09-14-2022, 08:23 AM | #1 |
Rep 1,220
XHP Reflash after transmission service?
Hi everyone,
I did some searching on here and Google and couldn't find the specific scenario I'm looking for info on. I had a shop do a trans service on my car, changing out fluid and doing the pan/filter replacement. My car has been flashed to XHP stage 3 for the past 1000 miles or so. Question: do I need to do any unflashing or reflashing with XHP with this service being performed or just leave it? Thank you- JM
2024 M2
2019 M240i- Sold |
09-14-2022, 10:02 AM | #2 | |
Rep 516
Pretty sure you do not need to unflash or reflash xhp by only changing out the oil and filter. It doesnt change much more than making it smoother
JMcLellan2081.00 |
09-14-2022, 10:12 AM | #3 |
Rep 1,220
That's what I was thinking. The shifts do feel smoother but I have heard the whining noise a couple few/times randomly accelerating in a couple different gears. That did not happen before the service. Sounds like that is a normal thing for the 8 speed auto trans.
2024 M2
2019 M240i- Sold |
09-14-2022, 10:27 AM | #4 | |
Rep 516
09-14-2022, 11:05 AM | #5 | |
Rep 1,220
2024 M2
2019 M240i- Sold |
09-15-2022, 08:08 AM | #7 | |
Rep 516
I read somewhere in the past, the adaptations is supposed to adapt to your wear and tear in the systems. If you reset it by just doing filter/fluid, wouldnt that messed everything up? At the same time, the adaptations adapt to the old filter/fluid which is probably rougher. So when that changes, wouldnt that needs to be reset? |
09-15-2022, 08:16 AM | #8 | |
Rep 1,220
2024 M2
2019 M240i- Sold |
10-04-2022, 12:43 PM | #9 |
Rep 140
Anyone have a link to a step-by-step DIY guide for changing the ZF8 ATF & pan/filter?
Had a one-man shop do it for me the first time around at 42k miles and it didn't take long. Figure I'd give it a try while I'm under there to change the oil. |
10-24-2022, 12:11 PM | #10 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
You are NOT supposed to reset trans adaptions after a service. Only do that if you have a trans rebuilt or replaced with a new one. Thats very very bad..
If you have issues after a service its likely an issue where the trans isn't at fluid capacity.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
JMcLellan2081.00 |
10-24-2022, 08:03 PM | #11 |
Rep 558
Timely thread.
I also had my trans serviced recently at ~50K mi. at a local BMW dealer. And, I also think I heard a whine under acceleration that I didn't hear before. You'd think they would have topped it off properly, but maybe I should bring it back to have them check, just to be sure. Edit: I did not re-flash xHP or reset adaptations.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
JMcLellan2081.00 |
10-25-2022, 09:12 AM | #12 |
1297
Rep 3,536
Oh and you do not need to reflash anything after a servuce.service.. at all.. thats silly
10-25-2022, 03:10 PM | #13 | |
Rep 1,220
I haven't heard the whine in a couple weeks and no drivability issues for me.
2024 M2
2019 M240i- Sold |
PeterWT253.50 |
