      02-05-2024, 06:27 AM   #1
Tek-dad
Drives: 20 X5 M60i 24 i5 M60 24 X7 M60
Continental Discontinued?
So I need a new rear driver’s side tire and I was told that the continentals I have on my 2020 X5 m50i are discontinued. I guess I have to go with another brand. I’m also guessing I would need to replace the rear passenger side also even though it’s in good shape.
So my question is which tires to get? Anyone have recommendations?
315 30 R22 in the rear and 275 35 R22 in the Front.
Thanks in advance!
      02-05-2024, 04:53 PM   #2
LDT
LDT's Avatar
1540
Drives: 2024 X5 M60i
Thanks in advance!
Have you searched tirerack? Or discount tire?
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^
2017 X5 35d--still in my diesel phase
2015 GL 350--diesel burner/highway queen
2013 Audi S6--a beast in it's day
      02-05-2024, 10:21 PM   #3
Blue87
Blue87's Avatar
376
Drives: 23 X5 M50i, 05 S2000
Which tires do you have on currently? The continental premium contact 6 tires are still showing available.
      02-06-2024, 01:52 PM   #4
Tek-dad
Available where? I saw the fronts but the rears are on back order. If I swapped out the rears with say Michelin do I need to swap the front too?
Thanks!
      02-06-2024, 02:15 PM   #5
Blue87
Blue87's Avatar
376
Thanks!
Tirerack is showing In Stock for the fronts and Limited Stock for the rear. You could also check with a dealership, especially since many are competive with tirerack's pricing. I ended up buying fronts through the dealership since i also needed an alignment due to some Abby-normal tire wear and the price was about the same. I would use the same tire all around.
LDT1539.50
      02-08-2024, 10:55 PM   #6
spike5150
Drives: 2020 X5 M50i
Thanks!
No, you don’t have to replace the fronts too.
But you should use matching tires on each axle. The car would still be drivable if you didn't, though (I recently drove with the donut spare and it handled fine, of course)
