02-18-2020, 09:07 PM | #903 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Engine was warm but did not have the chance to really "floor-it", hopefully this thursday will give me a better feeling since I will be driving across mountains and beach, can wait to hit the road for the first time since I got the car....
matthew_hull65.50 |
02-19-2020, 02:58 AM | #904 | |
1200
Rep 1,587
That's a shame as I was considering purchasing bimmercode to compare the psdzdata mappings, but SASx is a deal breaker. Too much good stuff to code in there. LexxM3 if you get chance could you do an experiment for me. My dealer killed my access to DSC_VIP_IB2 when flashing to 11/2019.x, but I don't think it's used on the G05. SASx seems to take preference. Could you code DSC_VIP_IB2 back to stock FA, wiping out the aSLA coding, and see if it still works please? I only included VIP in the aSLA coding for completeness, they are like a mirror of SASx in some instances. Looks like VIP (Virtual Integration Platform) is used for system integration testing, which makes sense when you look at the codes in the ECU. Haven't got my head around the coding implications yet if any. Last edited by ifr; 02-19-2020 at 03:21 AM.. |
eagle_bmw182.50 |
02-19-2020, 08:14 AM | #905 | |
Rep 2,610
From the short read of your attachment, I don't read VIP as being non-functional (or "testing-only"). I read it rather as an alternate software interface ("API") to the braking system control, abstracting different/inconsistent BMW braking/DSC systems interfaces to present a consistent interface to driving automation software. This is pretty reasonable and practical systems engineering approach when dealing with functionally-similar-but-interface/structure-inconsistent legacy system components (although it also paradoxically further increases the number of failure points and required testing permutations; i.e. a practical short term approach that will bite back in the long term). But we'll see what clearing it to stock does ...
02-19-2020, 08:35 AM | #906 |
1200
Rep 1,587
Thanks.
There is another document which I had read prior to posting the DSC specific content, which is more conceptual on VIP. I'll send you the link. It will be good to bottom this. It should be easy to test as you'll most likely not be able to choose to turn on aSLA, or will get a region lock warning, if it needs VIP as well. |
LexxM31701.50 |
02-20-2020, 04:00 PM | #907 |
174
Rep 391
02-20-2020, 05:08 PM | #908 | |
174
Rep 391
Anyone know what CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG is supposed to do? |
02-20-2020, 05:45 PM | #909 | ||
1200
Rep 1,587
02-20-2020, 06:11 PM | #910 |
174
Rep 391
No. Of course, turning DA on and then canceling it (hitting the brake or gas) disables the DA but leaves ADV on. But no, not with a menu option. Only with that workaround.
02-21-2020, 02:40 AM | #911 | |
1200
Rep 1,587
When enabled in coding you can set the idrive Display to use ADV instead of Nav etc. |
02-21-2020, 02:49 PM | #912 | |
Rep 2,610
Results of aSLA coding without DSC_VIP_IB2 ECU
Last edited by LexxM3; 02-21-2020 at 03:27 PM.. Reason: Made more readable with bullet points |
02-21-2020, 03:27 PM | #914 |
174
Rep 391
02-22-2020, 02:35 PM | #915 |
Rep 5,457
Anyone else having issues with the new version crashing. Mine works fine unless I try to read out the body control module, which is the whole point of using it as I wanted to code a few things in there. When it goes to read the line just moves slowly, never changes to a percent and starts to read, app goes non responsive and then crashes after a few minutes. Any other module still works fine for me except the newly added Body one, using an OBLink LX - sent off a report to the developer but wondering if anyone has had a similar issue?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
02-22-2020, 03:35 PM | #916 | |
Rep 71
02-22-2020, 03:49 PM | #917 |
Rep 5,457
Forgot to mention, I am on Android.
02-22-2020, 07:29 PM | #918 |
Rep 446
I can confirm the Body Domain Controller ECU is now added on the current beta of Bimmercode for iOS and works beautifully. And yes, you can now code default driving mode and all 6 modes are available.
02-23-2020, 03:59 AM | #919 |
Rep 810
I'm on Android too, Bimmercode version:- 2.17.3-6357 to be exact, and very stable, no crashes for me.
Is your device on "Flight mode" when you're using Bimmercode, maybe the comms are being interrupted by other activity in the background? |
02-23-2020, 08:07 AM | #920 |
Rep 810
02-23-2020, 09:09 AM | #921 | |
524
Rep 2,146
02-23-2020, 10:56 AM | #922 |
Starfleet Command
315
Rep 785
I wonder why the update to the iOS app is taking so long I want to get going on these new features
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
02-23-2020, 11:09 AM | #923 |
Rep 446
02-23-2020, 11:20 AM | #924 | |
Rep 5,457
Will report back after reinstalling.
