12-24-2020, 06:37 PM | #23 | ||
Rep 4,246
As TurtleBoy mentioned the suspension is COMFORT biased. Quote:
I should add the other aspect of DDC which effect other X5 controls: For example, pressing SPORT on the console effects the following in the X5: Damping - sportier, stiffer ride damping Steering- heavier steering Engine - faster response Transmission - hold gears longer in conjunction with engine The following systems are also adjusted: - Integral Active Steering (if optioned) - Display in instrument cluster - Cruise control You can configure the above settings via iDrive under Configure SPORT INDIVIDUAL: CAR > Settings > Driving Mode > SPORT INDIVIDUAL > configure your personal settings Damping: Comfort / Sport Steering: Comfort / Sport Engine: Comfort / Sport / Sport Plus Transmission: Comfort / Sport / Sport Plus
12-27-2020, 10:37 AM | #24 | |
Rep 7
08-03-2021, 06:10 AM | #25 |
Rep 618
Fascinating thread
I currently have a BMW 640d in M-sport trim with adapative dampers (allegedly). I say allegedly, because the car is (in my view) way too hard. I drive on english country roads. I've cracked two alloy wheels beyond repair. i'm looking at switching to an X6 and a primary reason for that is for greater ruggedness and better ability on crap roads. So I pretty much *assumed* I'd want air suspension right? Then I read this thread - which contains probably the only true A/B comparison I've seen on an X5/X6 and prefers the springs and dampers set up?? Truly confused now as to which I should go for. i've test driven an Air suspension X6 - it was a good deal softer - and I like that. I've not tried a springs and dampers one. - Is it different to the comparable set up in a 640d? |
08-03-2021, 07:29 AM | #26 | |
13275
Rep 19,805
08-03-2021, 12:51 PM | #27 |
120
Rep 318
I currently have an X5 F15 with 2VF (adaptive M) and rear axle air. Occasionally, the ride gets floaty in comfort and I just switch driving modes to "sport" which dampens the floaty feel a bit.
QUESTION FOR G05 owners with 2 axle air: Wouldn't the X5 G05 2 axle air react the same in "sport mode"? And in "sport" mode, the ride height lowers a bit so wouldn't that help reduce the effects of float?
Test
08-03-2021, 02:51 PM | #28 | |
Rep 4,246
The new 2VR 2-axle air suspension is a significant improvement over previous generations with sealed air strut units and system. Yes, selecting Driving Dynamics SPORT mode lowers the air suspension ride height to Sport which is -20mm or -0.787" from Normal level and also affect other driving aspects like engine, transmission response etc. Now, manually adjusting the air suspension from Normal to Sport ride height, DOES NOT change the Driving Dynamics mode. This allows you to let's say drive in Adaptive mode with Sport level ride height.
08-03-2021, 05:44 PM | #29 | |
120
Rep 318
Test
08-03-2021, 06:06 PM | #30 | |
13275
Rep 19,805
Edit: By firm and low I'm assuming you are referring to just the height being lowered and not any adjustments to the DDC.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 08-03-2021 at 06:15 PM.. |
08-03-2021, 06:09 PM | #31 | ||
Rep 4,246
SPORT, SPORT+, or SPORT INDIVIDUAL with damping set to SPORT Any of the above 3 DDC modes with automatically adjust the air suspension to Sport level and provide Sport damping. Manually adjusting the air suspension on it's own doesn't affect the DDC modes or damping and you're just adjusting the vehicle's ride height.
08-03-2021, 06:24 PM | #32 |
BMW forever!
1389
Rep 2,418
Air suspension for me on a SUV. I went with 21 inches wheel size + air suspension.
The M adaptive did not feel comfortable to me and I drove with different wheel sizes. Just felt that air had the right feel in all settings. For a more M feeling ride I have the M2C.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
08-04-2021, 09:36 AM | #33 | |
Rep 809
Auricom4361.50 |
08-04-2021, 11:03 AM | #34 |
Rep 83
Hello Auricom.
I have "discovered" the Sport setting via the shifter, basically pull the shifter to the left and it changes the suspension and shift point completely, especially when taking corners!!!. Take a corner hard in Comfort and the front will bounce a little, but pull the shifter to the left and the car changes completely. Previous car was 2017 X6M, so I am used to the drive/handling in an M car. This X5 M50i with air suspension has the perfect blend of comfort (in Comfort mode) and when I want to "take" a corner, pull shifter to the left and you can enter/exit the corner as if you are on rails. It saves me having to take my eyes off the road and press the Sports button which has everything set to the max. My question is does putting the car into Sports mode via the shifter tighten the body dynamics also, basically the same as pressing the Sports button?? |
08-04-2021, 11:55 AM | #36 | |
Rep 4,246
TL;DR version of the Steptronic Transmission modes - Drive, Sport and Manual These modes ONLY affect the transmission. One of the many links to discussion: Confused about sport mode https://g05.bimmerpost.com/forums/sh....php?t=1773893 There's another one I'm locating that goes into additional transmission behavior scenarios. Found it: M Mode vs. S Mode vs. D Mode with Paddle Shifts https://g05.bimmerpost.com/forums/sh....php?t=1837152
john1200c238.50 |
08-04-2021, 04:14 PM | #37 |
120
Rep 318
My take away from all the excellent information so far: If I want a G05 M Sport with the ability to ride lower AND have a sporty damper setting, it's 2 axle air. But alas, the current BMW configurator and 2022 DOG shows 2 axle air only available on the M50i (or the 45e). I suppose I could search for a CPO G05 40i, 2020-21, equipped with 2 axle air or just pony up for a M50i (which or course is a big upgrade). Any insights? Thanks
Test
08-04-2021, 05:51 PM | #38 | |
13275
Rep 19,805
08-04-2021, 06:11 PM | #39 |
120
Rep 318
That's actually a good plan. This time next year would be my timeframe. I'll either order a new 2023 G05 X5 4.0i, assuming no other unfavorable changes, or look for a loaded CPO 4.0i with IAS or even an M50i equipped with IAS. And hopefully by that time, dealers will loosen up on discounting like they were in the past. Thanks!
Test
08-04-2021, 06:33 PM | #40 | |
13275
Rep 19,805
08-06-2021, 02:50 PM | #41 |
Rep 4,337
Adaptive vs Adaptive “M” (M Sport Pkg) suspension hardware
First off this is a great thread, very informative. After reading it, I went to Realoem and saw that the spring struts (shocks) part numbers are different between the two (X-Line and M Sport) suspensions. I cannot find the springs themselves on Realoem. My question is..what are the mechanical differences between the shocks/springs in the two suspensions? Just want to understand how they are different but am not asking about any electronic control differences, just the hardware itself. Anyone know for sure?
08-06-2021, 02:59 PM | #42 | |
13275
Rep 19,805
The MSport package, and the standard on the M50i is the Adaptive M suspension.
08-06-2021, 03:30 PM | #43 | |
Rep 4,337
I called a dealer, they said the only diff is that when you have the Adaptive M Suspension, it locks the differential but when I started questioning that, their response fell apart This is the path I took in Realoem. .. not sure why the professional showed since I did not choose the M50i, however, when pulling up the M50i in Realoem, the shocks are the same part number. f I choose the X5 40i and not the X5 40iX, I still do not get an option that says...with M Sport, its either M Sport Prof or just the spring struts with VDC. . Last edited by Marty in NY; 08-06-2021 at 03:43 PM.. |
08-06-2021, 04:37 PM | #44 | |
13275
Rep 19,805
