05-02-2021, 07:56 PM | #1 |
Rep 500
Torque value for front caliper nuts?
Swapping out my front pads. Any idea of torque setting for the 14mm hex nuts that need to be removed to get to the brake pad? Thanks!
05-03-2021, 02:21 AM | #2 |
Live for today tomorrow never comes
1989
Rep 9,498
These are stretch bolts they need replacing every time they are removed. Can't remember the torque setting.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
05-03-2021, 08:54 AM | #3 |
Rep 500
Not sure we're talking about the same thing. The ones I removed are simple shoulder nuts. Not bolts. These 14 mm nuts attach to studs on the caliper carrier.
05-03-2021, 09:33 AM | #4 |
1989
Rep 9,498
OK not sure on that sorry.
05-03-2021, 02:44 PM | #5 |
Rep 3,298
Watching thread for the answer....
Photos of the job being done??? High resolution 8k Video?? Come on man! Mike JK
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
05-04-2021, 04:01 PM | #6 |
Rep 500
Sorry, but it's pretty straightforward. Remove pad wear sensor. Tap the two pins securing the pads out using a punch. Loosen sensor cables and brake line from grommet holders. Remove the two 14mm hex nuts from the caliper. Slide caliper out. Pads should fall out easily at this point. Might need to compress caliper pistons in to get new pads in. Reinstall pins before sliding caliper back into place. Tighten the two 14mm hex nuts. Reinstall sensor and secure sensor cables and brake line back into brackets.
VPRKLR63.00 |
05-04-2021, 04:45 PM | #7 | |
Rep 3,298
Mike
