      08-22-2019, 03:45 PM   #1
007bandido
Switzerland
Drives: 2019 G05 30D M
[Coding]Start to coding G05
Hello,
Even I coded with success my old F11, I'm quite a newbie in this field and need some help to start to have fun coding with my swiss G05 30D (december 2018).
I installed Launcher and Pro 3.51, Esys 3.33.4 and PSdZData V.4.18.33_PSdZData_Lite (thanks Tokenmaster) in my notebook with Win7-64 OS.
I used this parameters to connect my car... https://www.dropbox.com/s/qbdaklj09s...ture2.JPG?dl=0 and seems Ok using target S18A 1907.
I could read and activate the FA but when I tried to read VCM, I had this error... https://www.dropbox.com/s/bwtlkwmt9r...pture.JPG?dl=0
All ECU are in red.
What I did wrong or what I did not ?
I will appreciate your help and sorry for my poor english.
Regards,
Miguel
      08-22-2019, 03:53 PM   #2
archivedaccount
Guest
n/a
Drives:
Read (ECU) not VCM
      08-22-2019, 04:40 PM   #3
007bandido
Switzerland
Of course ! Thanks!
Another thing. Is my computer or edit Kombi cafd takes around 7-8 minutes?
      08-23-2019, 12:59 AM   #4
archivedaccount
Guest
n/a
Drives:
Originally Posted by 007bandido View Post
Of course ! Thanks!
Think its your environment, but there are some reports of slow loading with the latest Launcher Pro (3.5.1.261). I have the same setup as you but running a 2 vCPU VM with 6GB vRAM on W10 x64.
DKOMBI4 (Kombi_2018) took just under 2 mins on first open. A couple of secs on subsequent openings.
      08-23-2019, 01:46 AM   #5
marcosg
marcosg's Avatar
Australia
25
Drives: 2024 G05 X5 M60i
Of course ! Thanks!
I have the same issue with slow loading cafd files. Running the latest Launcher Pro as well.
      08-23-2019, 04:29 AM   #6
archivedaccount
Guest
n/a
Drives:
Some reports that rolling back to the previous version (n-1) speeds up load time
      08-23-2019, 07:09 AM   #7
jokinawa
293
Drives: 2019 X7 40i
My environment is slower that the older releases but it is not nearly that slow.
The longest and ECU takes is 10-15 seconds.
Running on an older MacBook Pro with 16gb RAM. Loading launcher with 8192MB.
If my post was informative or helpful, please click the appreciate button. Thank you.
      08-23-2019, 10:48 AM   #8
007bandido
Switzerland
My notebook in an old Lenovo T430 i7, 16 Gb RAM, SSD... Clairly, I configured something wrong to be much more slower than you.
I will try with an old Mac Book Pro. Maybe is a good time to run for a new notebook
Regards
      08-24-2019, 08:58 AM   #9
007bandido
Switzerland
Well, I tested with a MBP 2011, 16GB RAM, 4 cores, pretty clean install and works minimum twice faster.
