01-26-2020, 12:04 AM | #133 | |
1202
Rep 1,587
01-26-2020, 06:47 PM | #134 |
Rep 159
Sorry in advance. I have used E-Sys to successfully code my old F15 but am just stuck with my G05 M50i.
I now have E-Sys 3.33.4 64 bit up and running with E-SysX I get a good connection with using the latest psdzdata file hooked up to S18A_19_11_534_V_004_000_001 All good. Now I get stuck. I have searched high and low to be able to do the first code. I am using .pdf instructions E-Sys Version 3.18.4 Getting Started: Coding All good, I connect up to the car, read the ECU and find all the areas i want to code and then I get stuck. So I have the G05/7 Cheat codes that Jokinawa kindly put together. Here is an example that I want to do. </cafd> <cafd id="00002742" name="DME_BAC2" author="jokinawa" series="S18A"> <!--group 3020 BSU_BEREICH--> <code description="[DIAG] Enable Auto Start Stop Memory"> <group id="3020"> <function start="19" end="19" comment="TCM_MSA_MEMORY" mask="00000010b">01</function> </group> </code> </cafd> I find BSU_BEREICH. I find "TCM_MSA_MEMORY" Then I am stuck I am normally used to going in to change a value for Non_ Active to Active or change a Werte from 0 to 01 or similar. With the above I have no idea how to change it. I have looked on the internet how to complete the code instructions that jokinawa created but I do no find and instructions and cannot execute. Please can someone point me to some instructions? |
01-26-2020, 08:43 PM | #135 | |
Rep 2,610
To answer your direct question, code that parameter to 01 or Aktive as the case may be. The 01 is represented by this segment: 'mask="00000010b">01' Also, DME is the one ECU you cannot code with engine running. It must be coded in non-engine-running Diagnostic Mode.
01-26-2020, 09:27 PM | #136 | |
Rep 159
01-27-2020, 10:56 AM | #137 | |
Rep 133
Hope it works for you. Armando |
01-27-2020, 11:15 AM | #138 | |
Rep 602
01-27-2020, 11:25 AM | #139 | ||
Rep 2,610
01-28-2020, 10:46 AM | #140 | |
Rep 133
A question on linking the cheat sheets. I use the latest Launcher PRO wth latest 64bit ESYS, where and how do you set the cheat sheets to use when doing the FDL Coding. I have done all my codings manually since the XML file is really easy to read and follow using all the values on it. Armando |
01-28-2020, 10:55 AM | #141 | |
1202
Rep 1,587
You can't rely on the cheat creator to generate the cheats and not make mistakes. Another scenario is that codes change based on different i-step, or as a result of testing, and the creator doesn't update the cheat xml. For example, I briefly made some mistakes with LCA and included coding for NHA (emergency stop when driver unresponsive, change lane to kerb, call emergency services) which is potentially dangerous - they were in the G05 cheats for a while but now removed. So easy to just click apply cheat rather than reviewing what you are actually changing. |
mandomedic12240.50 |
01-29-2020, 01:37 PM | #142 |
Rep 159
Well, I finally got to code my M50i!
I did M Logo, M Dash layout, ASS, Allow closing of windows and sunroof with keyfob, Emergency Brake Force Display Europe default, Emergency Brake Force Display -Area Enlargement (whatever that means?) , Disable Camera Legal Disclaimer, Disable Legal Disclaimer Time (whatever that means?), Change Startup Emblem to BMW M, Enable Tailgate close with keyfob or switch (no holding), Change Start Mode To Adaptive With the M Dash layout it does not show what mode you are in -Comfort, Sport, Sport Plus or Adaptive. With the M50i dash layout it would show the mode below the Tach. So even though you hit Sport Plus, it shows changing on the big screen, you can feel it is in Sport Plus but then there is no indication that you are still in Sport Plus. Is this normal? Startup Emblem to BMW M does not show up when you have made a custom profile Welcome start up display. I chose one of the BMW images and to say Welcome Bigtop. That still shows and no start-up BMW M. On the old F15 I could program with E-Sys so that the car would remain in the last mode (Sport, Comfort, etc. ) you were in last. Can that be programmed with the G05? thanks |
01-29-2020, 02:02 PM | #143 | |
1202
Rep 1,587
FesPiaDefaultLastUserMode from 04 to 0A (adaptive) I think the other options are in the drop down list and self explanatory. |
01-29-2020, 03:04 PM | #144 | ||
Rep 2,610
ifr1201.50 |
01-29-2020, 05:15 PM | #145 |
1202
Rep 1,587
Ah yes misread that.
This could be possible and maybe one for you to have a crack at? Maybe review the translated comments for each of the possible modes e.g. FesSportWorldMode0, "highest bit = 1 means: mode is allowed as Last User Mode" There's also FesPiaPortableLastModes which may or may not need to be active. Will need some trial and error I suspect, and might not work, but there are some clues there. Currently whatever we set in FesPiaDefaultLastUserMode becomes the default mode, but the notes for that code state that its only used if the suspension modes dont allow last user mode. So, maybe changing the modes themselves to allow last user mode would take precedence over the default fallback setting? |
LexxM31703.00 |
01-29-2020, 05:54 PM | #146 |
Rep 159
Anyone tried to use the M dash?
With the M Dash layout it does not show what mode you are in -Comfort, Sport, Sport Plus or Adaptive. With the M50i dash layout it would show the mode below the Tach. So even though you hit Sport Plus, it shows changing on the big screen, you can feel it is in Sport Plus but then there is no indication that you are still in Sport Plus. Is this normal? |
01-29-2020, 06:01 PM | #147 | |
Rep 2,610
gpitts247.00 |
01-29-2020, 09:58 PM | #148 | |
Rep 18
01-29-2020, 11:05 PM | #149 |
Rep 159
01-30-2020, 10:11 AM | #150 |
Rep 159
01-30-2020, 10:24 AM | #151 |
Rep 602
01-30-2020, 11:12 AM | #152 |
Rep 159
You cannot flip it back. You hit refresh on the cheat codes and where you had checked the box to change
to M Display, it is now unchecked, even though the display in the car dash is M Display. You cannot check a box called M50i display or Default display. |
01-30-2020, 11:19 AM | #153 |
Rep 2,610
This is the bit of trouble if you rely on cheat code files without fully understanding what they do. This won't be that tutorial, but the simplest way to revert to stock with ESys is to just Code the specific ECUs. Note I said Code not Code NCD — Code is aka VO Code and is right click ECU and carefully choose Code.
01-30-2020, 11:27 AM | #154 |
Rep 602
You should have also backed up your files. That way you can see what those values were and restore them without losing any other coding in the ECU which you wish to keep.
