      11-02-2009, 03:45 PM   #1
Georgeca
Drives: 325ci coupe
Reset 325 ci coupe alarm using Key Fob
Hi, my key fob has stopped working (325 CI Coupe).
I used the key to open the door manually as they fob would not work, the alarm immediately went off, however when I opened the door manually and put the key in the ignition the alarm stopped. I had this problem approx 18mths ago and the BMW dealership mechanic advised how to reset by using the buttons on the fob. Can anyone refresh my memory in order to reset, at the moment the alarm is now disabled since this problem, thanks and much appreciate.
P.S I tried using my spare key but that also is not working, assume this is because the alarm is now in a disabled state.
      11-02-2009, 06:12 PM   #2
J-Raid
J-Raid's Avatar
12
Drives: E46
CTRL+Alt+Del
Seriously, don't know, sorry I can't help you
      11-07-2009, 02:31 AM   #3
KreditMe
Drives: honda
Hello,
It is always good to call an mechanic and let him set the way.Why bother to call him.
