04-30-2021, 09:50 AM | #24 |
Rep 8,698
Drives: eVeRyOnE mAD!
...but you lose the foot opening sensor. I had a tow hitch on my previous Q7 and never used it once in the 5 years of ownership. I've used the foot sensor on my 4-month old 45e more times than I can recall.
04-30-2021, 10:06 AM | #26 |
Rep 8,698
an example of how everyone's use case is different ...why we let others choose options according to their needs.
any option isn't a "must order bargain" if one never uses it, correct? (I've learned speaking in extremes is usually unhelpful.) |
04-30-2021, 11:14 AM | #27 |
Rep 2,609
Mostly true, except for the compact spare tire kit. At $150 option in US, IT IS a must order option. Then sell it to a Canadian if you really don't want it. Tow package is more nuanced.
gqgambler716.00 |
04-30-2021, 11:22 AM | #28 | |
Rep 8,698
Still a great value for a piece of kit that should come standard (even just basic tools for the 45e with RFTs). "would rather have it and not need it versus need it but not have it." |
04-30-2021, 12:12 PM | #29 | |
Rep 744
04-30-2021, 09:05 PM | #30 | |
Rep 2
04-30-2021, 09:57 PM | #31 | |
Rep 4,246
"Front brakes are upgraded with towing package option - identical to M Sport brakes but in silver and w/o ///M logo - larger front discs are also included but not as large as M Sport" And it answered why his 45e front brakes and rotors are different than what's standard on 40i. And you're correct to advise potential 45e shoppers that they don't need to option 3AC for upgraded brakes unless they actually do need the trailer hitch.
05-30-2021, 11:11 AM | #32 | |
Generalissimo
641
Rep 1,392
06-20-2021, 07:10 PM | #34 | |
Rep 4,246
You're only paying for the trailer hardware when option 3AC on 45e. X5 45e or 45e with 3AC tow hitch: Front fixed 4 piston, front discs 374x36 + rear discs 345x24, lightweight ventilated X5 45e with 2NH M Sport brake Front fixed 4 piston, front discs 395x36 + rear discs 370x24, lightweight ventilated
06-21-2021, 06:59 AM | #37 | |
Rep 4,246
06-21-2021, 09:37 AM | #38 | |
Rep 4,246
Drilled and vented 395 x 36 mm front brake discs and 380 x 28(?) mm rear brake discs. Optioning ceramic increases front discs to 400 x 36mm with no other changes to front calipers.
-Vanguard-1177.50 volodp198.00 |
06-21-2021, 10:02 AM | #39 | |
1178
Rep 1,502
06-29-2021, 08:22 PM | #40 |
Rep 781
I would order just for the upgraded brakes - But, I use my bike rack all the time. Its a must have for me.
06-29-2021, 11:52 PM | #41 | ||||
Rep 28
06-30-2021, 12:02 AM | #42 | |
Rep 4,246
The wheel spec for factory OEM 19" winter wheel set is 9Jx19 ET38 (265/50R19 110H tires). If your 19" wheel set meets the minimum offset of ET38 then you're fine.
06-30-2021, 12:08 AM | #43 | ||||
Rep 28
07-02-2021, 08:27 PM | #44 | |
Rep 426
And here’s the surprise - on G05 the opening pad that you press is soooo big that makes it 10 times easier to open the trunk. I agree with those who opt in for a tow hitch and bigger brakes. |
