02-21-2019, 08:26 AM | #1 |
Rep 88
Which brake controller to get for towing?
02-21-2019, 08:33 AM | #2 |
456bhp for breakfast
425
Rep 913
I used to have a Prodigy 3 (Wired) on my truck. The mounting was clumsy, and quite large. Ended up having it under the steering wheel, above the footwell. The LCD was also very bright (with no automatic day/night adjustment) so if you have it in eye line at night it will dazzle you. You could change the colour to red to avoid that but then it's hard to read in daylight.
The Prodigy had great reviews, lots of functionality and looks way better than the BMW / OEM version so out of the choices you posted I would go for that. I liked the digital adjustment of the output voltage as opposed to the scroll wheels as once you found the right balance for a trailer, it was easy to get back to that setting at a later date. I don't understand why BMW didn't integrate one in to the dash better. |
02-21-2019, 09:19 AM | #4 |
425
Rep 913
The BMW option actually just looks like a badged Prodigy P2.
Where does the wiring harness connect if you have the factory trailer hitch installed? Is it pre-wired to the trunk? |
02-21-2019, 09:43 AM | #5 |
Rep 88
Your guess is as good as mine, this is what the manual states:
Brake Controller The vehicle manufacturer recommends that you have a Brake Controller installed by a dealer’s service center or another qualified service center or repair shop. Information on installing a Brake Controller can be obtained from a dealer’s service center or another qualified service center or repair shop. |
02-21-2019, 04:29 PM | #6 |
Rep 773
I got a Prodigy RF Wireless to use with our MDX (traded yesterday). Future proofing was part of the idea behind spending the extra money on it. It can be brought over to the X5 with minimal setup and no additional wiring to do.
rs4eva33.00 |
03-06-2019, 10:24 PM | #7 |
425
Rep 913
Bump
Has anyone worked out if the G05 comes pre-wired for an electronic brake controller if you choose 3AC Trailer Tow Hitch? If so, where is the connector? I've read the technical training docs and I can't even find the basic information about the hitch. |
03-07-2019, 06:09 AM | #8 |
Rep 604
I installed a stealth hitch system(there is a thread on it). When I was installing it I noticed a factory wiring harness connection for the OEM trailer hitch down in the passenger side wheel well behind and below the tail light. If you pull out the hatch/trunk panel on that side behind the tail light and shine a light down there you will see it. Or if you remove the bumper you can see where the harness stops and has a connector for the trailer end. I used the harness that came with my hitch so I didn't plug into the OEM one.
russelldav424.50 |
