11-13-2023, 10:52 AM | #1 |
1008
Rep 1,514
Taller Tires?
Has anyone tried taller tires on the Rear 22 x 11.5 rims that comes with OEM 315/30/22 tires?
I have no issues with the front tires that are 295/35/21, but the 315/30/22 on the rear are really skinny....
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) Last edited by MADBMWX5MC; 11-13-2023 at 11:11 AM.. |
11-13-2023, 08:17 PM | #2 |
Rep 3,727
Assuming outer diameters are supposed to match. Fronts use 21", rears use 22', meaning rear side needs to be 0.5" smaller. The only way to increase side wall without impacting OD is to reduce wheel size. So rear wheels needs to be reduced to 21".
If I use tire size calucator, I got these 295/35R21, OD = 29.1" 315/30R22, OD = 29.4" Rear is + 1%. We have to assume 1% is within BMW design tolerance. To be within 1% of the front, here are some examples 295/35R21: exact same as front. square setup 305/35R21: +1%. same difference as what you currently have 335/30R21: -0.7%, 345/30R21: 0% 355/30R21: +1% You will need to get new 21" rear wheel anyway. 295 and 305 should fit. 335 and beyond, it really come down to clearance and offset.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-14-2023, 08:43 AM | #3 |
1008
Rep 1,514
That's some great information. I agree with you on getting 21's. Never been a fan on 22', specially with the roads around me here in Northern VA. Thank you!
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
11-15-2023, 08:54 PM | #4 |
Rep 5
We did 295/40/21 and 315/35/22 on my wife’s car for ride quality, rim protection and to get an all season Continental dws on it. With those tires and lowered on mss the ride is better than stock, tires don’t pick up every rock and can be left on for us all year. To me it looks better than the stock size rear tire that appears stretched and very little sidewall.
11-16-2023, 04:54 AM | #5 | |
1008
Rep 1,514
12-18-2023, 10:40 AM | #6 | |
Rep 3
12-18-2023, 02:07 PM | #7 | |
Rep 594
This actually looks great! |
12-24-2023, 09:07 PM | #8 |
Rep 108
Why does tire width affect the % difference ? it should just be diameter which would just be side wall and rim size ? what am I missing ?
For example 275/40 r20 is -1.4% yet a 285/40 r20 is -0.3% I guess it is a percentage of the width not an absolute measurement. My ultimate question is do you think a 275/45 r20 would be ok for the 2024 x5 m comp ? for winter of course |
12-24-2023, 09:14 PM | #9 |
Rep 3,727
Because the height of side wall is defined by aspect ratio number, the 40 here. It means side wall height is 40% of the width. So same aspects ratio, wider tire, taller side wall, larger overall diameter.
2022 G05 B58/PHEV
01-23-2024, 03:58 PM | #11 |
2022 BMW X5M Competition | Dravit Grey Metallic
Rep 3
I've been looking at this also. The front looks fine in the 295/35/21, but the rear tire I would like a bit more sidewall. Looking at moving up to a 325/35/22 which would add 1.6" to the overall diameter. Michelin offers their Pilot Sport 4S in this tire.
01-23-2024, 04:05 PM | #12 |
Rep 3,727
Wow, front vs rear will be 1.9” or 6.5% different. No man, it is a significant.
2022 G05 B58/PHEV
01-23-2024, 04:33 PM | #13 |
1008
Rep 1,514
Well, closing the loop since I started this opne...as I am concern, I am staying with OEM dimensions for now.
01-25-2024, 07:09 PM | #14 | |
Rep 3
I was just asking if anyone else has tried other tires sizes. |
01-25-2024, 07:44 PM | #15 | |
Rep 9
eelnoraa2073.00 |
01-25-2024, 09:38 PM | #16 | |
Rep 3,727
2022 G05 B58/PHEV
01-26-2024, 07:34 AM | #17 |
Rep 196
eelnoraa Not trying to hijack, but could you explain or point to a particular link regarding why a larger diameter tire would cause an issue with the transfer case? I'm assuming same diameter front/rear - I completely understand why different diameters front/rear would be an issue. I don't understand why changing the rolling diameter equally F/R would cause issues with anything beyond speedometer accuracy (and fender rubbing if you took it too far).
Edit: I see now that you're referring to the above commented 6.5% difference front/rear. Yeah, that would be a problem for the transfer case. |
01-26-2024, 09:34 AM | #18 | |
Rep 3,727
Now different diameters front and rear, I think if difference is small, it should be ok. I refer to x5m 21/22 setup, there is a 1% difference from BMW factory, is is the largest front/rear difference I can find within x5 factory setup. I think we can safely assume 1% is ok. While I don’t know for sure at what % problem will arise, we were taking 6.5%, not 1.5%, I won’t take this risk myself. Calling 6.5% is manufacturer tolerance is laughable. In the world of mass manufacturing, 6.5% off target is called defect. This part will be rejected. As simple as windshield wiper cannot be 6.5% off target from manufacture. Heck, even if you go to home depot buy a piece of lumber, they cannot be 6.5% off target.
2022 G05 B58/PHEV
MADBMWX5MC1007.50 Jeff J109.00 |
