glaring others. Of course it is not the full functionality but does provide tunneling.
11-27-2022, 04:03 PM | #116 | |
Rep 740
11-27-2022, 04:32 PM | #117 |
13266
Rep 19,785
What are you 13? Why don't you wait until you mature a little bit and then you can join conversations. And don't even bother posting the supposedly missing lines now, you have zero credibility on this forum and likely no one will test what you post anyways. Thankfully people like you generally lose interest fairly quickly and we don't have to put up with them for long.
11-27-2022, 04:53 PM | #118 | |
Rep 740
I genuinely feel bad for folks like you. Always trying to prove people wrong! Enjoy your G05, I will enjoy mine. Here are the lines: 7083 AL_MODE_ECO: LOW_LEVEL_3_DIPB[03] 7083 LIN_VARIANTE_SZL: szl_r_HW_aic_4Band_fla [30] 1DF8 C_AFS_ECO_LEVEL_3_ENA:enable 1DF8 C_AFS_ENA: enable 1DF8 C_BLC_PRE_ENA:enable 1DF8 C_CLC_BLINK_ENA: enable 1DF8 C_CLC_CURV_V2: ECE 1DF8 C_CLC_CURV_V3: ECE 1DF8 C_CLC_EXT_ENA: enable_roundabout 1DF8 C_CLC_REV_ENA: enable 1DF8 C_HBA_GFHBA_ENA_V_HI: standard 1DF8 LUT_AFS_CODRV_HOR: G05_Laser_ECE 1DF8 LUT_AFS_DRV_HOR: G05_Laser_ECE 1DF8 LUT_FLC_FORWARDLIGHTING_Y: AFS[00, 00, 00] C_HBA_DIM_DELAY: default [0A] C_HBA_DIM_ENA: enable [01] C_HBA_DIM_MAX_DIFF: default [02] C_HBA_DYN_RESERVE_LOWER_MAX: default [FB] C_HBA_DYN_RESERVE_UPPER_MAX: default [0A] C_HBA_ENA_V_HI: standard [28] C_HBA_ENA_V_HYST: default [0A] C_HBA_FILT_BND_BOT_DEC: default [05] C_HBA_FILT_BND_BOT_INC: default [19] C_HBA_FILT_BND_HOR_DEC: default [05] C_HBA_FILT_BND_HOR_INC: default [19] C_HBA_FOG_ENA: default [01] C_HBA_GFHBA_ENA_V_HI: standard [3C] C_HBA_GFHBA_ENA_V_HYST: standard_10_km/h [0A] C_HBA_GFHB_HGWY_ENA: default [01] C_HBA_HOR_BND_F_INC: default [07] C_HBA_HOR_BND_OFF: standard_04_deg/s [28] C_HBA_HOR_OFF_VEL_HI: standard_11_deg/s [71] C_HBA_HOR_OFF_VEL_LO: vel_6_9_deg/s [47] C_HBA_HOR_OLAP_CODRV: 2Grad [15] C_HBA_HOR_OLAP_DRV: 2_grad [EB] C_HBA_PREV_REA_ONC: default [00] C_HBA_SWITCH_DEL_T: default [05] C_HBA_TAU_EX_HGWY_ENA: default [01] C_HBA_TAU_EX_HGWY_L: default [F6] C_HBA_TAU_EX_HGWY_R: default [0A] C_HBA_TAU_EX_L: default [D7] C_HBA_TAU_EX_R: default [29] C_HBA_THRES_CODRV_DEACT: standard [99] C_HBA_THRES_CODRV_INIT: default [00] C_HBA_THRES_CODRV_REACT: standard [E1] C_HBA_THRES_COR_TYP: default [00] C_HBA_THRES_DRV_DEACT: standard [28] C_HBA_THRES_DRV_INIT: default [00] C_HBA_THRES_DRV_REACT: standard [05] C_HBA_THRES_HGWY_CODRV_DEACT: default [B8] C_HBA_THRES_HGWY_CODRV_INIT: default [00] C_HBA_THRES_HGWY_CODRV_REACT: default [F6] C_HBA_THRES_HGWY_DRV_DEACT: default [28] C_HBA_THRES_HGWY_DRV_INIT: default [00] C_HBA_THRES_HGWY_DRV_REACT: default [0F] C_HBA_UC1_THRES_RES_CURV_HI: default [0A] C_HBA_UC1_THRES_RES_CURV_LO: default [04] C_HBA_VERT_OFF_VEL_HI: default [06] C_HBA_VERT_OFF_VEL_LO: default [00] |
11-27-2022, 05:12 PM | #119 |
13266
Rep 19,785
LOL What an imagination you have. Thanks for posting the code, perhaps if you would have done that to begin with people wouldn't think as bad about you as they do. We are here to help each other and to give information and quash bad information. It is pretty obvious you are not interested in helping folks but rather going on some type of power trip by having information you think no one else has (although they do). My advice would be to not think of yourself as someone special but rather as someone part of a community that helps each other, maybe you will get something out of it and enjoy it more. Take it easy and good luck.
11-27-2022, 05:35 PM | #120 | |
Rep 1,070
Drives: 2022 M8cs
11-27-2022, 05:36 PM | #121 |
13266
Rep 19,785
11-27-2022, 10:56 PM | #123 |
Rep 1,070
Drives: 2022 M8cs
Excellent, back to regular programming. I shall be calling Ben
11-27-2022, 11:02 PM | #124 |
Rep 6,805
Living in Canada, the dealer will enable anti-dazzle for you, and then, you won't have to deal with it again should you get an OTA update. Canada has allowed the Euro spec of anti-dazzle for over a year now as opposed to the way the US DOT finally decided.
12-07-2022, 12:24 AM | #125 |
Rep 1,204
Drives: 2022 BMW X5 45e M-Sport
Other auto manufacturers already offer their version of Anti-Dazzle in the US.
12-07-2022, 12:49 AM | #126 |
Rep 298
12-07-2022, 12:51 AM | #127 |
Rep 298
Curious if BMW adds this as a Connected Drive addition that is added through the app/web site with a one-time charge or subscription fee. Given they just added M Adaptive Suspension coding for 40i owners, it wouldn't surprise me to see this added as a paid software option.
12-07-2022, 06:47 AM | #128 | |
13266
Rep 19,785
DonKeedic178.50 |
05-07-2023, 05:22 PM | #129 |
Rep 204
Drives: 2022 BMW X5 xDrive 40i
So when I visit Canada this summer can I ask a dealer there to code antidazzle to my US X5? I wonder if they'd be allowed to do it since mine is registered in the US.
05-07-2023, 06:49 PM | #130 |
13266
Rep 19,785
They won't do it and likely are not allowed to. Many, if not most, of their dealers won't do it on Canadian vehicles from what people are reporting.
TheACN104.50 |
05-08-2023, 02:24 AM | #131 |
Rep 1,143
Drives: 2022 x5 40!
I had the this feature enabled and they worked amazingly. The only thing you need to be aware of you cannot do updates on the car anymore. Once you do an update, it resets it and you’ll have to call them back and pay them to redo it, so turn off, automatic updating for software on the car.
05-08-2023, 12:31 PM | #132 | |
Rep 1,204
swainbmw525.50 |
