05-21-2023, 09:04 AM | #24 |
Rep 539
I don't put much faith in the estimated range on battery power, as it's much like looking at the weather forecast for yesterday.
But I did notice when I started the car yesterday on a 90-degree afternoon, the range displayed was 43 with the AC running. I turned off the AC and the range jumped to 50 immediately, with the car still parked. While I don't make much use of the information, it was interesting to see the effect of the AC on range. |
05-21-2023, 11:38 AM | #25 | |
Rep 3,681
Per US spec, 51 miles/1.7kWh = 3.0Mi/kWh. While it is possible in very special usage case, say driving down hill, but under most normal usage, it is highly improbable. 3Mi/kWh is in the very efficient BEV category for the size. Even Rivian cannot do this, hack, even model X cannot do this. |
05-21-2023, 01:57 PM | #26 |
Rep 6,806
When I had my i3, one day it was parked in my fairly warm garage. To do some stuff there, I moved it outside overnight where it was in the teens (F). I moved it maybe 20'. When I got into it the next morning, the estimated range had dropped about 10 miles...the temperature has a real effect on an EV or PHEV range. While the i3 had a heat pump, so was more efficient at heating than the PHEV, the X5 PHEVs do not, so there's a bigger difference in HVAC energy uses than on a vehicle with a heat pump...ALL HVAC in the X5 PHEVs is done electrically. Cooling moves more BTUs per watt than heating does (IOW, heating costs more in power than cooling to change the cabin temperature one degree).
Vehicles have had estimated range to empty on their ICE vehicles for decades...the range listed on a PHEV or BEV is the same...it's an estimate based on previous use and in no way is going to represent reality for your NEXT drive all of the time...unless your driving and use are identical (how often does that happen?). The EPA (of what's used elsewhere in the world) estimate is done under specific controlled conditions so that you can get an apples-to-apples comparison, but was NEVER intended to be a guarantee of what you'd get in YOUR situation and use case. |
05-21-2023, 04:47 PM | #27 | |
Rep 125
05-22-2023, 06:48 AM | #29 |
Rep 213
Are you concerned about battery warranty with the coded EU spec? Do you plan to "uncode" it every time it goes in for service? Or maybe just uncode it if there's a battery/drive train issue?
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
05-22-2023, 07:15 AM | #31 |
MGySgt
637
Rep 1,256
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
But then my question would have to be,..."What is the farthest eMiles you've driven in 'Individual Electric' mode?" vs,..."Post Your Highest 45e Starting eRange thus far!"
JMD
05-22-2023, 07:18 AM | #32 |
MGySgt
637
Rep 1,256
Nice!
JMD
05-22-2023, 07:20 AM | #33 | |
MGySgt
637
Rep 1,256
JMD
05-22-2023, 07:21 AM | #34 | |
MGySgt
637
Rep 1,256
JMD
05-22-2023, 07:23 AM | #35 |
MGySgt
637
Rep 1,256
Well done,...yessir! Very nice,...just imagine getting these kind of results consistently!
JMD
05-24-2023, 03:26 AM | #36 |
Rep 113
The highest estimate before start was 111 km.
The highest estimate while driving was 140 km (37.7 km driven plus estimated range 103 km). The maximum distance with purely electric driving was 78 km + 16 km estimated range. |
05-24-2023, 06:14 AM | #37 |
Rep 125
05-24-2023, 10:06 AM | #38 |
MGySgt
637
Rep 1,256
JMD
05-24-2023, 10:08 AM | #39 |
MGySgt
637
Rep 1,256
You may be the Top Dog for 45e range showing at start! We can only dream of that kind of starting range in the U.S.!
JMD
07-04-2023, 02:12 AM | #40 |
Rep 209
US spec, 50 miles! Didn’t know why, just did a road trip with obvious mostly gas highway miles, and today ev range shot up to 50, it’s typically 32-35miles.
07-04-2023, 07:34 AM | #41 |
Rep 8,700
Drives: eVeRyOnE mAD!
that higher electric range upon full charge is simply a reflection of efficient driving prior to charging. it sounds like you had a decent amount of hill descents on your recent road trip there in the PNW. such features play in your favor. to actually achieve those 50 electric miles, you'd have to drive exactly the same way as you did prior to charging. otherwise, it's the typical 30ish miles
ddnmkun153.50 |
07-04-2023, 07:44 AM | #42 |
Rep 68
95km (59 miles) in the EU version of starting range.
Finally, I drove 80km (49 miles) with pure electric engine, but I was the slowest car in the city ;-) (driving with respect to the signs, which nobody is doing here) |
07-04-2023, 01:45 PM | #43 | |
Rep 209
So because the car was driving gas uphill and electric downhill and the car thought it was efficient cause it only looked at how it was used? |
07-04-2023, 07:34 PM | #44 |
Rep 8,700
in a nutshell, yes, but this concept shouldn't feel foreign. it's no different with the estimated range showing on the instrument cluster in gasoline-only vehicles. if you baby the throttle, you'll burn less gasoline which is the same as being more efficient, and you'll get more range. if you gun it, you'll burn more gasoline which is the same as being less efficient, and you'll get less range given the same amount of gasoline
