10-21-2017, 12:30 PM | #1 |
BimmerPost Supporting Vendor
3883
Rep 54,457
Drives: F80 M3
SPL TITANIUM Rear Toe Links BMW F8X M2 M3 M4 + Eccentric Lockout
SPL Titanium Series Adjustable Rear Toe Links BMW F8X M3 M4 with Eccentric Lockout Kit
SPL rear toe arms increase stability and response by eliminating bushing deflection while providing an increased range of rear toe adjustment, necessary for lowered cars or for performance alignments. Even small changes to ride height and camber will effect toe settings and the wide range of adjustment allows you to maximize grip on a track car and extend tire life on a street car. The factory rear toe arms utilize an eccentric bolt and washer for adjustment and lack the precision that SPL Parts rear toe links plus eccentric lockout washers offer. Our eccentric lockout washers ensure that your alignment will never slip like the factory eccentrics are known for under extreme loads. Black anodized and gundrilled 2024 Aluminum main links along with our 360 degree rotating clamp design allow for quick and precise adjustment. Gundrilled 2024 Aluminum Links to reduce unsprung weight 6061 Aluminum Clamps and Heim Joint Spacers Titanium Socket Head Cap Screws Rotating clamp design allows for easy access to lock down your alignment settings Low friction 3 piece Teflon lined FK Heim joints/rod ends made in Connecticut 6061 Aluminum Eccentric Lockout Washers Grade 10.9 Hex Cap Bolts with Lock Nuts Sold as a pair. Made in the USA. Applications: 2014+ F80 M3 2014+ F82 and F83 M4 2016+ F87 M2 Order here: https://www.hpashop.com/products/spl...2d5f09ee&_ss=r Last edited by HP Autosport; 10-20-2023 at 07:24 PM.. |
12-16-2017, 10:09 PM | #11 |
3883
Rep 54,457
Drives: F80 M3
12-24-2017, 10:39 PM | #12 |
3883
Rep 54,457
Drives: F80 M3
01-05-2018, 08:47 PM | #14 |
3883
Rep 54,457
Drives: F80 M3
02-02-2018, 08:31 PM | #18 |
3883
Rep 54,457
Drives: F80 M3
02-14-2018, 07:46 PM | #20 |
3883
Rep 54,457
Drives: F80 M3
Looking for SPL suspension upgrades and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
We install everything we sell. www.hpashop.com |
