09-19-2023, 09:43 AM | #23 | |
Rep 3,681
Do you know what fuel pressure is needed at injector output? Look it up. Tank will explode with that kind pressure. Fuel pump main pump that supply the pressure to inject is driven by cam. It take a few rotation of cranking to get the pressure. PHEV use tow start meaning the rpm the engine get cranked is much higher than typical ice starter. No problem of getting fuel pressure. Q |
Gene Horr76.50 |
09-19-2023, 10:35 AM | #24 | |
Rep 1,078
Waiting to hear what you think about the why for pressurization. |
09-19-2023, 11:10 AM | #25 | |
Rep 3,681
Steel tank is because the location is the tank. It is right at the crumple zone of the car, simple as that. It is a safety requirement. BMW cannot put this in user manual saying "yes, we relocated the tank to the crumple zone. To mitigate fuel leak in rear end accident, we use a steel tank", right? The fact is, even with steel tank a small rear end collision can still damage tank cause a leak. This happened to a friend's 23 330e. It is being repair through PeterPan BMW in our area. We had a lot of discussion about the condition of the car with BMW inspector and auto body repair shop. Maybe a bit more information from me putting friend's car on quik jack for tire rotation. Rav4 prime has normal plastic tank, it is also at the conventional location, under 2nd row seat. Per Toyota user manual, it has "pressurized tank" too, one simple pull string mechanism to open gas flap like any other Japanese ICE car, no complicated depressurized procedure. Last edited by eelnoraa; 09-19-2023 at 11:58 AM.. |
09-19-2023, 09:26 PM | #26 |
Rep 6,805
Well, we may never know why BMW chose to design their PHEVs this way, but they do have a unique electronics module to monitor the pressure and control when the deadbolt can be disengaged, a unique pressure sensor for the tank, and the button to activate the monitoring system to perform its intended operation.
Yes, vapor pressure, as in the partial pressure laws of gasses will somewhat pressurize the tank (especially with temperature increases), but that's true of any gasoline fueled vehicle...something is different about the PHEVs that elucidated the changes. While with the right software, you might be able to view the pressure (BimmerLink? maybe) we don't know what that is, or if it's higher than with a more typical vehicle...all we know is that BMW chose to add this hardware to their PHEVs. If they have figured out a way to add more pressure to the tank, that would seem to help limit some of the more volatile components from evaporating. It wouldn't take much. Unlike a typical ICE, with a PHEV, the fuel could be sitting in the tank for a very long time, so trying to mitigate the degradation may have been the impetus of the whole system. |
aMIC31.00 |
09-20-2023, 01:10 PM | #27 |
Rep 4
I understood this to mean that the tank therefore remains pressurized and in particular has no ventilation, that the gasoline quality remains constant, because it is assumed that the PHEV often does not get fresh gasoline for a long period of time.
aMIC31.00 |
09-20-2023, 01:20 PM | #28 |
Rep 6,805
While the 50e has a carbon canister to help absorb fumes and not vent them to the atmosphere as does a typical ICE, it's not clear how the rest of the venting works in the 50e versus their ICE vehicles. But, yes, part of the design parameters appears to be to help preserve the fuel quality over time and to help ensure proper activation of the ICE, even when its use could be quite intermittent with lengthy intervals between uses.
aMIC31.00 |
09-21-2023, 02:00 PM | #30 | |
Rep 99
A more important worry for sitting for so long is that you are adding fuel stabilizer. Also, while in general it is best to store fuel in a full tank to minimize air exposure, I wonder whether in this case it should be stored half full to allow mixture with fresh fuel when needed. |
09-21-2023, 02:15 PM | #31 | |
Rep 3,681
As to handling of gasoline in long term storage of car, I have been taking a different approach than yours, I make sure I have 1/4 or less tank left. When I use the car again, first thing is to fill it up with new gas. Not sure which way is better tho. this is just the way I have been doing. The longest I have gone without gas stabilizer is about 6 months.
2022 G05 B58/PHEV
+ a few very old BMWs |
09-21-2023, 02:20 PM | #32 |
MGySgt
637
Rep 1,256
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
Try moving the Flap slightly Vertical up and down when attempting to open!
JMD
09-21-2023, 02:50 PM | #33 |
Rep 6,805
Just a thought...when I had my i3, the charging door was locked, similar to the X5's two filler doors when the vehicle was locked. Sometimes, the charging door would not unlock. What BMW found was that the bolt hole was slightly too small in some temperature conditions, and it provided too much friction for the solenoid to retract the pin. The hole was a plastic part...their solution was to use a particular sized drill bit, and enlarge it slightly.
There might be a similar issue with the X5's filler door. Also, a slight spritz of lithium grease in the hole might help long-term as well. Also, one time when I was trying to get the door open, when I pulled the emergency cord, it broke. When BMW replaced it, they found that it was not clipped into the proper guides, and had become pinched when pulled. With a BEV, not being able to recharge can be as bad or worse than not being able to fill your PHEV. Usually, though, if you locked and unlocked the vehicle, it would eventually open, but not always...I'm not sure of the logic on the gas filler on the PHEV release...my guess is it just does one cycle to the deadbolt, but maybe multiple presses might help. Last edited by jad03060; 09-21-2023 at 02:55 PM.. |
aMIC31.00 |
09-21-2023, 03:45 PM | #34 | |
Rep 415
Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
